P2757 FIXED
Discussion in '2nd Gen Tundras (2007-2013)' started by Tacticaldeath, Jan 31, 2020.
  1. Jan 31, 2020 at 2:06 PM
    Tacticaldeath
    Tacticaldeath [OP] New Member
    New Hampshire
    2007 Tundra double cab Limited TRD Offroad 5.7
    Factory recall frame, body mounts, coil springs, upper and lower control arms,leaf springs, shackles, gas lines, brake lines, y-pipe and muffler replaced in 2019. TORQ 3"/1.5" lift, Westin winch mount w/bull bar, LP8500 Superwinch, N-Fab wheel to wheel nerf bars with bed access step, 35X11.50 (285/75R18) Falken Wildpeak AT3, Tuffy Security long gun box under rear seat, Diamond Back tonneau cover w/cab guard and tool box, Pop-n-Lock tailgate.
    This issue was finally fixed. The transmission shop had diagnosed that the torque converter had excessive slipping at the lower rpm ranges. They do have very sophisticated diagnostic equipment. The dealer first decided to R&R the TC. Hoping it was the cause of the slipping. It was certainly a worn component, but the lights and same code returned. The transmission shop ran all the tests again and determined that the values inside the valve body were changed, but there were still faults with internal pressures. It was the valve body that was worn out. They replaced the valve body along with all the solenoids. (FYI, the solenoid indicated by the code was checked first before any other work was done) Lights out! I hope this can help someone. The parts and labor for the valve body was $1600.00, covered by the dealership. Also, I found this during my research. It is very interesting. https://www.sonnax.com/tech_resourc...aults-in-a761-ab60-a960-6-speed-transmissions
    Rex Kramer likes this.
