Picture of the 26.4 and 38 gallons fuels tanks
Discussion in '2nd Gen Tundras (2007-2013)' started by zebian2, Mar 10, 2019.
  1. Mar 10, 2019 at 5:27 PM
    zebian2
    zebian2 [OP] New Member
    Jamy
    looking for a picture showing the 2 tanks next to each other.
    I’ve seen it here before.
    What I need to know if the fuel pumps area in the same area on both tanks
    Thank you
  2. Mar 10, 2019 at 5:47 PM
    Jrfor0
    Jrfor0 New Member
    James
    found this
  3. Mar 10, 2019 at 6:25 PM
    FXFormat
    FXFormat New Member
    You versus the guy she told you not to worry about.
  4. Mar 10, 2019 at 6:51 PM
    zebian2
    Jamy
    Thank you
    That’s exactly what I was looking for
    Thank you
    trayday likes this.
  5. Mar 10, 2019 at 6:51 PM
    zebian2
    Jamy
    I lost you there
  6. Mar 11, 2019 at 5:31 PM
    scorpio86
    scorpio86 New Member
    Ohio
    2008 Silver Tundra DBL CAB 5.7L
    so i've considered going to the larger tank. are they a direct swap? i grow tired of never passing a gas station.. lol. not upset with the mpg.. just the small tank!
  7. Mar 11, 2019 at 5:35 PM
    Sunnier
    Sunny
    San Diego, CA
    There's an install thread for replacing the 26 with the 38, posted by PapaSmurf. Search using the little magnifying glass near the upper right hand side of your screen.
    ColoradoTJ and scorpio86 like this.
  8. Mar 11, 2019 at 5:42 PM
    scorpio86
    Ohio
    yeah.. typical newb not searching first.. <-
  9. Mar 11, 2019 at 9:37 PM
    zebian2
    Jamy
    From what I’ve gathered so far regarding the swap.
    A few minor details needed to be considered.
  10. Mar 27, 2019 at 9:48 AM
    ginocara74
    ginocara74 New Member
    North Carolina
    2017 SR5 5.7 V8 FFE 4WD magnetic gray with front bench seat and off road package
    TRD dual exaust, TRD drop in air filter, Weather Tech rain GUARD, tri-fold bed cover
    Which minor details are you referring to please. I'm interested in the same upgrade. My truck is a 17 SR5. When I decided to go with the front bench seat I was not able to get the 38 gallon thank. So I'm assuming that the frame already has predrilled holes to install the middle support bracket.
  11. Mar 27, 2019 at 9:52 AM
    zebian2
    Jamy
    It’s the front strap that you need to add for the 38 gallons
    Plus the support that hold the strap
    You either drill in your frame and use bolts or weld.
  12. Mar 27, 2019 at 9:55 AM
    ginocara74
    North Carolina
    Even on 17 model? My SR5 was modified at the manifacture plant for front bench installation. So I'm assuming the predrilled wholes are there. Where do I check to be sure?
  13. Mar 27, 2019 at 9:56 AM
    zebian2
    Jamy
    I’m only talking about the fuel 38 gallons upgrade
    No infos on the front seat
    Sorry
  14. Mar 27, 2019 at 10:08 AM
    ginocara74
    North Carolina
    What I meant is that SR5 trim level comes with a 38 gallon fuel tank. Mine is a 17 SR5 which should had a 38 gallon fuel tank. When I decided to have a front bench seat the 38 gallon thank didn't come with it even tough is an SR5
  15. Mar 27, 2019 at 10:25 AM
    zebian2
    Jamy
  16. Mar 27, 2019 at 10:43 AM
    Curious, would mine have, 2014 SR5 CM
