P0717, C1201 help please
Discussion in '2nd Gen Tundras (2007-2013)' started by hank.forker, Oct 11, 2019.
  1. Oct 11, 2019 at 1:22 PM
    hank.forker
    hank.forker [OP] New Member
    NE Ohio
    2005 DC SR5
    Working on it...
    Hello everyone, I am the proud owner of a new to me 2008 Tundra 5.7l 4x4 with 145000. Sadly, it is throwing codes P0717 and C1201. It runs and drives great otherwise, but I am constantly alerted to this by the the
    -check engine (solid)
    -traction control (solid)
    -VSC OFF (blinking)
    -4LO (blinking)
    dash lights. I also noticed that it doesn't want to shift past 4th gear, as determined by feel and RPMs. If I switch to "sport mode" to upshift, the numbers change on the display but it does not seem to shift gears. Based on the interwebs, I have ordered a transmission input speed sensor, but can not seem to find an easy way to get to it to change it out. I think that it is on the top passenger side face of the bell housing housing but can't seem to actually get to it. Has anyone done this or have any advice on how to best get a look at the sensor and connection? I appreciate any help, thank you.
  2. Oct 11, 2019 at 1:31 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Oct 11, 2019 at 3:05 PM
    hank.forker
    NE Ohio
    2005 DC SR5
    Working on it...
    I appreciate the links, but I've already read them. What I'm hoping for really is for someone to tell me the best angle of approach, so to speak for the sensor itself. I have googled for hours and am at a loss.
  4. Oct 11, 2019 at 3:15 PM
    Mike Tread lightly.
    south carolina
    Try disconnect the battery for like 30 minutes and see if it comes back..
  5. Oct 11, 2019 at 3:28 PM
    hank.forker
    NE Ohio
    2005 DC SR5
    Working on it...
    Yeah, already tried a reset. Lights came back after about 5-10 miles of driving. Had no trouble getting 5th and 6th gear until I put it back into park, then same issue.
  6. Oct 20, 2019 at 5:50 PM
    hank.forker
    NE Ohio
    2005 DC SR5
    Working on it...
    Fixed. It was the turbine input speed sensor, which once found was incredibly easy and quick to replace. One 10mm bolt on the front passenger side of the transmission. Running perfectly now.
    14crwmaxltd, MTRock and Tundra Fan like this.
  7. Dec 28, 2019 at 6:16 PM
    Jscherm
    Jscherm New Member
    I have this same problem going on now. Any pictures of where the sensor is located?
    Thanks!!
  8. Jan 2, 2020 at 6:03 PM
    hank.forker
    NE Ohio
    2005 DC SR5
    Working on it...
    Sorry, just saw this. I'll try to get a picture this weekend if there's not too much snow.
  9. Jan 18, 2020 at 10:04 AM
    Jscherm
    Jscherm New Member
    Hey no problem at all! I still have the code popping up randomly. Don't even necessarily need a pic, just what the best way to get to the transmission is. Thanks!
  10. Jun 2, 2020 at 6:47 PM
    Brian2015SR5
    Brian2015SR5 New Member
    2015 Tundra SR5 4WD
    Leveled
    This just happened to my 15 Tundra, where is the sensor located? Everything a search ends up on a different vehicle.
  11. Feb 28, 2021 at 9:48 AM
    ccsilva73
    ccsilva73 New Member
    As far as this code.. Just popped up on my 2012 Tundra.. I have the extended warranty on the truck and take it in this week.. The only mod I have on it is a BAM 8inch exhaust system.. Is there a correlation between the change of exhaust and Turbine/Input Shaft speed sensor A Circuit (no signal)? I m hoping Toyota covers this claim.. Thanks in advance guys!
  12. Feb 28, 2021 at 9:53 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Hope you get it fixed.
  13. Feb 28, 2021 at 9:55 AM
    ccsilva73
    haha, thanks buddy.. If I can get it covered I can use that money to powder coat some rims...
  14. Jul 8, 2021 at 7:00 AM
    RedJugador24
    RedJugador24 New Member
    Can someone who has been able to locate this sensor please describe the location and/or post a pic? I'm in the same boat, have the part, just can't find the damn thing to replace it.
  15. Dec 1, 2021 at 12:46 PM
    S1n1ster1794
    S1n1ster1794 New Member
    Andrew
    2014 Black Tundra 1794 Crewmax
    6 inch Rough Country lift, 37 inch Toyo Open Country M/T wrapped in 20x12 American Truxx
    Can anybody tell me or refer me to a part number or something for the sensor? I keep getting different answers about which sensor it is... One says its a speed sensor for $25, another is $156. When I talked to the parts department at the dealer, they don't know what I'm talking about when I said turbine input shaft speed sensor. Getting really frustrated and just want to know exactly which sensor it is I need to buy. Any help would be greatly appreciated!!!
  16. Dec 1, 2021 at 12:51 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  17. Dec 2, 2021 at 7:20 AM
    RedJugador24
    Here's the part I bought (AISIN is Toyota's OEM supplier for this part) https://www.ebay.com/itm/284203219904
    The input (turbine) speed sensor is the one circled in Red, on the bottom of the torque converter on the front side, easier to get to from passenger side. 10mm bolt and a wire harness is all you have to remove. 2 minute job once you find it.
