Plug Behind Climate Control Panel (8pin)
Discussion in '2.5 Gen Tundras (2014-2021)' started by BBoy1983, May 20, 2023.
  1. May 20, 2023 at 6:06 PM
    BBoy1983
    BBoy1983 [OP] New Member
    2017 Tundra Limited Edition 4x4
    Anyone have a wiring schematic for 2017 tundra limited edition 4x4, non jbl radio, I'm looking for the wiring layout for the 8 pin plug behind the climate control panel, it has like a white and black wire, a couple blues , blacks, and maybe a red! I'm trying to find where each color wire goes on the pin plug connector
  2. May 20, 2023 at 6:12 PM
    https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
  3. May 20, 2023 at 6:17 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. May 20, 2023 at 6:27 PM
    BBoy1983
    Ok so I see it's called the j127 plug, however I don't see a wiring diagram, as far as which wire goes where
  5. May 20, 2023 at 6:32 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    The numbers on the wire diagram are the pin number in the connector.
    J127 Pin 4 is IG+ Blue, Pin 5 is GND White/Black, etc.
  6. May 20, 2023 at 6:41 PM
    BBoy1983
    Yes sir, I understand how each pin is numbered, I just don't see a wiring diagram, but if you don't mind, can you just tell me what the other 5 or 6 pins are, I see pin 4 is ign+, and pin 5 is a ground......
  7. May 20, 2023 at 6:46 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    From the pictures above, it looks like the following:
    1 Haz - Blue
    2 P-AB - Brown
    3 PAON - Black
    4 IG+ - Sky Blue
    5 GND - White/Black
    6 ILL- - Red
    7 STX - Sky Blue
    8 ILL+ - Green
    Henry1jg likes this.
  8. May 20, 2023 at 6:47 PM
    BBoy1983
    Thank You, all who helped, Soo much!!!!
