Paint code for color match
Discussion in '2.5 Gen Tundras (2014-2021)' started by ardnutoz, Apr 8, 2018.
  1. Apr 8, 2018 at 1:58 PM
    ardnutoz
    ardnutoz [OP]
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    My 2018 CM is the Midnight Black Metallic the window sticker shows an LA20 code right behind the paint nomenclature. Do you guys know if this is correct? As i look at color matching the usual parts i see that this color is not listed. Just making sure im not missing something.
  2. Apr 8, 2018 at 2:31 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Should be a 3 digit paint code. As far as I'm aware, there is no "Magnetic Black Metallic"
  3. Apr 8, 2018 at 2:32 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    On the inside drivers door or inside door frame there will be your sticker with the GVWR and dates if manufacturing stuff.
    Somewhere towards the bottom there should be a color/trim with the paint code next to it.
    I do not know the magnetic black color codes though so sorry I can’t help you there!
  4. Apr 8, 2018 at 2:42 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Attitude/Midnight Black Metallic paint code is 218
    Regular Black is paint code 202
    Hope it helps
  5. Apr 8, 2018 at 2:45 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    I had this problem with my 4Runner metallic paint. It is a 2 step paint if you are looking to do some touch ups. You will get the black and you will get a mid coat with the flak. Don’t know your color code but hope this helps
  6. Apr 8, 2018 at 4:15 PM
    ardnutoz
    ardnutoz [OP]
    OZ
    SE-PA
    correted magnetic to midnight.. dont know what the heck i was writing
  7. Apr 8, 2018 at 4:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think Midnight is 202 and Attitude is 218
  8. Apr 8, 2018 at 4:37 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Yes attitude is 218
  9. Apr 8, 2018 at 4:38 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Attitude Black and Midnight Black are essentially the same color of black with a blue metallic flake. They changed the name I believe 2016. The 202 paint code is the black without metallic flake.
    619Tundra likes this.
  10. Apr 8, 2018 at 5:33 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    My truck is Midnight Black Metallic (blue flakes) and the paint code is 218.
    Beesta likes this.
  11. Apr 8, 2018 at 7:05 PM
    ardnutoz
    ardnutoz [OP]
    OZ
    SE-PA
    Thanks everybody. I can start ordering my color matched parts.
