Pedal Lag
Discussion in '3rd Gen Tundras (2022+)' started by TurboTundy, Mar 12, 2023.
  1. Mar 12, 2023 at 11:12 AM
    TurboTundy
    TurboTundy [OP] New Member
    22 Tundra SR5 CrewMax TT3.5L V6
    Carven Exhaust Kit - Black Tip
    All,
    My 22 Tundra, non hybrid TTV6, periodically the throttle will lag, even a couple of seconds. Not predictable, only happens every now and then, and I am used to turbo lag, I don't step on it, and I drive it pretty conservatively.
    Is this just a normal function of an occasional turbo lag, that for some reason on occasion the turbo is spun down and for whatever reason at that instant takes a couple of seconds to spin back up, or is it something else? Like I said, it doesn't happen all that often, and it's not easy to recreate, seems to be random.
    Thanks.
  2. Mar 12, 2023 at 11:14 AM
    Mykeromachine
    Mykeromachine New Member
    2022 Tundra TRD Offroad
    There's a chance, if it's lag upon starting that your truck needs the ECU to be flashed. There is a technical service bulletin (TSB)
    T-SB-0111-22 out that might fix what you need.
  3. Mar 12, 2023 at 11:17 AM
    TurboTundy
    No, it's not on start up. Just sometimes, say at a stop sign, and not often, will lag say a full 1s or 2s, then spins up and goes. I try to recreate it to see exactly what causes it, but it just randomly occurrs, and not frequently.
  4. Mar 12, 2023 at 11:22 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Try it in sports mode
    RVer likes this.
  5. Mar 12, 2023 at 11:25 AM
    TurboTundy
    Doesn't seem to do it in sports mode. But, like I said, I can't really seem to recreate it, happens randomly, and infrequently. I am just curious if this is just the nature of the turbo/engine, or if it is something else.
  6. Mar 12, 2023 at 11:48 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    This happened to my 23 Tundra yesterday a lot. First was when I got off work and coming to a rolling stop on a uphill. Bad habit but I didn’t stop fully since it’s uphill but it lagged for like 1-2 secs before launching me lol. Second time was with my gf the same day in some parking lot stop signs again but flat elevation and she’s like are you mad or something and I’m like no the truck is being moody not me lol. I have had several updates from the dealer but nothing seems to fix it.
  7. Mar 12, 2023 at 12:59 PM
    raylo
    raylo not so new member
    Frederick, MD
    Makes me wonder if the TSB did anything at all and maybe it was just the ECU reset that "fixed" it until the relearning "broke" it again?
    4genRunner likes this.
  8. Mar 12, 2023 at 2:23 PM
    TurboTundy
    I'm mainly just wondering if it's a sign of something wrong, or if it's just pretty much standard turbo behavior how these engines are built. I suspect it isn't anything major, but I'm just curious.
  9. Mar 12, 2023 at 2:35 PM
    pyrotechnic
    pyrotechnic New Member
    2022 SR5 TRD OR
    My truck does it, I quit for a but after the TSB but it's back again. It's definitely not turbo lag. It definitely makes me creep around town like a grampa as I don't know if I'll be able to smoothly and decisively pull out into traffic or if I'll sit there for a second before launching like a retard.
    mayan likes this.
  10. Mar 12, 2023 at 7:38 PM
    mayan
    Mayan
    DFW
    Felt lol and I agree definitely not turbo lag more like something to do with throttle map but it happens a lot to me in eco.
  11. Mar 12, 2023 at 7:47 PM
    Mykeromachine
    Yea maybe I should try in sport mode because normally I am just sitting in ECO. It's caused me to be quite a bit more cautious when turning across traffic because I just don't know if the power is going to be there.
    mayan[QUOTED] likes this.
  12. Mar 12, 2023 at 7:55 PM
    mayan
    Mayan
    DFW
    Sport mode gets rid of it for me but doesn’t go into the over drive gears like normal and eco but my favorite mode is definitely sport for how smooth it drives but mpg drops considerably and I usually get around 24 mpg driving normally in eco so I pick it but drives very weird.
  13. Mar 12, 2023 at 8:22 PM
    Rel
    Rel New Member
    Pittsburgh, PA
    2023 Magnetic Gray Metallic Tundra Platinum
    Can I ask if you are using the auto engine off/on? These trucks are so quiet maybe you are moving your foot to the gas quicker than the enter starts back up and you just aren't noticing.
