Paint matching trim pieces
Discussion in '2.5 Gen Tundras (2014-2021)' started by DigbyPotter, Aug 27, 2019.
  1. Aug 27, 2019 at 5:47 PM
    DigbyPotter
    DigbyPotter [OP] New Member
    Denham Springs, LA
    MGM 2019 SR5 CM TSS Black 4.6L 4x2
    Has anyone successfully paint matched the dark silver trim piece that is above the glove box? I want to paint or plastidip the interior chrome and light silver pieces to match it.
    Mountun Goat and Rustyscrew like this.
  2. Aug 27, 2019 at 5:52 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Is it the same as a Platinum? If so I will try to find something tomorrow.
    YsoSeRiouS! likes this.
  3. Aug 27, 2019 at 6:22 PM
    DigbyPotter
    Denham Springs, LA
    Thanks! It looks like it is the same.
  4. Aug 27, 2019 at 6:33 PM
    TS18
    TS18 Northern CO
    2018 sport
    Subd
  5. Aug 27, 2019 at 7:20 PM
    SUMMIT
    SUMMIT New Member
    2024 Tundra Platinum MGM
    I want to know the same thing. I want to get all of the dash trim pieces in that darker silver/gray. As well as the shift knob trim and cup holder trim.
  6. Aug 27, 2019 at 7:42 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I’ve asked this question before and someone replied that the color was anthracite
    DigbyPotter[OP] likes this.
  7. Aug 28, 2019 at 5:28 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Tufskinz is slowing coming out with more trim pieces for the tundra if you’d rather not paint your interior. They don’t have covers for the anthracite trim pieces yet tho. You might be better off vinyl wrapping them yourself too. They do have some things for the shifter area I believe.
  8. Aug 28, 2019 at 5:58 AM
    Omohundro
    Jody
    McMinnville TN
    I don’t really have anything to compare to, my Platinum is some sort of hydro dip or wrap. But I did find a nice grey in a BMW color. A52 Space Grey Met
    If you go anywhere that sales paint ask to see the color variance deck on A52 and pick witch ever one suits you.
    E0810C09-FE26-423E-B682-CA76025A7039.jpg 6B6B4A89-98FA-4959-AAF0-1652581D63A9.jpg 40394378-E7BB-4C66-9B14-CC2F43B681FB.jpg
  9. Aug 28, 2019 at 6:11 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  10. Aug 28, 2019 at 6:18 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I used a wrap that is pretty close. I will have to go look for the color code. The sample shown below looks a little different due to the way it reflects the light on the curved sample, but it is actually even closer than it looks in the picture.
    Edit: Found the code. 3M 1080 Matte Charcoal
    GAknight, Sas and DigbyPotter[OP] like this.
  11. Aug 28, 2019 at 6:28 AM
    DigbyPotter
    Denham Springs, LA
    Thanks everyone!
  12. Aug 28, 2019 at 8:54 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’ve really wanted to do the same. Especially so my towers will match and I think it would look so much better. It’s almost like a dark brushed aluminum or something like that. May try that wrap
  13. Aug 28, 2019 at 10:24 AM
    DigbyPotter
    Denham Springs, LA
    I asked a friend of mine who owns a graphics shop that does vehicle wraps for some advice on how to wrap such an intricate piece.
    Just in case it helps anyone:
    Clean the piece really really well with 91% isopropyl alcohol.
    Use adhesive promoter. Primer 94 is what we use. It’s a 3M product.
    After you lay the vinyl down and get it stuck, post heat is very important. You want to warm the vinyl up to nearly 200°. A hair dryer will not get hot enough. A heat gun should work fine.
    Avoid over stretching the vinyl as you smooth it out.
    Cheers
    DP
  14. Aug 28, 2019 at 10:46 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    You can buy the side stereo trim in black from Toyota. I’m debating it but heard it’s a pain to remove them
  15. Aug 28, 2019 at 1:36 PM
    SUMMIT
    SUMMIT New Member
    I don't think it's a pain to remove them as much as it is time consuming. Just need to figure out if the end result is worth the time spent.
  16. Aug 28, 2019 at 9:09 PM
    Viliamu808
    Viliamu808 New Member
    I'm thinking of ordering from carid..they can color match to your vehicle..b&i dash...kinda pricey and I never ordered from them yet..but I might order the dash..that chrome blinds me a lot..
  17. Aug 28, 2019 at 9:49 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Get some vinyl. Easiest way to change the color and, if you do ever decide you don't like it, it's an easy fix.
    Check out the guys at Metrorestyling. Great group that are super knowlesgeable.
    I personally like Oracal brand.
  18. Aug 28, 2019 at 10:23 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I think I’m going to get my stuff dipped!
