P2440 Secondary Air Injection Valve Bank 1 "stuck open"
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14tundy4.6, Dec 30, 2020.
New Check Valve? Or Bypass?
  1. Check Valve -
    0 vote(s)
    0.0%
  2. Bypass kit
    100.0%
Multiple votes are allowed.
  1. Dec 30, 2020 at 9:36 AM
    14tundy4.6
    14tundy4.6 [OP] New Member
    My 105K miles 2014 4.6L Tundra check engine/Trac control off came on. Limp mode officially activated :(
    Plugged in the code reader and it gave me the P2440. I did research on the valves and even ordered the new one. However, I took the one apart and I didnt really find the clogged mess everyone seems to experience. Slight moisture was found inside. Does This mean I need the Bypass kit instead? I hear they are plug n play as well. Replies are hugely appreciated if you know any info. Im a college student so I really would love to save some money and fix it myself. Also, is it terrible for the car to be driving it now? I gotta get to werk somehow
    Thanks for reading.
  2. Dec 30, 2020 at 10:21 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    FWIW
    I did the Hewitt Tech bypass, strictly on a preventative basis.
    I've had no issues with the truck since the install, but I wasn't having any before the install either.
    Technically, it is plug and play, but I couldn't believe how difficult the unplugging part was. It literally took me hours to do and I even managed to bruise my ribs crawling up and over top of the engine to get back to the plugs.
    Hardpain likes this.
