Performance Chips- Yes or No?
Discussion in 'Performance and Tuning' started by Jedge, Jun 26, 2024.
  1. Jun 26, 2024 at 10:27 AM
    Jedge
    Jedge [OP] New Member
    Justin
    2016 SR5 Tundra
    I am a new Tundra owner. My father gave me his 2016 SR5 with only 36000 miles on it and I am looking to see if there are any performance chips that work well with this model?
    Metro14536 likes this.
  2. Jun 26, 2024 at 10:41 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    There is not. @mZiggy or @JustDSM can probably hook you up with an ECU tune however which would provide some benefits. Anything marketed as a “chip” is a waste of money and will do nothing for you.
    ZappBrannigan, Mdl and RCwyoming like this.
  3. Jun 26, 2024 at 11:14 AM
    Jedge
    Justin
    2016 SR5 Tundra
    Silver 17, thanks for your feed back. I was also thinking of installing a K&N air flow package. I had really good success with it on my old chevy 2500 HD. Any thoughts?
  4. Jun 26, 2024 at 2:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    To be honest your stock intake is a far better cold air intake than most on the market. You could search a SABM for your stock intake on this site.
    Silver17 and Saltyhero13 like this.
  5. Jun 26, 2024 at 2:24 PM
    Keep the stock intake. Push the tow/haul button when you need a boost. There, saved you $1000
    ZappBrannigan and Mdl like this.
  6. Jun 26, 2024 at 3:57 PM
    Silver17
    Eastern PA
    I second this!
  7. Jun 26, 2024 at 4:23 PM
    2mchfun
    Spend your money on 5.29 diff gears
  8. Jun 26, 2024 at 4:35 PM
    Silver17
    Eastern PA
  9. Jun 26, 2024 at 4:36 PM
    2mchfun
    Both!!!
    Mdl and Silver17 like this.
