Pics w/ stock suspension with 275 60r20 tires
Discussion in 'Wheels & Tires' started by Snowcat4360, Jan 27, 2019.
  1. Jan 27, 2019 at 10:16 AM
    Snowcat4360
    Snowcat4360 [OP] New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Hi all,
    Looking for pics of trucks with stock suspension, aftermarket 20" wheels, and 275 60 r 20 (33") tires. I have a crewmax and want to go to the Novikane SOTA wheel with a +25 and am seriously thinking of no lift. Just want a slightly wider stance and a little taller tire to fill the wheel well more. Much appreciated!
  2. Jan 28, 2019 at 7:14 PM
    Snowcat4360
    Derek
    No one is running this tire size on stock suspension? Would really like to see some pics if any of you guys have them.
    Much appreciated,
    Inquiringone likes this.
  3. Jan 28, 2019 at 7:18 PM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    I have that size tire on stock rim if you want to see that. I put 275/60/20 BF Goodrich K02s on my Platinum rims
  4. Jan 28, 2019 at 7:22 PM
    Snowcat4360
    Derek
    Sure,
    Also looking for aftermarket wheels with something around a +18 or +25 offset
    Thanks!
  5. Jan 28, 2019 at 8:16 PM
    00Tyler10
    Tyler
    Bowling Green, Ky
    This is old. I'll post better one for you in the morning. 4E0A789E-7994-41A5-9185-D5C6E5B60F21.jpg
  6. Jan 28, 2019 at 8:40 PM
    Donkeypunch
    Donkeypunch New Member
  7. Feb 3, 2019 at 2:57 PM
    Snowcat4360
    Derek
    Looks great!
    Still trying to decide what to do. Pretty sure I am going to proceed with the SOTA Novakane wheels in 20x9 with +25 offset and 275 60r20 BFG KO2's, then sell my stock TRD Sport wheels and tires, then add the color matched OEM flares.
    Donkeypunch[QUOTED] likes this.
  8. Feb 3, 2019 at 4:25 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    275/60x20 tires on custom Raceline Havoc +25 offset wheels. Stock height. Had to remove front flaps on bumper and heat and mold the mud flaps a little to stop rubbing. Good Luck!
  9. Feb 3, 2019 at 6:30 PM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Are those Wildpeaks? P-rated? How do you like them?
  10. Feb 3, 2019 at 6:43 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    Yes, Wildpeaks, P-rated. Like them, but only about 500 miles on them so far. Don't tow or haul anything heavy anymore, so I don't need e-rated tires. Slightly more noise than the stock Michelins, but much better when roads are icy.
  11. Feb 3, 2019 at 7:17 PM
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    275/60-20 Wildpeaks, got 37k on them love them.
    TRDblvd and r1-superstar like this.
  12. Feb 3, 2019 at 8:54 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Stock suspension? What's the offset on those wheels?
  13. Feb 3, 2019 at 9:38 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Mine are technically aftermarket, as they have a different offset than stock, but they came on the TSS Off-road edition Tundras.
    My tires are 285/55/20, which I know is not what was requested, but are also the same as 33s, just wider than the 275s.
    I like them, but I think I’ll go with 34s when these wear out.
    bEastTexas903, VAQuicksand and KELZ84 like this.
  14. Feb 4, 2019 at 3:23 AM
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    Yes stock suspension, 20x9 +35 on the wheels
    easleycrawler[QUOTED] likes this.
  15. Feb 4, 2019 at 5:18 PM
    Snowcat4360
    Derek
    Looks great. Any issues running the 285's? I was entertaining trying that for the extra width.
  16. Feb 4, 2019 at 5:36 PM
    AlmightyCrash
    Crash
    San Leon, TX
    None whatsoever. I’m fairly certain I could go bigger and still not rub. Nothing at full turn, climbing, speed bumps, etc.
  17. Feb 4, 2019 at 5:50 PM
    Snowcat4360
    Derek
    Do you think a 285 60 would have issues?
  18. Feb 4, 2019 at 7:35 PM
    AlmightyCrash
    Crash
    San Leon, TX
    That’s only 33.5” tall. I don’t see it being an issue, but I can’t guarantee anything. I can only say what I’ve gathered from my experience with my tundra.
  19. Feb 4, 2019 at 7:47 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    It depends on your wheel offset. As I mentioned, with a +25 offset wheel, you have to remove the front bumper flap and heat and re-form the mud flap a little if you don't want any rubbing. With a 285 you will have to do more. The reason some guys get by with larger tires is a +35 to +60 offset wheel.
  20. Feb 5, 2019 at 2:05 PM
    TundraDrew
    TundraDrew New Member
    Drew
    Hahira, GA
    2020 White Tundra 1794 4x4
    Bakflip Revolver X4, Nitto Ridge Grappler 275-60R20
    I just had Nitto Ridge Grapplers installed, 275-60R20. No lift or mods, stock wheels. I was going to level the front, but I like this look better, and it’s more functional.
  21. Feb 5, 2019 at 4:08 PM
    Snowcat4360
    Derek
    That really looks good! How is your ride quality? Did the little extra sidewall improve it a bit? Amazing how a little larger and more aggressive tire changes everything.
  22. Feb 5, 2019 at 4:15 PM
    TundraDrew
    Drew
    Hahira, GA
    Thanks man, ride quality is just slightly rougher, probably due to the tread design (going from highway tires to A/T). There's a little more road noise too, but barely noticeable. Definitely changes the look, and will hopefully handle much better offroad compared to the stock tires.
  23. Feb 12, 2019 at 6:31 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I have 285/55/20. Really hoping to go with a 285/65/20 Nitto Ridge Grapplers.
  24. Feb 12, 2019 at 6:35 PM
    Donkeypunch
    Let me know if it works. The 275/60/20 BFG KO2s have about a little over 1 finger of space between the edge of the tire and the upper control arms. I suspect some slight trimming would be needed as well.
  25. Feb 12, 2019 at 6:37 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    This is what mine currently looks like next to control arm. Isn’t the 275 wider?
  26. Feb 12, 2019 at 6:44 PM
    Donkeypunch
    285 is wider by 10mm so it should be good to go. The middle number is how tall by percentage of how wide the tire is. Your 285/65/20 is about 34.5” in diameter.
  27. Feb 12, 2019 at 6:49 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Yeah that’s what I’m going for the 34.5, there is a 2018 TSS same wheels like mine and offset and he’s running 295/55/20 no rub all stock. @Donkeypunch
  28. Feb 12, 2019 at 6:55 PM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    The smaller that middle number is the more it rides like a forklift with solid tires.
    275/70/18 Open Country mud tires are 33.5" when new look better and ride smoother in my opinion.
    IceMan23 and KELZ84 like this.
  29. Feb 26, 2019 at 5:52 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Yea I have +25 offset wheels with 275/70R18 and the edge of my tire rubs just slightly when reversing at full lock, making contact on the back side of both front-wheel wells just above the mudflap. See the pic I attached with the smudge mark on the black plastic right where the wheel is contacting it.
  30. Jan 6, 2020 at 6:48 PM
    Mrencz
    Mrencz New Member
    2008 Tundra Limited Double Cab TRD Offroad
    So my question is for those who went from 275/55R20 to 275/60R20. I’m considering the larger but I don’t want to move any movement with my truck on the trails. I’m worried the extra size will not allow as much flex. I don’t have any kind of lift. Has anyone had any experience with this?
