Persistent Evap Codes in a 2002 4.7 AC
Discussion in '1st Gen Tundras (2000-2006)' started by Nueces, Jun 11, 2022.
  1. Jun 11, 2022 at 6:12 PM
    Nueces
    Nueces [OP] New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    Howdy, mates. I have owned this truck for 18 months, has 105K miles on it, runs like a top. I did all the catch up maintenance during the first year. Some weeks ago, I got a CEL with codes P0441 and P0446, evap leak codes. It’s been in shop jail several times and this is what has been done:
    Replaced cracked and leaking hoses from canister to engine mounted valve assembly.
    Installed new OEM gas cap.
    Replaced the engine mounted evap valve, as smoke testing revealed faults.
    Leak tested the evap canister, found pinhole leaks and a sticking control valve (part of the canister) – replaced that assembly.
    Only OEM parts have been installed. Still getting the 441 and 446 codes and the truck continues to run beautifully, even with the CEL light on.
    Do any of y’all have experience that might guide us in locating the remaining faults here?
    w666 likes this.
  2. Jun 11, 2022 at 6:19 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Welcome to the club . . . I'm in the same 'Hurt-Box' . . . cool folks here will chime in to help.
    It's all the smog crap.
  3. Jun 11, 2022 at 8:26 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    :popcorn:Same here as well. Thought it might be related to the gas smell I get with a tank fill up.
  4. Jun 12, 2022 at 4:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Are we relying solely on what shop folks say and if so, do we know for a fact the gas cap is OEM ?
    If relying solely on shop, have you checked gas cap and when putting it on, does it click when tightened ?
    Do we know if shop cleared all codes and if so, how long did it take for these 2 codes to re-appear. ?
    These 2 codes together normally point back to gas cap.
    Have you double checked their work as far as vacuum hoses ?
  5. Jun 12, 2022 at 5:14 PM
    Nueces
    Texas Hill Country
    2002 Tundra SR5 AC
    Gas cap is OEM, and clicks properly. I have a code reader and verified no codes after picking up the truck. Took about 2 weeks for the codes to reappear. Hoses are new and tight.
  6. Jun 12, 2022 at 7:52 PM
    johnstansbury
    johnstansbury New Member
    john
    2000 tundra 4.7 automatic
    I have seen a filler neck broken
  7. Jun 13, 2022 at 2:19 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  8. Jun 13, 2022 at 3:13 PM
    Jack McCarthy
    Bill
    North of Boston
    Smoke test. :rasta:
  9. Jun 23, 2022 at 1:21 PM
    Nueces
    Texas Hill Country
    2002 Tundra SR5 AC
    Those codes have not returned in the 12 days since I first posted this request. The only possible corrective action I took back then was to wipe clean the sealing surfaces for the new OEM gas cap, and did not detect anything much. Dunno, but I like not being haunted by the CEL.
    HBTundra likes this.
  10. Jun 23, 2022 at 2:43 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I too was going to suggest looking at the fuel filler neck like @johnstansbury suggested. I'm assuming you got the truck pre-owned and depending on where it came from could be causing the leak.
    It sounds like you may have gotten to the bottom of it (fingers crossed) but could be worth looking at if the codes come back.
  11. Jun 25, 2022 at 10:15 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Heh I’ve got 6 months before my next inspection. This is a reminder to start figuring out my evap issue again. I have gas smell by filler so perhaps the neck is leaky.
  12. Jun 29, 2022 at 3:53 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    I've had to replace the filler neck and/or fuel tank on my past Tacomas for evap leaks
  13. Nov 29, 2022 at 5:23 PM
    Nueces
    Texas Hill Country
    2002 Tundra SR5 AC
    OK, I took y'all's advice to look at the filler neck.The hard parts are discontinued, but the two hoses are still available as OEMs, albeit pretty expensive. I found a 2002 takeoff complete assembly on ebay, so I became well familiar with it's structure. Very unlikely that the steel bits were suffering leaks, but my two hoses had clamps on both ends and were as old as the underhood hoses I already replaced for tears.
    I took the take off assembly and two new hoses to my shop, where they replaced the hoses. I have not driven it much since then because I had a minor accident. It sits in the driveway awaiting a body shop appointment in January. Today, I ran it to burn out any condensation (used a bottle of Heet) and found the gas cap released pressure after a sit of 10 days or so. Good sign!
    Thanks for all the tips, guys.
    shifty` and Jack McCarthy like this.
