P2716 CEL
Discussion in '2.5 Gen Tundras (2014-2021)' started by lunchbox, Sep 28, 2019.
  1. Sep 28, 2019 at 9:24 PM
    lunchbox
    lunchbox [OP] Im lost
    Ryan
    Killeen
    2018 TURD 4x4
    "Stock"
    First i had two malfunctions and a CEL: Drive start control malfunction and something about towing malfunction. Turned off the truck and turned it back on and just had the CEL which was a P2716. Pressure Control Solenoid D Electrical.
    Anyone have this problem before? Anything i can do myself to check before taking it to a dealer on monday?
  2. Sep 28, 2019 at 9:37 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Hi that’s a code for the shift solenoid in the transmission called the SLT theirs way to diagnose it but it’s not that easy you need a multimeter to check resistance I can give you all the info you need but if your vehicle is under warranty I wouldn’t touch it cause you might have to remove transmission pan to diagnose it.
  3. Sep 28, 2019 at 9:43 PM
    lunchbox
    Ryan
    Killeen
    2018 TURD 4x4
    "Stock"
    hm okay if thats the case ill let toyota touch it then. I am still under warrantly, only 20k miles.
  4. Sep 28, 2019 at 9:46 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Yea man good idea cause they will possibly have to get into the valvebody to check the SLT solenoid that means dropping the pan which filling the trans with fluid is pain in the ass cause we have no dipstick. Or the other problem can be failed wiring from pcm to transmission or a pcm reflash so it gets a little complicated
