Pics of a 1st gen without body mouldings?
Discussion in '1st Gen Tundras (2000-2006)' started by Bleek182, Nov 19, 2021.
  1. Nov 19, 2021 at 8:20 PM
    Bleek182
    Bleek182 [OP] New Member
    Josh
    Minden NV
    2006 sr5 double cab
    Anyone got pics of a gen 1 with out body mouldings.
  2. Nov 19, 2021 at 8:48 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Really depends on which ones you are talking about. I mean the V6 base model had no bodyside molding. If that is what you are looking for.
  3. Nov 19, 2021 at 8:50 PM
    Bleek182
    Josh
    Minden NV
    2006 sr5 double cab
    Double cab
  4. Nov 20, 2021 at 2:22 PM
    Sunnier likes this.
  5. Nov 20, 2021 at 3:51 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I Haven't seen a double cab without the door mouldings and whatnot, but I have seen what's under the fender flares. There are a bunch of big square holes spread over the edges of the fenders that look ugly.
    Here's a photo I snagged from a facebook group where someone removed their flares.
    147807385_10102081420201054_460804996424_16306614fc28d62c2eeac0066cb0ba40288eecd1.jpg
  6. Nov 20, 2021 at 4:12 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    I really need to put mine back on, just haven’t done it yet. Ive also kicked around the idea of having a body shop weld mine up and then have the monstaliner touched up :anonymous:
    FrenchToasty and scooterprint like this.
  7. Nov 20, 2021 at 7:30 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Worth the effort of filling if you're painting anyway IMO
    aredub, MS22, alb1k and 1 other person like this.
  8. Nov 20, 2021 at 8:33 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Your going to have holes that need filled unless it’s a reg cab like mine… which never came with side moldings
  9. Nov 20, 2021 at 8:48 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    A bit off-topic, but I absolutely love this truck. The color, the cap, everything about it just fits.
  10. Nov 20, 2021 at 8:50 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That's a pretty awesome looking truck
  11. Nov 20, 2021 at 8:54 PM
    empty_lord
    05 rollover special
    Thanks!
    it is one of my greatest achievements. the only one that will top it is the 01 tacoma most likely. depending on how much rust i find on the 93 mr2, maybe it too.
  12. Nov 20, 2021 at 9:20 PM
    alb1k
    Left Coast
    It's good
    I do like the look of no flares. But, I'm chasing enough squirrels at the moment.
  13. Nov 20, 2021 at 9:23 PM
    daveeasa
    David
    Dan, you like the black mirrors? I assume manual? They work well on the truck but curious if you contemplated heated power there and maybe color matched cement caps?
    OP, I got these but haven't press-fit them yet. Not sure how much I'll like the look. I don't love my chromey ones but not thinking of a re-paint so I'm a tad limited on choices unless I drop big $ for OEM.
  14. Nov 20, 2021 at 9:46 PM
    empty_lord
    05 rollover special
    they're powered, heated mirrors. was plug and play for my truck with the proper door harness. the black caps came off my old manual mirrors. these are junkyard specials. eventually i plan on getting new ones that dont vibrate and i'll be probably having the caps painted cement.
    daveeasa[QUOTED] likes this.
  15. Nov 20, 2021 at 9:51 PM
    daveeasa
    David
    And the button for mirror heat, junkyard pull solves that? Even the SR harness has the relay and wires? Or have to source a relay too? I definitely don't have a button but then again I do not have much need for mirror heat where I am.
    Do the caps just pop off with a pry tool? I need to find me some black or white. So I could potentially scrounge caps off manual mirrors then? That's rather good news.
    Sorry for the OT stuff OP.
  16. Nov 20, 2021 at 11:29 PM
    empty_lord
    05 rollover special
    Pop off from the back, need to remove the glass.
    mine was wired, plugs were all present. Double check yours since it’s an older one.!
