Please help with this
Discussion in '1st Gen Tundras (2000-2006)' started by YodaKru, Jan 14, 2025.
  1. Jan 14, 2025 at 6:11 PM
    YodaKru
    YodaKru [OP] New Member
    Big island Hawaii
    02 white 4.7 tundra sr5 ac cab 4x4
    Rcd 6” full length Bilstein front and rear total chaos uca
    My 2002 sr5 4.7 access cab 4x4 is driving me insane. Soon as I fix something then something else will go wrong. About 2 weeks ago my truck started giving me symptoms like bad coil. I thought it would have been water in my fuel tank because that happened about six months ago where I jumped fuel pump to drain tank and gave the truck a throttle body cleaning and oil change and cleaned plugs. Truck was running better than ever until about two weeks ago, so I dropped gas tank and cleaned inside and addressed fuel pump gasket, which was rotted and new fuel filter. Then proceeded with brand new coils and plugs. I should’ve stopped there, but because of my fuel trims being around +30 I made the decision that I had an intake gasket leak and went ahead and replaced lower and upper and all seals on my Injectors.When I went to start the truck there was a surging idle and no response to throttle. After three stressful days of troubleshooting and learning about my throttle body decided on the TPS sensor on driver side which fixed the response problem. Then I had the bright idea of cleaning my cone Filter and cleaning my MAF sensor Which brings me to the current issue of a loud chirping sound that sounds like it’s coming from the firewall area near intake or exhaust manifold but when I say loud, I mean loud and it’s cyclic or intermittent but as soon as I start It. It still has surging idle because I Can’t leave the truck running long enough to relearn because it sounds like it’s doing damage.
  2. Jan 14, 2025 at 6:14 PM
    YodaKru
    Big island Hawaii
    I will try to post a video so you guys can hear it
  3. Jan 14, 2025 at 7:10 PM
    shifty` Grab your dope and your shelltoe shoes!
    It would help if you did a scan and let us know if you have any codes.
    Can’t think of anything on the firewall that would cause chirping off the top of my head. Serpentine pulley, totally.
  4. Jan 14, 2025 at 7:22 PM
    YodaKru
    Big island Hawaii
    Last codes to show up were p0300 random multiple misfire and then p0301-308.
    not sure on how to post a video but trying to get it figured out
  5. Jan 14, 2025 at 7:25 PM
    May be worthwhile to isolate shit.
    If the noise is rhythmic, try taking the serpentine belt off. Then start the engine. It’s fine to run without serp belt for a few minutes.
    If noise goes away, you know the source. Likely a pulley. Spin all the pulleys to find the guilty SOB.
    There’s a TSB for cold-start squealing FYI. It’s in the megathread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Search that thread, 1st page, for the word SQUEAL and you’ll get the link to Toyota’s document on it.
    G_unit3000 and YodaKru[OP] like this.
  6. Jan 14, 2025 at 7:40 PM
    YodaKru
    Big island Hawaii
  7. Jan 14, 2025 at 7:43 PM
    YodaKru
    Big island Hawaii
    Wondering if it could be the starter but to me it sounds like intake or exhaust
    Tundra family likes this.
  8. Jan 14, 2025 at 8:49 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    What brand coils did you use?
    these trucks hate aftermarket electronic if you didn’t go oem or Denso you might have some issues with the coils after a few thousand miles. I learned the hard way.
    Also try taking the belt off and turning the engine on.
  9. Jan 14, 2025 at 8:58 PM
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Sounds like a massive intake leak.
    ATBAV8, BroHon and shifty` like this.
  10. Jan 15, 2025 at 4:11 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Always use OEM intake gaskets. If you must go aftermarket, only FELPRO.
  11. Jan 15, 2025 at 4:50 AM
    Yeah, the idle surging, the sound of sucking, knowing the engine is one big air pump essentially (with controlled explosions inside), sounds like you fucked up on the intake gasket.
