P0722 code
Discussion in '2nd Gen Tundras (2007-2013)' started by Jennyfrmcntry, Mar 29, 2022.
  1. Mar 29, 2022 at 10:17 AM
    Jennyfrmcntry
    Jennyfrmcntry [OP] New Member
    Jen
    NY
    2012 tundra
    Tundra throwing P0722 code output speed sensor. I saw some threads on it but new to group and can't seem to get back to that particular one. Toyota dealer telling me I need to replace 2 sensors I'm going with probably input and the output sensor but I've only gotten codes for output sensor. Is it common to replace both? OEM is 145$ each I've used rock auto before for parts is it better to use OEM or can I purchase away from Toyota dealership. It has been throwing 4low light, check engine, traction control off and one other light when it does this sparatically. Ive noticed its shifting is off when it throws code. I know sensor is on bottom of transmission on passenger side. I have some mechanical skills not pro by any means but looking for suggestions on whether I should go OEM and do both sensors that Toyota suggested. Thanks
    Jen
  2. Mar 29, 2022 at 11:06 AM
    2mchfun
    Welcome to the forum from OKC! No experience here with this particular code or sensor. However, others will chime in, just hang tight. You might also go to the "ask the Toyota Mechanic" thread and inquire there for a better explanation.
  3. Mar 29, 2022 at 11:37 AM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    I'd recommend going with the OEM Parts. They are the reason why Toyota's have such great reliability.
  4. Mar 29, 2022 at 12:20 PM
    Jennyfrmcntry
    Jen
    NY
    2012 tundra
    I know the OEM is better to spend the extra because of longevity and quality. I was just on the fence when the parts guy said I'd need both sensors. I'm definitely not easy on my truck either. I'm at 155k and use it for everything from hauling tractor, cross country trips, getting it axle deep in mud and snow. Salt corrosion is pretty awful up here in the southern Tundra as I refer to it. I'm replacing rotors and brakes every spring because if corrosion. From last post to this one lights have gone off. But will randomly come back so just trying to get ahead of them going completely.
    Thanks
    2mchfun likes this.
  5. Mar 30, 2022 at 7:40 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would just replace the one output sensor and definitely use a Toyota part (if you're on a tight budget, consider getting a used part). You can always replace the input sensor later if you absolutely have to.
  6. Mar 30, 2022 at 7:59 AM
    Jennyfrmcntry
    Jen
    NY
    2012 tundra
    Thanks,
    The money isn't the issue if I only do the output sensor. I know they always try to give you more then you need. I just wanted opinions on whether to do both.
  7. Mar 4, 2025 at 6:00 AM
    Jkotch1
    Jkotch1 New Member
    Josh
    2013 Toyota tundra rock warrior
    What did you end up doing? I have the same problem, I replaced both sensors and still having issues, I am now thinking its the wiring harness.