  14. Mar 12, 2023 at 9:51 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I believe your are referring to what many are calling throttle lag, yes many of us experience it. Mine will actually accelerate for a second starting from a stop and then it's like the throttle disengages for a second. This has almost got me creamed twice turning across traffic. Thankfully, I wasn't trying to cut it too close or I would have been hit for sure.
  15. Mar 12, 2023 at 9:58 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    I thought I had a hesitation, for the first time today, at a traffic light. Turned out to be I forgot to turn off the auto start/stop. It sure felt like hesitation but it wasn't.
  16. Mar 12, 2023 at 10:17 PM
    xc_tc
    xc_tc New Member
    I noticed two kinds of low speed delay.
    1. Slowing down/braking and accelerate again like light turned green before I could stop
    2. From stopped, brake off and let the truck roll by itself and then accelerate like when stopped at a light and the car in front is slow to start going
    #1 always feels like a downshift hesitation. I feel like a lot of vehicles are like this though. 1st is so low so I guess it’s hard to get into that gear.
    #2 is weird because it’s not turbo lag. Accelerating from 1000 rpm in other gears is no problem. It just seems like 1st gear is the issue, like there’s some kind of torque control to limit the rate of torque but I can’t really guess why.
    mayan likes this.
  17. Mar 13, 2023 at 4:48 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    If you have a Non-Hybrid a TSB is out that offers a software fix for lag or hesitation at lower speed like rolling through a toll booth or stop sign.
    Contact your local Toyota Service Center.
  18. Mar 13, 2023 at 6:47 AM
    pyrotechnic
    2022 SR5 TRD OR
    Yes, and unfortunately multiple people, myself included, have had the lag and hesitation return after about 500 miles post TSB.
    Eurodriver likes this.
  19. Mar 13, 2023 at 7:17 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    I think I'm able to replicate this, specifically on a rolling stop where you slow down to about 1-2mph then try to get going again, its a significant delay between requesting more throttle and the engine outputting the power, to know for sure I'd have to do some dataloging with techstream but I don't have the time to do so. Since my build date is after the Production update its probable that the issue isn't resolved by the TSB.
    The specific intersection was also jerky on my 2012 Tacoma, so its a unique one its a 4 way stop in a dip, so you coast downward followed by an immediate incline. My 2017 Tacoma actually handled this one well, but was far more derpy in everything else than either of the other trucks.
  20. Mar 13, 2023 at 8:38 AM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    The TSB helped but a pedal commander helped mostest.
  21. Mar 13, 2023 at 12:06 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    I have same issue 2023 Tundra 1794. Press the gas peddle from a stop and truck doesn't move , then press some more and it speeds forward. Acceleration is not linear from a stand still. Much less prevalent in Sport mode. TSB indicates a trans program issue. Wonder if its not a throttle relearn.
  22. Mar 13, 2023 at 12:17 PM
    xc_tc
    xc_tc New Member
    TSB didn’t really change much for any hesitation. The TSB said “worse when cold” so I assume it was much worse for those that live in wintery climates.
    The TSB reprogrammed the TCM only and I bet the throttle control lives in the ECM. So until there’s a software update for ECM, there won’t be a fixed for this nonlinear acceleration from a stop.
  23. Mar 14, 2023 at 5:37 PM
    Rel
    Rel New Member
    Pittsburgh, PA
    So is this something I have to look forward to? My 2023 Platinum has only 200 miles on it and is currently fine.
  24. Mar 14, 2023 at 5:46 PM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Mine is fine.10k
  25. Mar 14, 2023 at 6:43 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Mine did it from the start, maybe it's not an issue for you.
  26. Mar 14, 2023 at 7:15 PM
    BaldMenace
    BaldMenace New Member
    2022 Tundra SR5 Double cab
    My Tundra has a little peddle lag but only until it's warmed up.
  27. Mar 14, 2023 at 7:30 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I have had the TSB done. It helped, but the main thing is staying out of Eco while in town. I think it’s trying to decide what gear to be in. I notice more at a rolling stop than from from a dead stop.
  28. Mar 14, 2023 at 8:40 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I had tsb done about 1k miles ago.
    Tested today when driving from work and couldn't find any lag... So I think it's fine
  29. Mar 15, 2023 at 6:38 AM
    Tom976
    Tom976 New Member
    Tom
    This happened to me a few times too. Not start stop feature. Stop, roll gas.... oh no is this thing running? Then giddy up and go.
    My build is from Feb 2023. Wonder if it has to do with the safety sense....
  30. Mar 15, 2023 at 7:44 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    On a rolling stop or slowed down for entering a roundabout and then need to hit it and nope, there's the lag... Even on my Hybrid.
    mayan likes this.
