PASSENGER Front seat cushion shield
Discussion in '3rd Gen Tundras (2022+)' started by jb trd, Feb 17, 2025.
  1. Feb 17, 2025 at 5:17 PM
    jb trd
    jb trd [OP] New Member
    22 Tundra CrewMax Limited 6.5
    Can anyone help me select the right part number for this or point me in the right direction?
    The PASSENGER Front seat cushion shield that houses your power seat buttons, passenger side.
    Edit: To fast forward to the end, the correct part number has changed and is
    71811-0C182-C0
    Mines a 2022 Crew Max limited. Power seat with lumbar. I had a part in Sparks Toyota cart that they said matches my truck but on the parts diagram it shows a hole like if you have manual recline. I was about to buy it anyway because I put in my vin but on the last checkout page it wanted me to be responsible for any part that didn't fit my truck and I don't feel like eating $75 just in case it's wrong. Interior is in black. Any help appreciated. Thanks in advance.
  2. Mar 24, 2025 at 11:50 AM
    jb trd
    So.
    Sparks Toyota looked it up by VIN and sent me 71811-OC192-CO
    It works but its slightly different . The hole where the lumbar goes thru is slight larger and the retaining spot for one of the screws doesn’t line up.
    The original part on the old shield is 71811-OC180
    Picture attached. New one partially installed.
    Any thoughts?
  3. Mar 24, 2025 at 12:05 PM
    DRP
    DRP Old Member
    Dave
    Send it back and get the correct one?
  4. Mar 24, 2025 at 2:19 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    why didn't you order 71811-OC180?
  5. Mar 24, 2025 at 2:24 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Mar 24, 2025 at 2:32 PM
    jb trd
    Hoping it was an updated stronger part since he checked by vin
    1lowlife likes this.
  7. Mar 31, 2025 at 4:35 PM
    jb trd
    Ok. Third time the charm. The correct part number has changed. The correct part is
    71811-0C182-C0
    One of the mounting clips looks slightly different. See pic. My original clip sheared off which makes it hard to discern but there is definitely a small change there. Will it help with this design defect? Only time will tell I guess.
    Btw. Make sure all three clips are installed in their correct location. It’s tricky to see but if you raise the seat all the way you can confirm fitment with a flashlight.
    Finally if yours have a hairline crack but haven’t ‘failed’ you may consider placing some tape or something over the crack in the meantime to protect the leather seat cover. The plastic is sharper than it appears.
