Passenger side rear wheel sticks out much further than driver's side
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chuck1188, Oct 19, 2018.
  1. Oct 19, 2018 at 6:13 PM
    Chuck1188
    Chuck1188 [OP] New Member
    Charles
    2016 TUNDRA BLACK SR5 CM 4WD
    So my passenger side rear wheel sticks out much further than my drivers side rear wheel.
    Is this normal? Is my rear axle out of whack?
  2. Oct 19, 2018 at 6:14 PM
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Ny first gen does the same thing!! The driver side sticks out almost a whole half inch more than the pass side , mine is older, though
  3. Oct 19, 2018 at 6:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've seen threads on this. A few people have loosened their beds and adjusted it that way. Before you do that you might wanna look at whether or not the wheels are centered in the wheel well or just check your most recent alignment numbers to be sure the axle is somewhat straight.
    Otaku4life69, joonbug and Matty4wd like this.
  4. Oct 19, 2018 at 6:51 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    I've had a 2017 and now a 2019. They are both offset a bit to the passenger side. I try not to worry about it too much.
    ATV25 likes this.
  5. Oct 19, 2018 at 7:01 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
  6. Oct 19, 2018 at 7:03 PM
    Chuck1188
    Charles
    I tried the search function to no avail.
    Maybe someone could link another thread
  7. Oct 19, 2018 at 7:32 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    Had no idea. I'm not going to look. In fact, I'm going to pretend I never saw this thread.
    GODZILLA, Luckydog, Ostrich and 13 others like this.
  8. Oct 19, 2018 at 7:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. It’s circle track racing inspired.
  9. Oct 19, 2018 at 11:39 PM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    Same. 18 CM TRD SR5. I think they’re all like that. Pisses me off but I try not to think about it
  10. Oct 19, 2018 at 11:41 PM
    trdprobped17
    trdprobped17 New Member
    I believe that it totally depends on your wheels and tires sizes. Stock wheels and tires do not stick out.
  11. Oct 20, 2018 at 12:34 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What rims do you have?
  12. Oct 20, 2018 at 6:30 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Yeah but what about left turns?
    OMG, I noticed this the other week, intended to get dealer to do 4 wheel alignment.
    Y'all say this is normal?
    joonbug[QUOTED] likes this.
  13. Oct 20, 2018 at 7:48 AM
    Bonz did it
    Bonz did it New Member
    Just close one eye and squint with the other. Ive actually gone to the dealership and measured brand new ones , only to find that they actually vary . Tire sizes only hide or make the problem more noticeable. Moving the bed will just make it misaligned with the cab, so take your pick. But yes its common
    Chuck1188[OP] and TunderStorm like this.
  14. Oct 20, 2018 at 7:52 AM
    TunderStorm
    Michael
    Right but that’s just because they’re so tucked in the fender wells. So you can’t notice it most likely. Mine sticks out about a full 1” further. Not thrilled but not much I can do. Thought about maybe running a spacer on the drivers side to Even it out.
    trdprobped17[QUOTED] likes this.
  15. Oct 20, 2018 at 8:16 AM
    Chuck1188
    Charles
    TSS black 20” with I think 275 K02
  16. Oct 20, 2018 at 8:30 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, it’s normal. My bed is off center, in the other direction, and my passenger wheel still sticks out further. If I fix my bed, it’ll get even worse.
  17. Oct 20, 2018 at 8:44 AM
    Part_time
    Oregon
    I heard after the 16 model they fixed that problem
  18. Oct 20, 2018 at 8:58 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Nope, mine is a '18, just over 3k miles.
    TunderStorm likes this.
  19. Oct 20, 2018 at 9:02 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    My 2018 Crewmax is also like this. So were both the 2014 and 2012 F-150s I had prior to my Tundra. I guess I just assumed there was a reason for it.
  20. Oct 20, 2018 at 9:03 AM
    Mr Badwrench
    Mr Badwrench New Member
    Now that you guys have called this to my attention, I am going to look at mine, and even if it is perfectly centered, I will think it isn't and it will bug the hell out of me until I sell the truck.
    Thanks a lot guys...
    Ostrich, JohnLakeman, Vhob99 and 3 others like this.
  21. Oct 20, 2018 at 9:32 AM
    Chuck1188
    Charles
    Haha it bothered me at first, then didn’t worry about it, then thought I should ask just in case. It will still be in the back of my mind
    Mr Badwrench[QUOTED] likes this.
  22. Oct 20, 2018 at 9:40 AM
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    I had a 2017 Tacoma that did the same with OEM set up and my 2018 Tundra does the same with oem set up. I was thinking it could possibly be a result of taco lean however not sure. The way I notice it most i get dirt caught up on the passenger side rear fender in a way that doesn't occur on the driver side,and of course the wheel is flush on the passenger side where the driver side is tucked in just barely. Same guy must have finished both of my trucks. Beds alignment is just slightly off.
  23. Oct 20, 2018 at 12:22 PM
    trdprobped17
    Have you taken it to the dealership? If there is a defect, they should be able to let you know and also fix it. Hope that you’ll be able to get it resolved quickly.
  24. Oct 20, 2018 at 12:23 PM
    Mr Badwrench
    Mine is very slightly to the passenger's side. It isn't perfect, but I guess it won't keep me up at night haha.
  25. Oct 20, 2018 at 12:59 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I’m gonna pretend this thread didn’t happen, and not even check my truck
  26. Oct 20, 2018 at 1:01 PM
    TunderStorm
    Michael
    Seems like they’re all like this. Doubt they can do anything
  27. Oct 20, 2018 at 3:51 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Noticed this on mine the day I was looking at it to purchase, passenger side rear sticks slightly further out. Didn’t think much about it since I looked at other tundras on the lot and all of them where like this, some more than others. Just figured it was normal..
    trdprobped17 and Mr Badwrench like this.
  28. Oct 20, 2018 at 4:57 PM
    trdprobped17
    It must be an intentional design by Toyota. I am 100% positive that Toyota would have a manufacturing defect as obvious as this and not do anything about it. My Tundra runs perfectly well and I don’t see anything different with the wheels being off.
  29. Oct 20, 2018 at 4:59 PM
    TunderStorm
    Michael
    You’re 100% positive huh? That they would have a defect like this and not do anything about it? I agree
  30. Oct 20, 2018 at 5:02 PM
    Mr Badwrench
    I checked body-fitment and everything when I bought mine. I checked the door gaps, alignment of the bed with the cab I could tell the salesman was getting irritated since it was close to closing time, but hey, that's his job. I guess nothing is perfect. Even a Bently won't get 200,000 miles without tens of thousands of dollars in preventative maintenance.
