Payload 2022 Tundra SR5
Discussion in 'Towing & Hauling' started by Rickem, Aug 7, 2022.
  1. Aug 7, 2022 at 7:40 AM
    Rickem
    Rickem [OP] New Member
    Rick
    2022 black tundra sr5
    I just took delivery of my 2022 Tundra SR5 4x4 Double cab. Online specs stated 1800 lbs. payload but door sticker shows 1500 lbs.I have a Fourwheel Hawk popup camper rated at 1100 lbs. Not too happy about being limited to only packing 400 lbs. of cargo. Should I return the truck to the dealer or trust the online spec of 1800 lbs payload?
  2. Aug 7, 2022 at 7:55 AM
    Retired...finally
    Were finding out the payload listed by dealers and online is for a truck you may never find. A unicorn of sorts. Does the camper really have 1,100 pounds of tongue weight?
  3. Aug 7, 2022 at 7:57 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Neither... :confused:
  4. Aug 7, 2022 at 8:00 AM
    Rickem
    Rick
    It's a camper, not a trailer so tongue weight not applicable. Payload is my concern.
  5. Aug 7, 2022 at 8:15 AM
    Retired...finally
    Oh, that makes a big difference.
  6. Aug 7, 2022 at 12:52 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    The spec is irrelevant...the sticker on the door jam is what counts.
    1,500 lbs of payload would be considered pretty damn good to most.
    Sorry to say you probably should have researched this more...
    SPP
  7. Aug 7, 2022 at 1:04 PM
    anh6259
    anh6259 New Member
    400 lbs = cargo + driver & passenger(s).
  8. Aug 9, 2022 at 12:16 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    1100lbs dry. Add another 20 gallons of freshwater (capacity) and now you're at 1266.
    1500-1266 = 234lbs left.
    That doesn't leave you much but it is doable. Assuming your single passenger is small to average in size and very very minimal cargo added.
    Sounds like you missed a little bit of homework prior to taking delivery.
  9. Aug 9, 2022 at 12:25 PM
    mass-hole
    mass-hole New Member
    This has been discussed extensively in the Payload thread. The stickers on all of the trucks are only going to be one of the 10 or so payload values in the owners manual. So regardless of your trucks specific options, the sticker will always read the same value as what is listed in the manual for your configuration.
    People are finding that their SR5 stickers are showing 250-300 lbs less than what a Cat Scale says it should be. So I suggest you go weigh your truck without you in it, but with a full tank of gas, and find out what the true curb weight is and subtract that from the GVWR. My guess is it will be in the 1700-1800 lb range.
    And 1800 lbs is the ideal number assuming you have zero options. Any options added at the factory or dealer over a base SR5 will reduce the payload.
    frichco228 and Cpl_Punishment like this.
  10. Aug 9, 2022 at 12:27 PM
    mass-hole
    It's usually easier to do that AFTER you purchase a $50000 truck.
    Jaypown[QUOTED] likes this.
