Passenger window won’t roll up
Discussion in '1st Gen Tundras (2000-2006)' started by jggeere, Mar 4, 2021.
  1. Mar 4, 2021 at 8:26 PM
    jggeere
    jggeere [OP] New Member
    jared
    2002 toyota tundra 4.7 4x4
    I know these tundras are notorious for failing power windows. But how do you fix them? My passenger side window won’t roll up but it will roll down, motor is fine, I disconnected the passenger window for now but would like to go back and fix it. Anyone else have the same issue and resolved it? Thanks in advance.
    2002 Toyota Tundra Ext cab
  2. Mar 4, 2021 at 8:51 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I didn't know about this being a huge issue with our Tundras. Guess I'm lucky :fingerscrossed: Is it at the switch on drivers side? Does the passenger side switch work?
  3. Mar 4, 2021 at 8:54 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  4. Mar 4, 2021 at 9:47 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s not a common issue. Thankfully it’s not catastrophic like a jeep where the window will fall into the door and shatter. That happened to a friend of mine.
  5. Mar 12, 2021 at 12:49 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
  6. Mar 12, 2021 at 1:30 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I had it happen on the '92 Camry but luckily didn't shatter. It happened just after the warranty ran out. I took the door panel off and found a plastic part broke that held the window to the cable mechanism that moved the window up and down. Toyota didn't sell that part separately. You had to buy the whole motor and cable regulator assembly which then I think was around $300. I wasn't going to spend that much to fix a part by all actuality should not have cost more than a few dollars to replace. So I did one better and fixed it for no cost to me. I had some stiff baling wire and just used it to wrap around the broken plastic part and cable mechanism for free!
