P2715 and P0761
Discussion in '2nd Gen Tundras (2007-2013)' started by Jhernandez370, Dec 1, 2021.
  1. Dec 1, 2021 at 2:25 PM
    Jhernandez370
    Jhernandez370 [OP] New Member
    Jean
    Tundra 2008 5.7
    What that means?
    I think one is the SLT SOLENOID AND THE OTHER?
    P2714 and P0761
  2. Dec 1, 2021 at 2:48 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Sounds like you have a trans problem. Making this comment to help bump your thread. Good luck.
  3. Dec 1, 2021 at 3:17 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    How many miles are on your truck? Has the trans ever been serviced?
  4. Dec 2, 2021 at 4:54 AM
    Jhernandez370
    Jean
    Tundra 2008 5.7
    I get that 2 year back and never I think check but last week I change filter and oil transmission and running well now after that when accelerating fast keep slow and shaking that code in the internet tell me is the pressure solenoid sensor bad ,but will wait for Toyota call me to pick up and install
  5. Dec 2, 2021 at 8:38 AM
    audiowize
    Paul B.
    A Toyota dealership is going to charge you to replace your transmission. They are very, very unlikely to do any kind of internal work on the transmission itself.
  6. Dec 3, 2021 at 3:02 PM
    Trust86
    Trust86 New Member
    2007 DC
    I would double check your trans fluid level and make sure filter is seated correctly since you said you changed fluid and filter. There is a specific way to check fluid level, make sure you follow the procedure. It can be done with just a paper clip. You don’t need tech stream.
