Popping noise when turning
Discussion in 'General Tundra Discussion' started by Gravyacres, Jun 11, 2018.
  1. Jun 11, 2018 at 7:01 PM
    Gravyacres
    Gravyacres [OP] New Member
    Mississippi
    2018 CM TSS
    When I’m backing out of the driveway and turn the steering wheel all the way, I feel a popping sound. Only happens when steering wheel is turned all the way (in either direction). Anybody else having this issue?
  2. Jun 11, 2018 at 7:08 PM
    Grumpy Uncle
    Pat
    CO
    Are you running bigger tires? I see your a 4x2, could the tire be hitting the fender well or UCA?
    4x4_Angel likes this.
  3. Jun 11, 2018 at 7:13 PM
    TheBeast The Beach
    any mods done to the truck or stock suspension/tires ?
  4. Jun 11, 2018 at 7:17 PM
    Gravyacres
    Mississippi
    2018 CM TSS
    Stock 20” blackout wheels w/ BF Goodrich tires. No mods.
  5. Jun 11, 2018 at 7:18 PM
    TheBeast The Beach
    could it be rubbing on engine skid plate (if any?)
  6. Jun 11, 2018 at 7:20 PM
    Grumpy Uncle
    Pat
    CO
    Maybe the sidewalls are hitting the coilovers or UCAs. My boys runner does this on the coilovers at max turn in reverse.
    Edit side lugs
  7. Jun 11, 2018 at 7:22 PM
    Gravyacres
    Mississippi
    2018 CM TSS
    10-4 Grumpy Uncle, I’ll check that out. Thanks.
    4x4_Angel and Grumpy Uncle like this.
  8. Jun 11, 2018 at 7:30 PM
    Gravyacres
    Mississippi
    2018 CM TSS
    If that’s it, seems like poor planning for the tss edition wheels/tire combo.
  9. Jun 12, 2018 at 11:36 AM
    Bearcat
    Bearcat New Member
    Nikolaus
    2018 MGM SR5 CM
    I noticed a clunk sound on mine every time I pulled out of my drive. I read a thread on here about the ABS system performing a system check that sounds like a clunk. I chalked it up to that since I can't find any signs of rubbing. It will do it when I first start up and take off straight as well. Usually I am turning out of the drive or a parking spot which is what originally lead me to believe it was a rub.
    Joe333x and Gravyacres[OP] like this.
  10. Jun 12, 2018 at 11:54 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The ABS check only does it once, when you hit 15mph. If you're hearing multiple clunks, you probably have some other issue.
    Gravyacres[OP] likes this.
  11. Jun 12, 2018 at 11:58 AM
    Gravyacres
    Mississippi
    2018 CM TSS
    Thanks,
    It only does it once, every day. Hopefully that’s the ABS check. Thanks.
    Boerseun and joonbug[QUOTED] like this.
  12. Jun 12, 2018 at 12:09 PM
    Bearcat
    Bearcat New Member
    Nikolaus
    2018 MGM SR5 CM
    Same here. I only hear it once. I am almost certain it happens at less than 15mph since it happens usually when I am mid turn when pulling out of my drive way. I'll look for some signs of rubbing just to be safe. My truck has the TSS appearance package with black 20" wheels and the BFGs.
  13. Jun 12, 2018 at 12:23 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Eclipsed & Floating and joonbug like this.
  14. Jun 12, 2018 at 4:06 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    My popping(s) usually deal with primarily cherries or trying to stand up from a squatting position, but the time I heard popping on my truck was resolved by just lifting the truck up and looking under it. Never happened again, but absolutely couldn’t make it stop no matter what I did. And, it only happened when I was turning though no specific radii made it happen.
    Bearcat and TheBeast like this.
  15. Jun 12, 2018 at 4:35 PM
    Gravyacres
    Mississippi
    2018 CM TSS
  16. Jun 13, 2018 at 3:58 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Is the noise coming from the front or back? I had a popping noise coming from the back of mine, while turning. The noise turned out to be the parking brake cable was the culprit. I loosened the mounting clips and wiggled it let it settle then tightened the clips. No more noise.
    -Jason
  17. Mar 14, 2020 at 10:00 PM
    tundra822
    tundra822 New Member
    Nicholas
    2020 cement tundra trd
    My 2020 tundra seems to be doing the same thing. Have you found a solution to this?
  18. Mar 15, 2020 at 4:47 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    If it is a single pop when you start driving, it is the ABS self-check and is perfectly normal. Since most people start their daily driving backing out of their driveway they associate the popping noise with backing up and turning, but in reality it has nothing to do with that.
    If it is actually every time you back up, then you might be rubbing, but I would think your's is the ABS.
  19. Mar 15, 2020 at 4:58 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Does the noise occur with movement in the front suspension? For example, if your driveway has slope, does the "pop" occur with the wheel fully turned when you roll across the paving angle or ribbon curb to the street crown?
    Is the noise localized to suspension side on the inside of the turn?, Or on the outside of the turn? Or, does the noise seem to always come from same location?
    Have you tried generating the noise with slightly longer turn radius, i.e. wheel turned just short of "all the way"?
  20. Jan 22, 2021 at 5:36 PM
    Jarekbal66
    Jarekbal66 New Member
    2021 toyta tundra
    None
  21. Jan 22, 2021 at 5:37 PM
    Jarekbal66
    2021 toyta tundra
    None
    I have 1 week old 2021 toyta tundra same problem every time i start driving going ask on my first servise whats going on
  22. Jan 22, 2021 at 6:19 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I just bought one too. It will happen at 6mph when you first drive each time you turn on the truck. To prove, drive backwards past 10mph, you wont hear it. Drive forward under 5mph for a while and you wont hear it. Soon as you get to 6mph....clunk. abs check.
