Plasti Dip VS Vinyl Wrap VS paint protection sheets
Discussion in 'General Tundra Discussion' started by Tundyfundy, Sep 30, 2019.
  1. Sep 30, 2019 at 12:05 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Hey y'all! I'm looking to get some sort of paint coating over the paint to protect against off-roading and general thrashing of my paint.
    Any tips on what would be best? Easiest? Cheapest?
    Thanks in advance!
    Fishin RGV-Trd Pro likes this.
  2. Sep 30, 2019 at 12:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    No one single product will be all 3 of these.
    Best would be doing lineX on the whole truck but that is permanent, 2nd best option is wrapping the whole truck with vinyl or clear PPF. Those are very expensive options and generally not a DIY job. Easiest and cheapest would be doing nothing or plasti dip, but it won't work very well and will look crappy.
    jewsNbrews likes this.
  3. Sep 30, 2019 at 12:29 PM
    Tundyfundy
    Bay Area, CA
    What is PPF? I had a paint guy tell me vinyl only lasts 5 years. I could get my truck plasti dipped clear for around a thousand. As long as it looks better then pin stripes along the sides of the truck I’m ok with that.
    The lines is a no go because I’d like something less intensive.
  4. Sep 30, 2019 at 12:35 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Clear plastidip sounds like a horrible idea
    PPF=paint protection film
    Your best bet is vinyl wrap.
    MyFj08, McMason and Jmad1997 like this.
  5. Sep 30, 2019 at 12:37 PM
    Tundyfundy
    Bay Area, CA
    I saw a truck that was plastidipped clear and it had a rubbery feel and just looked hazy, but it was indestructible. What reasons do you think plasti dip is bad? You think vinyl will last a while?
    Jmad1997 likes this.
  6. Sep 30, 2019 at 12:47 PM
    Jmad1997
    Jmad1997 New Member
    Vinyl will last and hold up to pinstripes. Vinyl is warrantied for 3-5 years but I have seen it last longer than that. Vinyl will be cheaper than PPF and look 100000x better than plasti dip.
  7. Sep 30, 2019 at 1:41 PM
    Tundyfundy
    Bay Area, CA
    Just spoke with a professional. He seems to think the same thing. He said they can ceramic over it and it will last longer. Looking into this now. Only thing is it’s so expensive. I’ve done all the mods to my truck. Every last one except for window tint. I think I can handle the install, although there will be a learning curve.
    Jmad1997[QUOTED] likes this.
  8. Sep 30, 2019 at 1:50 PM
    Jmad1997
    Jmad1997 New Member
    You can ceramic over it. And if you are semi patient you can do it yourself you just need time and some YouTube certification. If you want a pro to do it the going rate for a full size truck is about $3,000-$3,500 in NM. I’ve had a few of my wraps go through some tough wheeling and they help up. Only failure I have seen due to wheeling was rubbing the whole bedside on a tree that also cause the fiberglass bedsides to fail.
  9. Sep 30, 2019 at 1:52 PM
    Tundyfundy
    Bay Area, CA
    Awesome. I’m going to have them do paint correction and then vinyl wrap myself. Thank you! I think that was the confidence I need to get this started.
    Jmad1997[QUOTED] and jewsNbrews like this.
  10. Sep 30, 2019 at 1:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Ceramic wont protect from scratches. It can help. But if seriously off roading, it will still scratch. I love ceramic coats on my trucks...but it doesnt cover scratches.
  11. Sep 30, 2019 at 1:57 PM
    Tundyfundy
    Bay Area, CA
    Yeah that’s what he said. Ceramic is like just more clear coat. He said if you ceramic over the vinyl it will last longer. I’m not moshing through trees and stuff only worried about desert pin stripes. Like rigid bushes.
  12. Sep 30, 2019 at 1:58 PM
    Jmad1997
    Jmad1997 New Member
    Ceramic coating can help the longevity of the vinyl. Vinyl is taking the scratch. If it doesn’t go through the vinyl material fully most wraps have “memory” meaning you can heat it and most scratches heal themselves if it’s not crazy.
  13. Sep 30, 2019 at 1:59 PM
    Jmad1997
    Jmad1997 New Member
    You won’t regret it.
  14. Sep 30, 2019 at 2:01 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thats cool. Good to know. The MGM i had scratched too easily. Ceramic helped but not very well. But i love it for its other properties of being hydrophobic and cleans easily. Also helps uv protection as its outside 24/7
  15. Sep 30, 2019 at 2:05 PM
    Jmad1997
    Jmad1997 New Member
    https://youtu.be/pTEASrOQPj4
    This shows how to repair some minor scratches in wrap. The ones shown in this video would be somewhat consistent with a small shrub/branch rubbing your truck.
  16. Sep 30, 2019 at 2:07 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thats pretty cool. Something else for me to look into:annoyed::spending:but having peace of mind off road would be nicer.
  17. Sep 30, 2019 at 2:13 PM
    Jmad1997
    Jmad1997 New Member
    I like that it’s UV resistant. Out here in NM clear coats get eaten alive and flake like the truck has dandruff. I like that it’s sealed. And the matte colors look killer.
  18. Sep 30, 2019 at 2:26 PM
    Tundyfundy
    Bay Area, CA
    The Toyota paint is so soft. Everything scratches it. Hydrophobic is a great quality due to our color and water spots.
    I’m going to love having the protection off road. That’s my number one motive here along with protecting the truck against heavier damage from parking lots, kids, dogs, and generally everything That comes with having and using a truck like a truck.
    They quoted me 2500 for 4 stage paint correction w ceramic over it. I’d then wrap the truck and ceramic it myself.
  19. Sep 30, 2019 at 2:44 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I hang rubber stall mats alongside my truck when I go off the pavement. 45 buck a pop from tractor supply and I can take them off when I get home. Only need 6 of them plus 1 for the front.
    Tundyfundy[OP] and jewsNbrews like this.
  20. Sep 30, 2019 at 3:07 PM
    Tundyfundy
    Bay Area, CA
    i
    Can you link them?
  21. Sep 30, 2019 at 3:17 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
  22. Sep 30, 2019 at 4:30 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    @DZ_ pics or it didn't happen. Im sure you are joking
    Tundyfundy[OP] and DZ_ like this.
  23. Sep 30, 2019 at 4:40 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
  24. Sep 30, 2019 at 5:34 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    As far as I know, you cannot wrap anything over a ceramic coated surface.
  25. Sep 30, 2019 at 5:48 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    I would suggest paint protection film over vinyl. We have our commercial vans and trucks wrapped with vinyl. I can tell you that they do not certainly hold up that well. My fleet sees construction sites, my trucks with the PPF has held up much better.
    When it came time to decide on my sports car. I use my car at the track a lot, so wanted the best protection possible. I ended up using PPF, and have been very happy with it. Some of the guys I track with that used vinyl are not particularly happy. One thing about PPF is finding someone that does it really well.
