Painting Brake Calipers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Sep 14, 2019.
What color caliper paint? Or don't even bother
Poll closed Apr 14, 2020.
  1. Red
    17 vote(s)
    42.5%
  2. Blue
    3 vote(s)
    7.5%
  3. Black
    14 vote(s)
    35.0%
  4. Don't bother
    6 vote(s)
    15.0%
  1. Sep 14, 2019 at 5:26 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I am thinking of painting my brake calipers during my next tire rotation. Anyone do this yet using brush on POR15 caliper paint?
    I don't want to remove them from the truck so I was thinking brush in paint would be best. I have had good experiences with other POR15 paints. The paint is only $13 and I will obviously clean and prep them well first.
    Also what color? Red to match TRD sport suspension and sway bar? Blue to kind of match truck? Or black because it's not flashy?
  2. Sep 14, 2019 at 5:29 PM
    Just did mine today
  3. Sep 14, 2019 at 5:30 PM
    Pudge
    CT
    Thanks man. Go figure as soon as I posted my thread I saw yours pop up. They look great!
  4. Sep 14, 2019 at 5:32 PM
    I saw your post right after I made mine. This kit was $22.00 at AutoZone and is brush on. It will take a couple of coats but that can has plenty.
  5. Sep 14, 2019 at 5:59 PM
    19TuRDSport
    19TuRDSport New Member
    Michigan
    2019 MGM Tundra SR5 TRD Sport Crew Max
    Red looks good To match trd components but kinda bringing attention to stock brakes that arent worth showing off imo. Silver looks clean too and doesnt look like youre showing off stock brakes
    BravoDeltaRomeo and Pudge[OP] like this.
  6. Sep 14, 2019 at 6:06 PM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    I like the red. I’ll be doing this once I get some new rims and move on from the stock 1794 rims.
    Inexpensive mods like this are a lot easier on the wallet.
  7. Sep 19, 2019 at 7:15 PM
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    Anyone ever mod their stock calipers to a smooth finish?
  8. Sep 19, 2019 at 7:30 PM
    Waterboy45661
    Waterboy45661 New Member
    Tommy
    07 Red SR5
    Has anyone ever used the Rust-Oleum spray caliper paint? I just ordered some today.
  9. Sep 19, 2019 at 7:33 PM
    Pudge
    CT
    I'm considering just leaving them alone. I think they look great red, but I do only have the stock calipers so maybe its not qoegg drawing the attention plus I'm not a flashy guy and feel this is too much bling. I already have the red sway bar, and am getting red trd sport shocks all around so maybe the calipers will be too much red. I may eventually do them, but maybe just black. We'll see.
  10. Sep 21, 2019 at 7:35 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    Mine are powder coated from the vendor. They set me back about $55 per corner.fullsizeoutput_1bc5.jpg
    RitcheyRch likes this.
  11. Sep 21, 2019 at 9:45 AM
    Waterboy45661
    Tommy
    07 Red SR5
    Just did one of the front ones and one of the back on the passenger side.B3CCCB87-9011-439E-BA38-DE76EBCF61B4.jpg363E9816-F0DC-4CBA-A1C3-169FFD197C38.jpg
    Pudge[OP] likes this.
  12. Sep 21, 2019 at 10:14 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You could always paint them black.
    Pudge[QUOTED][OP] likes this.
  13. Sep 21, 2019 at 1:01 PM
    AZTundra
    Paul
    Phoenix, AZ
    Do the brake parts not need to be disassembled for the painting process?
  14. Sep 21, 2019 at 1:10 PM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    I disassembled mine and taped off bleeder valve and pistons. I used duplicolor red ceramic rattle cans and finished with same in clear coat. Pretty easy. Since I was replacing rotors and pads I figured it was the best time to finally get 'em done.20190921_095153.jpg
    AZTundra[QUOTED] likes this.
  15. Sep 21, 2019 at 1:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Looks good. I'm debating doing mine, but I won't plan that until it's time to do the brakes.
  16. Sep 21, 2019 at 1:45 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I did mine with the brush on paint. Looks good two years later. That small paint can is enough to do the tundra ( all four corners), outer rim of rotors for a Porsche Boxster, and all four calipers for same Porsche. Still have about a half can left. Pick up some small acid brushes at harbor freight ( 4.99 for 36 brushes).
  17. Sep 21, 2019 at 2:00 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I just did mine too.
    I used VHT high temp caliper paint (spray). Do yourself a big favor and disassemble the brakes for a cleaner, easier, and ultimately professional type job. I did the BBK on the front so I only had to paint the rears. There are two 17mm bolts and two 19mm bolts. They come off and on really easy and allow you to paint with minimal masking. Hardest part was wire brushing the stupid CT rust and gook off to get a clean surface. I did TRD rear pads so I felt "OK" about putting the TRD label on it, lol!
    Before
    In-between
    After
    And the BBK fronts...
    Good luck!
  18. Sep 21, 2019 at 2:09 PM
    IMO, I would have taken the pads and clips off before painting. I didn't spray mine. I used the Duplicolor brush on kit so there was no need for clearcoat.
  19. Sep 21, 2019 at 2:28 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Red looks too type R to me, I went black powder coated from Power Stopbrake1.jpgbrake2.jpg
    Prostar 190 likes this.
  20. Sep 21, 2019 at 2:52 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Either black or grey. Unless they are 6-8 piston aftermarket calipers, it’s cheesy to paint them red or blue or yellow, etc to make them stand out. That’s just my opinion.
  21. Sep 21, 2019 at 2:57 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I want a polished aluminum look. Sorta shiny like chrome:D
    Pudge[OP] and Prostar 190 like this.
  22. Sep 21, 2019 at 4:52 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I would do silver or black, I’m not a fan of red calipers anymore.
    Danman34 likes this.
  23. Sep 21, 2019 at 5:32 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Dealership told me not to paint them myself. Said Toyota has denied brake claims stating the paint caused the issue. I guess make sure you cover all parts not to be painted.
  24. Sep 21, 2019 at 6:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Made me think of this:
  25. Sep 21, 2019 at 6:10 PM
    Looks good!
    I used VHT also.
    [​IMG] [​IMG]
    It has held up really well.
  26. Sep 21, 2019 at 6:26 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Very nice!
    We have the same Jack too...!!!
  27. Sep 21, 2019 at 6:27 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
  28. Sep 21, 2019 at 6:38 PM
    :thumbsup:
    Toyotoholic[QUOTED] likes this.
  29. Sep 21, 2019 at 7:25 PM
    Pudge
    CT
    I'm thinking black or gray, I'll see what colors the POR15 kits come in. I know that its under $15 for their brush on paint. I'd like to do the hub/rotar flat spot where the wheels bolt up, to maybe keep those surfaces from rusting together. I put grease in there but they still seize up something fierce and it's a battle kicking and kicking to get the tire off for a rotation
    Oh what wheels are those? They look sweet but I don't think I've seen them before, maybe its just the way the picture is though.
  30. Sep 21, 2019 at 7:29 PM
    Pudge
    CT
    Bryan, your frame and entire undercarriage is so freaking clean and shiny. I have to figure you spent a lot of time prepping and painting under there. Outstanding work!
