Pedal monster from banks.
Discussion in 'Performance and Tuning' started by Lemuel1, Nov 29, 2023.
  1. Nov 29, 2023 at 5:20 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Got it on a Black Friday deal, if you’re questioning it get it now. It’s like perfectly being in the power band all the time. Great product.
    Ginsterkev, Bprose and ryanwgregg like this.
  2. Nov 29, 2023 at 5:58 AM
  3. Jan 10, 2024 at 5:10 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    Any Improvements to MPGs?
  4. Jan 10, 2024 at 5:17 AM
    It doesn't improve them. It's designed to remove throttle delay.
  5. Jan 10, 2024 at 5:18 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nope, more fun though. MPG is all dependent on how you drive it. It’s not a tune, just interrupts the throttle position sensor to make pedal more sensitive. If you unplug it from obd2 it goes back to stock.
    Tundra234 likes this.
  6. Mar 28, 2025 at 9:33 PM
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    Does the safe reverse feature work? I have a 2021. I’ve heard cases where it doesn’t work on some model years.
  7. Mar 30, 2025 at 8:16 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Pedal Monster doesn't offer an MPG (muted throttle curve) mode. The throttle controllers that do offer the mode give marginal gains if any at all. I've had a Pedal Commander and two models of Hike It and none demonstrate any improvements in MPGs on my set up with my driving behavior and environment.
    You can emulate a throttle controller by mashing the pedal with a heavier or lighter touch so I don't think it is worth purchasing one if that is all you are after. Where I think the throttle controller comes in handy is if you want a valet or lock out mode.
    If you are really concerned with MPGs check Ecomodders. The site goes into a deep dive on hypermiling and also ranks mods by MPG improvements. To save you time the best and reasonable mods for a truck is an air damn and smoothing out the bottom of the truck to reduce turbulant air. Common mods like lifts and larger tires will hurt MPGs.
