Overheating for a second, then returning to normal temp quickly???
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Dec 23, 2020.
  1. Dec 23, 2020 at 2:42 PM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    Alright guys this has happened 2x in 2 days in a row now. Driving under normal conditions nothing crazy at all. 95K miles. 2017
    All of a sudden I get a overheating warning and a beep from the dash. Quickly look at the gauge and confirm it is overheating, and then before I can pull over the warning goes away. And then with-in 30 seconds the temp gauge is back at normal operating temperatures.
    Truck is running fine, no leakes or smells.
  2. Dec 23, 2020 at 2:46 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Sounds like it could possibly be a connection issue on the sensor. I have no idea where the sensor is located.
  3. Dec 23, 2020 at 2:46 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    Describe normal conditions. Hauling or towing? Passenger count? Stop and go traffic? Highway speeds? 90 MPH? Length of drive (miles and/or time) before this happened?
  4. Dec 23, 2020 at 3:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Could be as simple as an air bubble or the radiator cap. Check both. On the cap, make sure all the gaskets are present (see below). If/when it happens again, pull over anyway to see if it looks like the expansion tank filled with fluid briefly and then emptied back into the radiator again. I had that happen on a Tacoma once where the radiator cap was on it's way out, not reliable holding pressure.
    nobodyintexas and jmevis[OP] like this.
  5. Dec 23, 2020 at 3:10 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Both times this happened on about a 15-17min-10mile drive. with about 10-12 min of highway speeds 70-85mph. The overheating would happen about 13-15 min in to the drive. After exiting the highway. But I have driven a few times today longer distances and nothing happened.
    LS3 and Doctor Flex[QUOTED] like this.
  6. Dec 23, 2020 at 3:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wonder if the thermostat was stuck closed for a moment...could be the t-stat, or a piece of rubber from the cap that kept it from opening only to eventually bounce out of the way... Easy enough to check the cap after the engine cools.
    bfunke, Northbound Train and GODZILLA like this.
  7. Dec 23, 2020 at 3:20 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    I thought also that the thermostat could be stuck closed.
  8. Dec 23, 2020 at 5:50 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Could try an obd reader scangauge or ultra gauge and see if your temps are really fluctuating or a bad gauge.
    mgrs and (deleted member) like this.
  9. Dec 23, 2020 at 8:16 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    As stupid as it sounds, how is your coolant level? Sensors pick up fluid temperatures better than air temperatures.
    PeakIT likes this.
  10. Dec 23, 2020 at 8:30 PM
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    Possible causes 1)Intermittant tuck closed T-stat, 2) Bad coolant temp sensor 3) Radiator cap not holding the proper pressure, 4) You've got air in the coolant system and need to get it out, 5) Wrong mix of coolant/water that caused some localized boiling (for that matter, freezes the water), 6) Hopefully not, early signs of a head gasket failure. You can "burp" some combustion gases into the coolant system, cavitates the water pump, overheats until it purges some of the air and then all looks fine. It repeats this cycle until there is a gross head gasket failure. Smell the coolant and look at it's color. Hope that helps.
  11. Dec 27, 2020 at 5:29 AM
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    Sounds like coolant could be low, same thing happened on my work truck
  12. Dec 31, 2020 at 10:12 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Here is a development. It has happened 2 more times now. And I'm starting to think its the dash gauge cluster malfunctioning.
    The radiator cap is holding pressure. And the fluid isn't low. I have a OBD2 reader installed and when it was sending the over-heating warning Torque was showing a temp reading of 204-205 degrees. I think thats with in normal operating spec?
    I have a hypertech speedo calibrator installed in the dash and I wonder if that is messing with the gauge cluster. Also when I have filled up on gas the last 2 tanks the fuel gauge wouldn't go all the way to full it would stick around 3/4 full.
  13. Dec 31, 2020 at 10:22 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The logical thing to do would be to disconnect the Hypertech device and test drive for some days, I would suppose.
    majbjb, Rocko9999 and JLS in WA like this.
