Parking Sensor Problem?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Feb 19, 2025.
  1. Feb 19, 2025 at 4:35 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I’ve got a bit of a mystery on my hands. My parking sensor on the passenger side front keeps going off and beeping like a crazy person. I’ve tried turning the Parking sensor button on and off, and sometimes that works, but other times I have to leave it off for a while and then turn it back on. Is this something that’s easy to fix? Can I replace the sensor myself?
  2. Feb 19, 2025 at 6:43 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You don't have any snow/ice or debris covering it do you?
    Mdnitedrftr likes this.
  3. Feb 19, 2025 at 6:50 AM
    rodl12
    Rod
    South Jersey
    No! I actually cleaned it with alcohol to make sure it was clean.
    Jaypown[QUOTED] likes this.
  4. Feb 19, 2025 at 7:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Water can get in them and cause issues and alerts. Sometimes It may take a day or two of dry weather to clear.
    Or it could be a bad sensor, nick in wire or the sensor connector is dirty.
  5. Feb 19, 2025 at 7:10 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Good point on connector. As a free troubleshooting step, look for any nicks and reseat the connector.
  6. Feb 19, 2025 at 1:32 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    I'm not 100% on this, but on the Creader Elite bi-directional scanner I just got for my FlexFuel truck (which worked like a charm) I believe I recall seeing an option for adjusting the sensitivity of the parking sensors.
  7. Feb 19, 2025 at 3:34 PM
    rodl12
    Rod
    South Jersey
    I’ve been trying to figure this out for a while now, and I’ve searched everywhere but haven’t found a solution. I thought I’d ask you all here if you have any ideas.
  8. Feb 19, 2025 at 3:36 PM
    rodl12
    Rod
    South Jersey
    I'll give that a try. I really surprised no one else has had a problem like this.
  9. Mar 15, 2025 at 12:53 PM
    chance03
    chance03 New Member
    I have the same problem but it says 3 of the 4 sensors are bad.... how is that possible
  10. Mar 15, 2025 at 1:29 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Unfortunately there is no communication available for the parking sensors. Makes it a pain to diagnose. I always kept a known good sensor to swap out to figure out which one was causing the issue.
  11. Mar 16, 2025 at 3:19 AM
    rodl12
    Rod
    South Jersey
    I shared this on a thread I started after this one. After I posted it, I stumbled on a fix and discovered a fix for my sensor sensor and now it's working perfectly. Here’s the edit I made to that post.
    EDIT: I wanted to share a quick fix I found for my faulty Parking Assist Sensor. I had been searching for a solution for a while, and I stumbled upon two YouTube videos that suggested using WD40 to fix the issue. The sensor would come on and then not go off. In both videos, they recommended spraying WD40 into the gap between the sensor and the part that holds it onto the bumper. To my surprise, it worked! The sensor has been functioning perfectly ever since. I’m guessing that maybe some water had gotten in between the sensor and the part, causing the sonar to malfunction. By using WD40, which displaces water, I was able to resolve the problem. I hope this helps someone else who’s been struggling with the same issue. It was quite frustrating to find a solution, but I’m glad I did!
  12. Mar 24, 2025 at 2:40 PM
    chance03
    chance03 New Member
    Wow the wd40 trick worked!!!! All the sensors are functioning thank you so much for the tip!
    Ruggybuggy likes this.
  13. Mar 24, 2025 at 3:28 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Trying to get my head around this. So you sprayed WD40 on the back of the sensor or spayed the sensor from the front?
  14. Mar 24, 2025 at 3:29 PM
    chance03
    chance03 New Member
    I sprayed inside the connectors after I unplugged them. Used one of those keyboard air canisters to dry them out and plugged them back in.
  15. Mar 25, 2025 at 3:10 AM
    rodl12
    Rod
    South Jersey
    Glad I could help! Amazing how easy a fix this is. Mine has been fixed for over a month now without a problem. I can't believe nobody here or in other places didn't know this. I did so much searching about fixing and replacing these sensors and found two seemingly obscure videos, one which was in the UK on using WD40 for this fix. I guess this is just another application for using WD40 we can add to the list.
  16. Mar 25, 2025 at 3:14 AM
    rodl12
    Rod
    South Jersey
    You have your sensor that fits into a sleeve that snaps and holds onto the bumper. You spray the WD40 in between the sleeve and the sensor. My guess it that there is some moisture or water in there that interfers with the sonar of the sensor and the WD40/WD=Water Displacement removes it and problem fixed.
    Ruggybuggy[QUOTED] likes this.
  17. Mar 25, 2025 at 5:27 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So you didn’t remove your connector and spray WD40 onto the terminals? Did you spray from the front on the back of the sensor? Chance03 said he removed the connector and spayed into the sensors onto the terminals.
  18. Mar 25, 2025 at 6:36 AM
    rodl12
    Rod
    South Jersey
    All I did was spray in between the the sensor and the sleeve. That's all the videos showed that I found. There is no need to spray or take apart just KISS.
