Please Help!!! Fox 2.5 gave me a 5” lift 2022 Sequoia TRD Sport
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by TundraTEX518, Nov 12, 2023.
  1. Nov 12, 2023 at 6:18 PM
    TundraTEX518
    TundraTEX518 [OP] New Member
    Tay
    19 LTD CM 4x4
    Please help
    2022 TRD Sport Sequoia
    4x4
    So everything was going great until I lowered the truck down and saw how tall she was sitting.
    setup
    Fox 2.5 Factory Race Series 88002947
    2-3” lift claimed for the kit
    Trying to keep factory UCA because I wasn’t trying to go above 2” at least for now
    center of hub to fender:
    Passenger:21.5”
    Driver: 21”
    post lift height
    Passenger: 27.5”
    Driver:26.5”
    6” gain passenger
    5.5” gain driver
    wtf
    I even adjusted the collars up 2 turns. Currently resting at the 6th thread
  2. Nov 13, 2023 at 12:43 PM
    TundraTEX518
    Tay
    19 LTD CM 4x4
  3. Nov 13, 2023 at 1:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Did you loosen the lca bolts when you installed them?
    Did you tighten the lower shock and lca bolts with the truck sitting on tires under its own weight?
  4. Nov 13, 2023 at 1:01 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Did you move the truck at all after the install? If not it is possibly just 'scrubbed'. The tires don't want to slide sideways on the concrete under the truck so it keeps the height closer to full droop than ride height when you drop off of the jacks. Worth a shot:notsure:... just back up 15-20 feet and turn the wheel a couple of times while moving, then pull back forward and remeasure.
  5. Nov 13, 2023 at 1:15 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Did you drive the car and let the suspension settle after?
  6. Nov 13, 2023 at 1:41 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    This. Suspensions always sit a couple of inches higher immediately upon setting them down. They need a drive-around to settle.
  7. Nov 13, 2023 at 1:42 PM
    TundraTEX518
    Tay
    19 LTD CM 4x4
    Tightened everything after lowering, and have driven it around everything feels good. Just finished putting wheels and tires on. Just seems way tall, and I adjusted collars even more
  8. Nov 13, 2023 at 1:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Maybe the front weight balance of the sequioa is lower than a crewmax?
  9. Nov 13, 2023 at 2:01 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  10. Nov 13, 2023 at 2:10 PM
    TundraTEX518
    Tay
    19 LTD CM 4x4
    Damn this is my wife’s car or I wouldn’t mind. I guess I’ll be putting these on my truck. Thanks for all the comments and assistance
  11. Nov 14, 2023 at 4:42 PM
    TundraTEX518
    Tay
    19 LTD CM 4x4
    Just to follow up I ended up doing a spacer lift until I can determine the direction I want to go with the front, I’m impressed with the road mannerism with the factory Bilstein plus the spacer and it sits level with the back, which ended up with 5100’s and dobinson 1.75” springs
    the rear rides firm but gentle, granted impression solely from 2 speed bumps while test driving post install but I love the stance and I’m liking the wheel tire combo a lot. Now debating storage of the spare and roof rack options.
    The Fox 2.5’s I’m not thrilled about the initial impression I got from the short test driving I did while they were on. Even with UCA I’m not convinced they won’t behave similarly on my tundra. I may try to return them, or possibly exchange them.
    I welcome any feedback or questions. Thanks for your input
  12. Nov 15, 2023 at 12:25 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Those coilovers are for a 07-21 Tundra (and usually fit Sequioa), not a 2022+ vehicle. The lengths btw the two are VERY different, which is why its sitting so tall.
    880-02-947 (What you have, and PN is not for Long Travel)
    COMPRESSED: 18.1920
    EXTENDED: 24.860
    883-06-218 (What you need)
    COMPRESSED: 15.640
    EXTENDED: 21.680
    AZTundra, T-Rex266 and JMGmanAZ like this.
  13. Nov 15, 2023 at 1:11 PM
    APalmTree
    Brandon
    SW Washington
    I have no knowledge on these spring lengths only want to point out, Sequoias lag a year behind the Tundras, so the 2022 Sequoia is still on the 2nd gen platform (07-21 tundras).
    ryanwgregg likes this.
  14. Nov 15, 2023 at 1:44 PM
    AccuTune Offroad
    El Cajon, CA
    If thats correct and does bolt in, my next suggestion would be springs. If our customers are running stock weight up front and dont plan to add anything else, we drop spring rate quite a bit.
  15. Nov 15, 2023 at 3:28 PM
    mountainpete
    2022 Sequoia is the same as a 2021 Tundra. It was only redesigned as a 2023.
  16. Dec 2, 2023 at 10:48 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I have a Tundra and Sequoia also. Even though the Tundra front suspension fits on the Sequoia, I think they have different spring rates. I have not confirmed but I think the stock Tundra springs has a higher spring rate vs the stock Sequoia springs. When the aftermarket manufacturers design the lifts, they base it off the Tundra specs. In your case, Fox advertise 2.5-3" lift on a Tundra but may not have tested on a Sequoia. That's why when installed on Sequoia it lifts higher than Tundra because of the higher spring rate. Even if you look at the Bilstein 6112, they advertise different lift heights for the Tundra and Sequoia even when on the same clip settings. For example, it says if on clip#3, it lifts Tundra 2.7" and Sequoia 3.3"
  17. Dec 8, 2023 at 4:43 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    For reference, I put a set of Bilstein 5100's with Tundra front springs on my 2nd Gen Sequoia to level it out and ended up with significant increase in ride height. I even used the lowest perch setting on the Bilsteins. I attributed this to the spring rates, they were absolutely different.