  14. Dec 31, 2020 at 10:26 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Agreed. Just gotta rip apart the dash. Luckly im getting good at that.
    Patch999 and Wynnded[QUOTED] like this.
  15. Dec 31, 2020 at 10:27 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, once you know what you're getting into it goes much quicker.
  16. Dec 31, 2020 at 12:26 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    hypertechs have caused cluster issues before and is where I would start troubleshooting.
  17. Dec 31, 2020 at 6:20 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Sounds like your on the right track
  18. Jan 14, 2021 at 7:24 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Update. It has done it 2 more times now. I have been able to monitor the temp on the Torque app and i can see the temp climb up to 250 ish and then drop quickly. I think I'll start with the thermostat. Since this is reporting from the OBD2 port.
  19. Jan 14, 2021 at 9:02 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    If your seeing that the vehicle is actually sending periodic temp fluctuations. I wouldn't suspect thermostat, maybe a temp sensor going bad.
  20. Jan 14, 2021 at 9:14 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Any idea where those are located?
  21. Jan 14, 2021 at 6:16 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Not exactly sure, I suspect mounted to the block near the thermostat, did a few internet searches and didn't find anything that showed where it's mounted on 3rd gens. Maybe someone else can answer that question.
  22. Jan 14, 2021 at 6:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's one right next to the upper radiator hose where it connects to the water crossover pipe.
    Edit, found a picture. I know it's a Supercharged engine, but the location is the same although the water crossover pipes are slightly different.
    jmevis[QUOTED][OP] likes this.
  23. Jan 4, 2023 at 10:02 AM
    BlueNinja
    BlueNinja New Member
    Larry
    2014 Toyota Tundra CM 1794
    Hello @jmevis - What was the final diagnosis and outcome? I am experiencing exactly the same issue.
  24. Jan 4, 2023 at 10:17 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    OP hasnt been on in over a year, maybe truck exploded
    majbjb and Rocko9999 like this.
  25. Jan 4, 2023 at 5:57 PM
    Daganh62
    Daganh62 New Member
    2017 TRD Off Road
    The most likely cause is a thermostat issue. Thermostat may be going bad. You can take it out and put it in boiling water if it doesn't open its bad.
    You could like a previous poster said have an air bubble. If you do you can get rid of it by letting the truck get COMPLETELY COOL and removing the radiator cap. Next turn on your truck and let it run until it's at operating temp for minutes. Put your heat on full blast to make sure it doesnt overheat. Top it off if it needs it and put the cap back on. Any air bubbles should come to the top and pop so to speak.
  26. Sep 24, 2023 at 4:17 AM
    MLittle04
    MLittle04 New Member
    I actually drive a Toyota Highlander and I am also having this issue. My issue is only happening when I use the heat in my car and then I get a “leak” but it only seems to leak after I’ve used the heat. From what I am reading, I should have the thermostat checked?
  27. Dec 5, 2023 at 3:09 PM
    TxTundra
    TxTundra New Member
    2014 CM SR5 TX Edition
    I am experiencing this same issue. It happened twice today on a 30 minute drive home from work. Anyone else experience it and found a tried and true solution before I start to troubleshoot the issue?
  28. Feb 20, 2024 at 4:52 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    This just happened to me on the way to work. Anyone find a solution?
  29. Feb 20, 2024 at 5:16 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Once the engine is cool, check that the lower portion of your radiator cap didn’t break off. I see it happen to people a lot. It can get lodged in the cooling system and it restricts coolant flow. The radiator cap should be replaced from time to time as a maintenance item.
    huntertn likes this.
  30. Feb 20, 2024 at 5:21 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    This happened to my 08 where I was losing coolant due to suction bottom piece of my radiator cap broke off. Fortunately it never got lodged or ever intermittently showed signs of overheating. I ended up buying the red TRD radiator cap.
