Platinum Package & Option Codes (pulled from dealer daily)
Discussion in '3rd Gen Tundras (2022+)' started by nodak67, Apr 28, 2022.
  1. Apr 28, 2022 at 3:49 AM
    nodak67
    nodak67 [OP] New Member
    JR
    i got this pulled from dealer daily for all the platinum package codes and option codes.
    this is a screen shot of an allocation request i am thinking of going with but havent decided yet.
    the AQ package requires you select RB package also for my region (Kansas City)
    tried to only select the AQ code but wouldnt let me select any other running boards. i dont want automatic running boards due to our winters.
    i did edit the pdf to remove the person that logged in, and the dealer info in case toyota usa had an issue with the dealership.
  2. May 3, 2022 at 11:59 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Thanks for this. Helped me decipher most of the option codes for an allocation I just got. Does anyone know what option code RR is?
  3. May 3, 2022 at 2:29 PM
    Hyezt
    Hyezt New Member
    RR is rock rails.
  4. May 3, 2022 at 2:32 PM
    4genRunner
    Southwestern MO
    Thank you!
  5. May 4, 2022 at 5:21 AM
    nodak67
    JR
    ?? is for the TRD running boards if you want those instead of the dual step black ones. but that would be a dealer installed option that you would have to work out with the dealer since you cant option that for a platinum from the factory.
    edit: sorry i forgot the option code for the TRD boards. thought i had it laying around.
  6. May 4, 2022 at 6:15 AM
    Hyezt
    Hyezt New Member
    R4 is the TRD aluminum running boards for crew max models.
    R6 is predator steps.
    nodak67[QUOTED][OP] likes this.