  18. Jan 8, 2022 at 5:56 PM
    S1n1ster1794
    Andrew
    Are they the same part, or are they 2 totally different sensors? Trying to fit a large hand in there isn't all that easy because of all the other stuff in the way.
    The reason I'm asking, I got the sensor and swapped it out but now I'm thinking it may have been the one circled in blue that I changed... I'll have to look at it again when I get home. The check engine light is back and traction control off are still coming on, every time I clear it. Thanks for your help
  19. May 31, 2023 at 8:47 AM
    Dirka dave
    Dirka dave New Member
    David
    2010 tundra Crewmax trd off-road
    Fox remote resi front. Total chos uca. 35” bfg.
    I’m dealing with this issue right now.
  20. Jan 18, 2024 at 5:01 PM
    haemotech
    haemotech New Member
    Simon
    RX 3
    I had the same code for me last night, followed by P1604.
    Went to the dealer Don Velley North Toyota, had to order the parts, 208 + tax.
    I found one in Amazon for 21.52. it will come next Tuesday. This afternoon I found it's easy to change it hope the bolt which will be easy to remove.
    After install I will clear the code to see it fixed or not.
  21. Jan 24, 2024 at 9:44 AM
    haemotech
    Simon
    RX 3
    The parts arrived on Monday, I tried to replace it today while I am off, on the wet snow floor, the place is extremely difficulty to reach there, and cannot see the bolt. I used the multimeter checked the parts resistens reading 465 Om and the new parts read 640.om. I give up to change it, I will see how it developed.
    Anyone had a good idea to replaced the parts ? I may try to use a bendable extension to for the next attempt.
  22. Jan 28, 2024 at 5:17 PM
    haemotech
    Simon
    RX 3
    I had applied some contact cleaner to it, the check engine light came back today, anyone had done this before I found is not easy to reach the 10mm bolt. Because I can not see it, only by feel. Anyone had this experience?
  23. Jan 29, 2024 at 1:25 PM
    haemotech
    Simon
    RX 3
    P0717 Code ! DO NOT BUY THE AMAZHON IN PUT SPEED SENSOR even it's cheap 21 Canadian dollars, END WITH THE WRONG PARTS CAN NOT BE INSTALLED! EVEN IT SAY IT FIT YOUR 2014 TUNDRA .Today in Toronto the weather is very good, I tried to installed the parts which is above the coolant pump ( I guess , I saw two black coolant hose goes there) , the job is not that hard if you don't have a huge hand. I used flexible head rachet 10'mm, and spend some time to clean the bolt, the job was not that hard to do, I use a long screw driver to take out the sensor (a little bite to the transmission body) I had check resistance read 667 om, looks good, compared with Amazon it read 670 om, but Amazon sensor the fastening is a straight line one ,it would not fit , the original Toyota had 45 degree. The hardness connector not long enough to reach there, if you want use this parts you had do cut the connector to extend the wire in this way you can connect, I did not do this way , because I love this truck, I reset the code and drive to Don Valley Toyota , the check engine light went on after 3 KM, I had paid 235.00 for the QEM parts had do wait above a week, I will update what happen after I stalled the new parts.
  24. Jan 29, 2024 at 4:42 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    The beck/arnley on Amazon is correct oem part (denso) and it’s about $40. It is the 90 degree orientation one, for the v8 tranny.
    edit: the Toyota version was on back order and nearly $200 a few weeks ago.
  25. Jan 29, 2024 at 5:33 PM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I had this same issue pop up a few months ago. Replaced with aisin sensor RST0071 (RST-007-1) from rock auto. Literally the easiest repair job I've ever done. Didn't have to take the skid plate off. It's not easy to see, you'll be doing a bit of the work by feel, but shove your phone up there to assist with spotting the part. Also keep in mind there's a small o-ring on the sensor and it took a bit of force to get out. Bolt was in great shape, backed out very easy even after 7 years of Illinois road salt exposure.
    baraynavab likes this.
  26. Jan 29, 2024 at 5:35 PM
    haemotech
    Simon
    RX 3
    Dalandshark: Great !Thank you I will check that.
  27. Jan 29, 2024 at 5:36 PM
    haemotech
    Simon
    RX 3
    Thank you Jaywhy.
  28. Jan 29, 2024 at 6:33 PM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I popped out to the garage to get some pics. See below. Once you locate it, it seemed easiest to get to by going after it almost blind. Under vehicle from passenger side, head just forward of the trans oil pan and you can get an arm up in there and do everything. The harness clip is a push down and pull off. 10mm bolt is on the top of the sensor.
  29. Jan 29, 2024 at 6:50 PM
    haemotech
    Simon
    RX 3
    Yes that is right, that is not a hard job, after I tried this afternoon it's a very Doable job . Thank you for the picture. After you send the picture is very easy for anyone new who looking for input sensor, not the output sensor. Last week I could not get much info as today. Now people with no difficult to locate this sensor just view from the picture you send. Very clear. Thank you for your help.
  30. Feb 5, 2024 at 3:19 PM
    haemotech
    Simon
    RX 3
    I had installed another sensor from Amazon, see the picture, clear the code driving for 3 days no problem no engine light on, traction control on ( stay OFF when had a faulty sensor ) the Parts from Don Valley Toyota have not arrived yet, it will take five week to order one!2014 Toyota Tundra  Speed sensor A.png