    Tell us more about the gasket install. Two things: it’s easy to install them backwards and we have one guy on here who had to install 3x because he had aftermarket (2 different common brands( fail on him. Nobody has ever had an issue with OEM, other than installing them backwards with the tabs aligned wrong.
    bmf4069 likes this.
  12. Jan 15, 2025 at 6:34 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Something is not sealed right causing a whacky vaccuum issue.
    YodaKru[OP] likes this.
  13. Jan 15, 2025 at 6:35 AM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    G_unit3000 likes this.
  14. Jan 15, 2025 at 6:36 AM
    FishNinja
    Lee
    06DC2wd
    my durashit coilpacks are going on a year now lol
    JasonC., G_unit3000 and BroHon like this.
  15. Jan 15, 2025 at 6:39 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Going on 3.5 years... I don't even remember the brand :anonymous:
    Lol:fistbump:
    FishNinja[QUOTED] and G_unit3000 like this.
  16. Jan 15, 2025 at 6:40 AM
    Following up to my own post with info from @bfunke on the intake gasket orientation. I don't know about the upper gaskets (you said you did upper & lower), but the lowers must be installed in a specific fashion, which isn't abundantly clear at first glance:
  17. Jan 15, 2025 at 7:18 AM
    YodaKru
    Big island Hawaii
    Thanks everyone for your responses. I may have found the leak or void I should say
    jerryallday likes this.
  18. Jan 15, 2025 at 7:22 AM
    Don't leave us in suspense! :rofl:
  19. Jan 15, 2025 at 8:31 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    My Duralast coils give up after 9.5k miles. Switch to denso 50k miles later no problems.
    BroHon likes this.
  20. Jan 15, 2025 at 8:34 AM
    Sounded more like a void than a leak
  21. Jan 15, 2025 at 11:20 AM
    bmf4069
    bmf4069 Something something Miller Lite
    Beau
    TX
    02 AC sr5 4wd v8
  22. Jan 15, 2025 at 11:25 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There's only one way to install the upper.
    BroHon likes this.
  23. Jan 15, 2025 at 12:07 PM
    FishNinja
    Lee
    06DC2wd
    cali problems.
  24. Jan 15, 2025 at 12:08 PM
    You say that, but you've also never seen some of the shit I've done after a few beers.
    I had to make a new rule for myself 20 years ago. No beers until the work is done. After beers/booze, shifty isn't allowed to touch the tools.
  25. Jan 15, 2025 at 1:58 PM
    YodaKru
    Big island Hawaii
    So all major gaskets passed the smoke test. Only two small leaks maf gasket and another line running from intake tube to passenger valve cover, which both were addressed. Also the felpro gaskets I bought on the bottom side were only one layer unlike the triple layer that was removed?
    Now, could anybody tell me why my oil temperature light came on when I was trying to reset the idle Which was staying around 1700 in drive. So I shut her down and gonna have lunch.
    p.s. it’s always good To have the garage organized, especially all spark plugs should be accounted for and not mixed up with the old plugs.
    KNABORES likes this.
  26. Jan 15, 2025 at 2:44 PM
    bfunke
    South Carolina
    Oil temp light? Sure it’s not pressure - danger Will Robinson!
  27. Jan 15, 2025 at 3:18 PM
    YodaKru
    Big island Hawaii
    It says at oil temp. And the idle reset doesn’t seem to be working it’s stuck at 1800. Wondering if I need to adjust tps?
    I think it’s auto trans temp light?
    Faaack! Dis truck I tell you and that’s why I love my Tacoma more always have and always will.
  28. Jan 15, 2025 at 8:57 PM
    Jdtuned
    Jdtuned New Member
    01 AC sr5 4.7 2wd
    No mods besides regular maintenance and up keep.
    is the truck still making that terrible noise?
  29. Jan 15, 2025 at 10:44 PM
    AZBoatHauler
    So.Arizona
    Does it have oil?
  30. Jan 16, 2025 at 1:47 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :eek:
    bmf4069[QUOTED] likes this.
