Possible to drive my 4x4 without front cv shafts?
Discussion in '1st Gen Tundras (2000-2006)' started by KarmaKannon, Jun 3, 2019.
  1. Jun 3, 2019 at 7:52 PM
    KarmaKannon
    KarmaKannon [OP] Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I have a few crazy things going on and I'm looking at possibly taking the front cvs off is possible and driving that way for a couple weeks or months. I looked around and it looks like the 2wd and 4wd knuckles are the same. If this is correct, what would I need to acquire to pull my cvs off and run without them for a while.
    Timing and other responsibilities would really be easier if I can do some front end fiddling and not worry about immediately taking care of the cvs. I know this is a strange question, but that's what I'm here for.
  2. Jun 3, 2019 at 8:00 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I think you will loose some gear oil. Prob not a good idea.
  3. Jun 3, 2019 at 8:02 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I wouldn’t recommend it. Leaving those holes open on the sides of your transfer case is just asking for dirt and other garbage to collect in there.
    I think I heard somewhere that it could affect the wheel bearings somehow as well, but don’t quote me on that. I could just be making it up.
  4. Jun 3, 2019 at 8:07 PM
    KarmaKannon
    Utah
    Some junk
    Ah shiza. They are splined and not the flanged style? I guess I just assumed they were the style that bolted onto the front diff with a flange. Ah hell, I guess I could pull the whole diff for a couple months. My issue is just trying to get custom axle shafts for the cvs if I find myself fiddling around a bit too much and needing axtra length.
    Probably just a better idea to pull a spare cv from a yard for disassemble and to spec out a custom shaft or bend over for total chaos $800 shafts.
  5. Jun 4, 2019 at 6:01 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yeah or just buy on and return it after your done with it.
  6. Jun 4, 2019 at 6:10 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    You can do it. Pull the whole axle assembly on each side. I have a couple friends who had to pull one side on the trail because the cv failed.
    No 4wd and you’ll need to plug the holes in the front diff.
    joonbug likes this.
  7. Jun 4, 2019 at 10:54 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    You need the spindle side in to keep the bearings in and not cause damage. I found a aftermarket CV on Amazon for $13 shipped and stuck it in the truck for an emergency spare. Might be worth just getting a cheap one to work on, rather than all the work and potential damage pulling them.
  8. Jun 4, 2019 at 10:55 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What exactly are you trying to do that you need to pull ur axels?
  9. Jun 4, 2019 at 4:55 PM
    KarmaKannon
    Utah
    Some junk
    That might be a good idea. I was assuming it was like my old Cherokee and it needed a spindle for the bearings to stay together on the 2wd. Makes sense. Thanks.
  10. Jun 4, 2019 at 5:01 PM
    KarmaKannon
    Utah
    Some junk
    Still trying to decide if I want to do a shock upgrade with a new upper arm or if I want to make a new lower arm at the same time. To be honest it might be easier to make a new lower arm to fit the shock I have in mind.
    And yes... All suspension building warnings apply. Not my first rodeo on building a arm suspensions so no worry there. This would be however, my first a arm build with 4wd.
    Anywho I'm not really worried about building it all, I'm mostly not interested in paying for the TC extended shafts right now and I'd really like to see if I can find someone that can make me some extended shafts cheaper than $800. I'm not quite desperate enough to sleeve and weld them right now haha. I might sleeve and weld one for mock-up though.
  11. Jun 6, 2019 at 10:42 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    Or spend $42 at Rockauto. Do you need super strong front shafts?
  12. Jun 6, 2019 at 11:05 AM
    KarmaKannon
    Utah
    Some junk
    That was what I thought but total chaos notes on their website that their extended shafts only fktt oem cvs. I have no clue if they are actually different or not.
    I don't know if I need super strong shafts or not. I'd imagine stock strength would do it.
  13. Jun 11, 2019 at 5:20 AM
    foxtrapper
    2003 SR5
    Ah, so you're going/fabricating long suspension arms? That would call for longer shafts than stock.
  14. Jun 11, 2019 at 10:14 AM
    KarmaKannon
    Utah
    Some junk
    Yes it would, but it would be nice not to buy those right now. No matter I actually just found them for $630 so I must have been mistaken when I was thinking they were $800. I was hoping to get by without the shafts and 4wd altogether for a while but forcing me to get new shirts upfront is probably the easier way than sourcing them while driving without 4wd later.
