Poly leaf spring bushing kit
Discussion in 'Suspension' started by TexasTundra27, Aug 24, 2018.
  1. Aug 24, 2018 at 9:45 AM
    TexasTundra27
    TexasTundra27 [OP] Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    MetalTech 4x4 has a poly bushing kit from Ironman4x4 that includes all 4 leaf spring eyelets AND the upper shackle bolt bushing. The only part you need to reuse is the metal sleeve from the original upper bushing, and you will need to order some type of grease for it, I ordered a small tub of the Energy Suspension grease off Amazon. I just placed a order for a set and plan on installing it soon so I’ll report back with how the install went and how it rides.
    My14Tundrs, GodlessPro and Sas like this.
  2. Aug 24, 2018 at 10:15 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Spendy! I've been shopping for bushings lately and saw those but I'm cheap. Maybe some of the bushings I've been looking at don't include the shackle bushings too?
    GodlessPro likes this.
  3. Aug 24, 2018 at 10:21 AM
    TexasTundra27
    Mark
    I honestly think that’s cheap for 6 sets of bushings! I paid $50 for just the rear spring eyelet when I installed my coachbuilder shackles.
    GodlessPro and 831Tun[QUOTED] like this.
  4. Aug 24, 2018 at 11:09 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You've probably researched this more than I have. I was thinking MCM or TC had 'em for $40-50?
  5. Aug 24, 2018 at 12:18 PM
    TexasTundra27
    Mark
    I can’t find any leaf spring bushings on the @TOTAL CHAOS website or the MCM website...
  6. Aug 24, 2018 at 2:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Bushings are an option if you buy Deavers from Matt so I figured he's gotta have 'em. Price difference is $40-50, doesn't mean I could actually buy 'em from him for that, I was just assuming. I guess I could call Deaver too and see what they say.
    The more points you bring up the better that price is looking LOL. .:anonymous:
  7. Aug 24, 2018 at 2:29 PM
    TheBeast The Beach
    i got new bushings when I bought my Deaver leaf pack from MCM.
    831Tun[QUOTED] likes this.
  8. Nov 21, 2018 at 5:57 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    so what's the report back on install and ride quality?
    speckmon likes this.
  9. Nov 21, 2018 at 11:08 PM
    TexasTundra27
    Mark
    Haven’t gotten around to doing it yet, I will say when I originally installed my coachbuilder shackles and bushings it was a huge upgrade so I have high hopes for this set.
    Coachbuilder1 likes this.
  10. Jul 14, 2021 at 4:57 PM
    Redacted
    Redacted New Member
    MA
    2014 SR5 TRD
    3" level kit
    What did you use for the front leaf bushing at the frame? I got the Ironman shackles and have the bushings set up for the upper lower shackle but there’s a lot of slip in the leaf spring front eyelet with the Ironman set. At a loss.
  11. Jul 17, 2021 at 2:48 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    I just got my kit the other day and was going to install next weekend. How much slop is there ? Have you called them or maybe snap a few pictures for us?
  12. May 31, 2023 at 7:50 PM
    TexasTundra27
    Mark
    Let’s just say I wasn’t impressed with the Ironman bushings… finally installed them in 2021 and they were shot within months and replaced them with some energy bushings today.
    Terndrerrr likes this.
  13. May 31, 2023 at 8:36 PM
    blenton
    blenton New Member
  14. May 31, 2023 at 8:55 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I have poly everywhere on the first gen. I've modded sleeves and bushings to fit my applications, used every grease from Energy #5 to SuperLube high dollar to copper anti-seize. What I've learned is that good poly is good and grease is essential if you want a quiet ride after that next 5 day run. And you want to be able to re-grease without pulling your suspension apart. And, you have to learn where you want the grease to go and where poly is supposed to slide and where it is supposed to hold. I use a combination of zerk pins, zerked eyelets and modded sleeves to put the grease where it should be without a teardown. I guess my point is poly is the way to go for some, but it also adds to your maintenance schedule, in my experience.
    TexasTundra27[OP] and 831Tun like this.
  15. May 31, 2023 at 9:27 PM
    alb1k
    Left Coast
    It's good
    I realized I didn't explain the most important part. Where you want the grease (movement). Light grease anywhere is fine, but these red areas are where you want greased movement. Between the inner sleeve and the inner bushing, and on the outside of the bushing flange. Thats where poly is supposed to move. Remember that when you tighten down your bolts, that inner sleeve becomes part of the frame or shackle - it's not a bearing, the poly moves around it.
    And those grooves you see in the pic are not grease channels. The poly bushings are not meant to rotate in the leaf eyes.
    TexasTundra27[OP] likes this.
