Portal Axles for 200 series…who will be the first to make these work on their Tundra?
Discussion in 'General Tundra Discussion' started by Terndrerrr, Nov 19, 2022.
  1. Nov 19, 2022 at 5:41 PM
    Terndrerrr
    Terndrerrr [OP] 925000 miles to go
    Music City
    6UR-FE
    No affiliation. They’re in, um…Russia. Just thought this was really cool. Would love to see someone fit this to their Tundra. Would it work? Or is part of what makes it so great that the 200 series is fulltime 4wd?
    “By increasing the clearance by 130mm and reducing the gear ratio by 35%, portal gearboxes WEREWOLF can multiply improve the vehicle's cross-country ability, increase torque and while unloading the transmission.”
    https://werewolftech.com/en/catalog...yota/portal-axles-for-toyota-land-cruiser-200
    Great video:
  2. Nov 19, 2022 at 5:51 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    I haven't seen any boxed portals like that hold up to regular high speed use. I imagine it's more trailer queen territory. In which case, just solid axle the front, drop a Dana 60 in the rear and toss 40s at it.
    300BLK likes this.
  3. Nov 19, 2022 at 6:01 PM
    Terndrerrr
    Music City
    6UR-FE
    They’re certainly not easy on them in that video.
  4. Nov 19, 2022 at 6:07 PM
    AZxp
    AZxp New Member
    I must have missed the high speed portions.
    My point is, if it's not a reliable highway cruiser but rather a low speed crawler; there are much better ways to spend your money
    reywcms likes this.
  5. Nov 19, 2022 at 6:23 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    74Weld messes around with portals. I bet if anyone does a tundra kit, it’ll be them
    rockmup, snivilous and Terndrerrr[OP] like this.
  6. Nov 19, 2022 at 6:30 PM
    Terndrerrr
    Music City
    6UR-FE
    I see. I took your first comment “regular high speed use” to mean desert running, but are you just saying that portals aren’t good for cruising on the highway? But a solid axle swap, Dana rear, and 40s are? o_O
    I just thought that this stupidly expensive bolt-on 5” lift and regear was cool. :notsure:
    Speaking of highway cruising, where can I get a set of those tires on that 200 series? :rofl:
  7. Nov 19, 2022 at 6:38 PM
    AZxp
    AZxp New Member
    I recommend rereading my comment.
    Wynnded likes this.
  8. Nov 19, 2022 at 7:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I don’t care about any axle comment, I just want to know about the elk in your avatar. :blahblah:
  9. Nov 19, 2022 at 7:07 PM
    Squatting Pigeon
    Holden
    North Texas
    Elk hunter V2.0
  10. Nov 19, 2022 at 7:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Still just a wannabe Elkhunter.
    Only elk tag soup so far…
    Mailboxes are safe for now.
  11. Nov 19, 2022 at 7:52 PM
    Terndrerrr
    Music City
    6UR-FE
    Yep, I misunderstood you. I haven’t slept in two days.
    Very cool. The @74weld portal’d trophy truck is pretty nuts.
    https://www.instagram.com/reel/Ck3pBKkpBsO/
    rockmup likes this.
  12. Nov 19, 2022 at 7:59 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think the hubs are identical between the 200 and the Tundra, so I doubt there's any or minimal additional modification needed to run them. @Cruzer should do it.
    And if you're gonna go to the effort to solid axle, go to the effort to portal :D it's not like portals are exclusive to ifs.
    Cruzer, des2mtn and Terndrerrr[OP] like this.
  13. Nov 19, 2022 at 10:07 PM
    blenton
    blenton New Member
    Portal axles are cool.
    HMMWV’s all came with them so they can put up with some abuse. Volvo used them recently on the XC90 so they can be refined and handle high speed. They are just another gear box - like a gear driven transfer case or axle gears - so as long as the gear tolerances are correct and you keep them lined, they should work well.
    Maybe I’ll but them on ‘my other tundra’ wish list…
    Terndrerrr[OP] and Mater like this.
  14. Nov 20, 2022 at 12:14 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They make kits for the tacos too. They’re Ukrainian not Russian too
    Neat stuff. Way out of my budget
  15. Nov 20, 2022 at 12:23 AM
  16. Nov 20, 2022 at 4:39 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    The Volvo boxes are too light for anything beside fire roads, they've been making them in one version or another for 40 yrs or so that I know of.
    The Hummer boxes are good but not cheap anymore, if you can find them and still need a bit of work.
    https://www.ebay.com/itm/2848680925...lCjF6zBuVNkz6Sd57N5bkW96OFyKiRnBoCBa8QAvD_BwE
    If you're doing portals then theres no need for a 60 or a 14b, aftermarket housing appear to be the way to go. Theres quite a few guys running 8" toy centers.
    Terndrerrr[OP] likes this.
  17. Nov 20, 2022 at 7:40 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    :rofl: Those things are crazy expensive, I’ll pass.
    snivilous[QUOTED] likes this.
  18. Apr 30, 2024 at 7:57 AM
    coTony
    Tony
    Montrose, CO
    Well that would get 40’s on the Tundra :benchpress:
  19. Apr 30, 2024 at 8:03 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I remember the owner of 74 Weld saying that he was working on portals for the LC200, and by extension our trucks. It was on an episode of the Snail Trail 4x4 Podcast. Pretty good listen packed with all sorts of off road and engineering knowledge
  20. Apr 30, 2024 at 8:17 AM
    Talon2006
    Talon2006 New Member Vendor
    I do know Bronc Buster is working on portals and is wanting to extend them to other trucks. Shoot him an email.
    https://broncbustertx.com/pages/contact
    I have portals on my bronco... They are freaking awesome.
  21. Apr 30, 2024 at 9:54 AM
    SD Surfer
    Bruce
    So Cal
    I think Jefe's on Matt's Offroad Recovery put 74Welds on his Bronco.
    coTony likes this.
  22. Apr 30, 2024 at 10:03 AM
    coTony
    Tony
    Montrose, CO
    He had to do something, the angles really sucked for clearance
  23. Apr 30, 2024 at 10:45 AM
    SD Surfer
    Bruce
    So Cal
    Yeah, I remember in a couple of the vids being really surprised how much he was scraping.
    coTony[QUOTED] likes this.
