Possible to turn down screen brightness?
Discussion in 'Audio & Video' started by W3agle, Jan 12, 2022.
  1. Jan 12, 2022 at 12:39 AM
    W3agle
    W3agle [OP] New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    Aftermarket head unit:
    JVC KW-Z1000W - Manual
    I can’t find anything on this site or the rest of the internet. But I’m pretty ignorant to car audio in general.
    I’m good at navigating menus though. And I definitely can’t find any setting for screen brightness.
    can you turn the screen brightness down on these things? It’s blinding at night.
  2. Jan 12, 2022 at 2:16 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Looks like the dimmer isn’t adjustable. You can turn off the display if it’s that bright, or maybe put a tint over the screen?
    W3agle[OP] likes this.
  3. Jan 12, 2022 at 3:20 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I haven’t dealt with this model, but here is what someone said on a Ram forum.
    “there are TWO settings that change the screen brightness. One is in the menu as “Brightness.” The other is in the menu as “Backlight.” I discovered that the brightness setting really didn’t dim it much, but the backlight setting really knocked it down to where I could barely see it.”
    this looks to be on page 63.
    I just installed an Alpine unit in my daughters car for Christmas and there was no dimming wire for headlights like most other units. I guess it uses a sensor on the front of the unit to detect night and auto dims that way.
    They also said on that forum that many people use the wrong dimming wire? So check that if your big complaint is too bright at night with lights on.
  4. Jan 12, 2022 at 8:56 AM
    W3agle
    San Diego, CA
    This is super helpful thank you so much! I'm definitely curious about the dimming wire. It sounds like it should dim when the headlights come on? Very cool.
  5. Jan 12, 2022 at 9:01 AM
    BoysandHisToys
    Central Virginia
    Yes, there should be a wire that hooks up to your factory harness. It tells the radio when your lights come in so it knows to dim the lights on the radio.
    KK6PD and W3agle[QUOTED][OP] like this.
  6. Jan 12, 2022 at 10:58 AM
    BoysandHisToys
    Central Virginia
    Page 93 shows the electrical wiring. Should be the Orange/White wire with “ILLUMI” label on it.
  7. Jan 12, 2022 at 12:56 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  8. Jan 12, 2022 at 2:07 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's probably a menu setting. Check page 65, set dimmer to "sync".
  9. Jan 12, 2022 at 2:12 PM
    Ericsopa
    Ericsopa Old man and the sea
    Page 63 of your manual addresses screen brightness, contrast, etc. in the setup section. That doesn't work?
  10. Jan 13, 2022 at 9:45 AM
    W3agle
    San Diego, CA
    You guys are amazing. Can't wait till it gets dark tonight to confirm if I can make it work via software with the 'sync' button on page 65. Maybe that just needs to be turned on.
    If not, tomorrow I'll get into the harness and see if I have the ILLUMI wire hooked up correctly.
    Seriously thank y'all so much I was super lost. I owe y'all pizza and beer.
  11. Jan 13, 2022 at 10:20 AM
    BoysandHisToys
    Central Virginia
    I’ll fly out to SD and we can go hang out in the gaslamp district!
    W3agle[QUOTED][OP] likes this.
  12. Feb 25, 2022 at 1:05 PM
    W3agle
    San Diego, CA
    Alright so I’m working on this now. It looks like the installer may have tried to hook up the orange illuma wire? This bundle of yellow and orange wires are coming over from the head unit. The orange wire tires into this blue wire that goes through the firewall. The yellow wire taps into a small gauge teal wire.
    Any hints? The head unit never seemed to auto adjust before. I don’t think the orange wire is hooked up correctly.
  13. Feb 25, 2022 at 1:41 PM
    BrandonL812
    Brandon
    Did they use the idatalink maestro radio adapter harness? TO2 or TO3?
  14. Feb 25, 2022 at 1:43 PM
    W3agle
    San Diego, CA
    Yep we used the idatalink maestro radio adapter harness. TO2.
  15. Feb 25, 2022 at 2:16 PM
    BrandonL812
    Brandon
    Then there’s no reason he had to run those two extra wires. Unless they are for something else. On the TO2 harness there is a dimmer wire already. That dimmer wire will tie into the jcv dimmer wire. I’m not sure why your installer ran the extra wires.
    take a look at this photo. On the TO2 harness, the Illumination wire is Orange. The Illumination wire on the jvc/kenwood is Orange/White. These two connects together.
    3DA9DCFA-E79F-47F0-9ADC-D02A6FEA638A.jpg 40EDAC71-66EC-42B9-AB58-1E1BDB2B9AEA.jpg
  16. Feb 25, 2022 at 3:03 PM
    W3agle
    San Diego, CA
    I was wrong on those wires. They were run by another installer for my ditch lights that connect at the switch panel below the climate controls.
    This is what I’m looking at on the back of the HU. Any idea where I would begin troubleshooting? I don’t see an orange wire going into the maestro!
  17. Feb 25, 2022 at 3:10 PM
    W3agle
    San Diego, CA
    Ok I’m piecing this together bit by bit. They didn’t use all the wires. The first photo shows a bundle that was tied off. The second photo shows the orange and white wire coming out of the HU. Final photo shows the orange wire from the maestro. Looks prepped and everything. Odd huh? So I’m guessing that orange and white wire is cut somewhere in that bundle. Not sure if I want to go to the trouble to undo that.
    For starters, I only have bigger wire on hand. Like 12ga or something haha
    *edit* it’s weird to me that the orange and white wire isn’t with this bunch I unraveled.
  18. Feb 25, 2022 at 3:21 PM
    BrandonL812
    Brandon
    You have to unravel the tape and get to the wires. Then connect them together.
  19. Feb 25, 2022 at 3:22 PM
    W3agle
    San Diego, CA
    OK! Got it. It was just coiled up way back in there. So I’ll strip this and finish crimping it! So far so good. Let’s see if it actually makes the screen flicker… I asked James at tech12volt if he’d heard of that phenomenon and he said never. Here’s to hoping!
    BrandonL812 likes this.
  20. Feb 25, 2022 at 3:50 PM
    BrandonL812
    Brandon
    Easy fix. Plus there’s a butt connector already there. This should fix the issue.
  21. Feb 26, 2022 at 4:20 AM
    BoysandHisToys
    Central Virginia
    So what was the outcome? Did it work last night?
    reading from your post yesterday did the installer just forget to hook up the orange and orange/white wires?
  22. Mar 2, 2022 at 6:36 AM
    W3agle
    San Diego, CA
    Last night was the first night I was able to test. Oddly enough, I don't think it's working. No noticeable change in screen brightness when turning the headlights off/on. No flicker either though!
    Think there's anything on the maestro to2 side of things that wasn't plugged in / set up correctly?
  23. Mar 2, 2022 at 11:43 AM
    BrandonL812
    Brandon
    I’ll test mine out tonight and see if it does anything. Im pretty sure it dim down.
  24. Mar 2, 2022 at 8:44 PM
    BrandonL812
    Brandon
    Here’s my finding. The dimming function will only dim the buttons and accent light located beneath the screen. That’s it. The main screen will NOT dim when headlights are ON.
    You can manually change the brightness from the main screen. Must be on any Source screen to change. Hit Function button. Pick Screen Adjust option at the top of screen. You can make it brighter or darker.
    535C4092-2A3D-4270-8273-C2C58B13D294.jpg C220C57B-BD60-4F8A-B37C-287046616C97.jpg
