PCS Warning Light
Discussion in '2.5 Gen Tundras (2014-2021)' started by CourtJester, May 4, 2020.
  1. May 4, 2020 at 6:43 PM
    CourtJester
    CourtJester [OP] New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    2019 TRD Pro
    Anyone have issues with thing coming on for no reason? It’s done it a time or two and did it today and wouldn’t shut off. I finally shut the truck off and started it back up and it went away.
  2. Dec 22, 2020 at 10:41 AM
    peteshen
    peteshen New Member
    I had the same problem. Took it to my Toyota dealership and they can't find any code. I gave them 2 pictures but I guess they want me to bring it in when it comes on.
  3. Dec 22, 2020 at 11:01 AM
    Bodizaffa
    Bodizaffa New Member
    Calgary Canada
    2020 tundra crewmax
    Heritage grill. Black badging on exterior Leer 100xr campy color matched cement grey. AJT black out interior. Painted center surround. 275 70 r18 KO2s Spray bed liner Ellis precision shifter on way Blistein 6112 front and 5160 rear on way Charging tray on way Box led lighting on way Sill protectors on way Kat skinz once my kids stop destroying my stuff Any advice on custom bed storage. It's in the plans
    Dumb question maybe. Is the sensor clean? Mine does that when gets gummed up with mud or snow or ice.
    WesternFlyer and T500 like this.
  4. Dec 22, 2020 at 11:03 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If it’s cold and frost develops over the sensor or in heavy rains sometimes it will turn off. It snowed here last week and there was slush that formed on the bumper and iced up the grill. The PCS light came on then too. The weather seems to affect it quite a bit for me
    CourtJester[OP] and T500 like this.
  5. Dec 22, 2020 at 11:08 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Weather related I found out too
  6. Dec 22, 2020 at 11:09 AM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    When it rains hard mine does it
    T500 likes this.
  7. Dec 22, 2020 at 11:13 AM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    I, like the others, have only experience this a couple times due to weather. Mainly in cold weather (heavy frost or snow). It has always gone off after running for a bit though.
    T500 likes this.
  8. Dec 22, 2020 at 11:21 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm going to assume it's not weather related because his outside temp gauge says 84 degrees and in Alabama. Unless he's traveling to Minnesota and parked in a very heated garage :anonymous:
    Edit: weather related may be applicable to @peteshen
    CourtJester[OP] likes this.
  9. Dec 22, 2020 at 11:50 AM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    I see it when there's heavy rain or frost.
  10. Dec 22, 2020 at 11:57 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    The pre-collision system used the radar in the grill and the camera behind the rearview mirror. so if either get crap obscuring them it will cut the system off
    T500 likes this.
  11. Dec 22, 2020 at 12:01 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    This happens to me when there is rain, frost, dew, or the camera is dirty. It usually goes away shortly.
  12. Dec 22, 2020 at 12:08 PM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    my 2019 limited does the same thing from time to time. Like others have said, typically after snow or heavy rain, often clears up pretty quick.. I think it is a Minnesota thing, lol.. I do notice it is a little more sensitive since I switched to the AJT relocation bracket to use the 2018 Pro Grill.
  13. Dec 22, 2020 at 1:31 PM
    CourtJester
    Alabama
    It did happen a few times in the rain and then that picture was just tooling down the road on a dry summer day. It hasn't done it in quite some time though.
  14. Dec 31, 2020 at 8:05 PM
    GrumpyoldSGM
    GrumpyoldSGM New Member
    jeremy
    2021 Tundra 1794
    mine started out like that... had the pre col. symbol showing off and the sensitive was accessible through the menu screen but unadjustable... now a few weeks later the middlebox has an annoying error message saying the Pre col system is off and I can't get it or the yellow! symbol to turn off or go away. I tried to disconnect the battery as well.
  15. Jan 1, 2021 at 7:54 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Toyota bought my 2018 back because of this. Had the same issue where it would go off and on. Never throws a code. Even brought it in one time to get it looked at because it was going off and on. They hook it up to the computer to look for codes. while it was hooked up, the PCS light came on. Still no code. Then finally the malfunction error light came on and still no code.
