PIAA fog lights not working
Discussion in 'Lighting' started by Mbril, Sep 19, 2022.
  1. Sep 19, 2022 at 1:23 PM
    Mbril
    Mbril [OP] New Member
    Hey guys,
    Recently purchased a 2010 Tundra that had some PIAA fog lights installed.
    I was in a hurry and didn't check if they worked. They don't.
    I tried changing the H3 bulbs but it didn't do the trick.
    The switch does turn on and off just fine. Connectors inside the lights are clean. There are no evidence of severed/broken/rusted wiring anywhere.
    It looks like there is a harness that connects the lights directly to the headlights (the light on the switch turns off when I turn off the high or low beam).
    Any idea where I should be looking to possibly solve this issue?
    Thank you
  2. Sep 19, 2022 at 1:26 PM
    AZBoatHauler
    So.Arizona
    Check for voltage at the light. There should also be an in-line fuse wherever that harness picks up power if they didn’t use factory wiring.
    Backslider likes this.
  3. Sep 19, 2022 at 4:49 PM
    Mbril
    Checked the voltage at the lights and I'm not getting anything. The relay seems to be working. Fuse is intact.
  4. Sep 19, 2022 at 4:53 PM
    AZBoatHauler
    So.Arizona
    Voltage at the fuse on both sides?
  5. Sep 19, 2022 at 5:02 PM
    Mbril
    I'm getting a reading there too
  6. Sep 19, 2022 at 5:04 PM
    AZBoatHauler
    So.Arizona
    If you have voltage at the fuse trace your wiring from there to the bulb to find the short.
