Post your OEM factory running boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by dadtrucklife, Aug 1, 2024.
  1. Aug 1, 2024 at 12:49 AM
    dadtrucklife
    dadtrucklife [OP] New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    I need to get some running boards for the family and thinking of sticking with oem factory for simplicity and fit finish. It seems there are various oem factory options- tube, predator, flat platform- I might be missing others. Think I’m leaning towards the flat platform style since it provides maximum step area, discrete, and it blends in better with the truck’s lines. Can you post yours up? TY!
  2. Aug 1, 2024 at 4:36 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    The OEM stuff is top shelf. I have like both sets of Toyota that I have had. In both cases they stuck out the same amount and were the same distance down from the sill.
    I can take more pictures if you would like.
    I have these currently. I believe that they were simply called "running boards". I can get the part number if you would like. I like them a lot because they hide well. They are aluminum and the top is all rubber. I don't like them because the rubber does start to wear where they are used a lot. Not bad but after three years you can see it:
    I have had these in the past. Mine were in stainless finish but they are also available in black. I liked these a lot as well but they were big and hung down a long way. :
  3. Aug 1, 2024 at 6:16 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
  4. Aug 1, 2024 at 6:25 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    @dadtrucklife
    I'll second the quality and longevity of some of the OE products; the ones posted above on the blue truck w/that are satin and have large black steps are the ones on my '08. So, they've got 16 years and over 285k miles on them; still in great shape; have a super wide step w/good positive friction for wet, snow and icy conditions; and they've held up way better than the ones on my '21 (which appear to be the same ones you have currently).
    I wonder if a lot of us didn't end up w/some kind of dealer installed steps that are not OE quality.
    j-utah and dadtrucklife[OP] like this.
  5. Aug 1, 2024 at 10:20 AM
    dadtrucklife
    Think the running boards on your lunar rock is the oem version I’m leaning towards because it’s the most discrete and it seems very functional with a wide step area. Basically anywhere is a step. Would you mind posting some close ups and also a few shots of how it attaches to the truck? TY!
    Don't think I’m a fan of the tubular style because it sticks out to the eye. I want something discrete and not as noticeable.
    Tripleconpanna likes this.
  6. Aug 1, 2024 at 10:32 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    my previous 2011 CM
    These were a standard item coming from SET district but you should
    be able to order them from https://cordautomotive.com/cord-automotive
    This is where i ordered from
    I can get you an email if you need.
    j-utah likes this.
  7. Aug 1, 2024 at 10:34 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
  8. Aug 1, 2024 at 10:35 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Let me take some pics in about an hour.
  9. Aug 1, 2024 at 11:05 AM
    dadtrucklife
    Is this style an option on my 2021? Believe these are oem cast aluminum but not certain it is available to Tundras. I rented a 4Runner recently and it had these on it which were very functional.
    j-utah likes this.
  10. Aug 1, 2024 at 11:08 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Here are three photos. One shows the wear after three years. One shows the mounting brackets. One shows the bolts used (come with the steps). It uses threaded holes already in the cab. Sorry, the truck is a little dirty.IMG_8081.jpg IMG_8082.jpg IMG_8083.jpg
    dadtrucklife[OP] likes this.
  11. Aug 1, 2024 at 11:08 AM
    SD Surfer
    Bruce
    So Cal
    I love the functionality of mine but hate the look.
    I'm not a big fan of chrome to begin with but I also don't like how low they hang. It ain't a rock crawler but I do a bit of desert exploring, mild off roading, etc. and these just seem really vulnerable to catching the odd rock.
    At some point I'll likely swap out for something tucked up a little higher. Definitely like having something though since I'm old and short. (and ageing and shrinking sadly) :(
    I like the "Wheel to wheel" versions that have a third step in front of the rear wheel since I step on the back end of mine frequently to fasten/unfasten the surf racks.
  12. Aug 1, 2024 at 1:40 PM
    dadtrucklife
    TY very much!!
  13. Aug 1, 2024 at 2:48 PM
    dadtrucklife
    @mverkaik, what is the running board made of? How’s the weight?
  14. Aug 2, 2024 at 4:08 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    The running board is aluminum with rubber over the top. The brackets that mount to the truck are steel. They are not very heavy. Maybe 10 pounds per side. I put them on all by myself and I was able to hold them in place with one hand while starting the fasteners with the other.
  15. Aug 2, 2024 at 4:16 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
  16. Aug 2, 2024 at 4:34 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Yep, these are available for the Tundra. Personally, I regret not going with these
    I have the predator tube steps. They're aluminum, so they won't rust in these Midwest winters and they're very light, but very stout. I was nervous about them being slippery in winter, but that wasn't an issue last winter. They function well and look pretty good. I just prefer the cast aluminum boards
  17. Aug 2, 2024 at 6:49 PM
    TimmyTundra21
    TimmyTundra21 New Member
    2021 Magnetic Gray TSS
    TRD Rear Sway Bar, Spotter Mirror with BSM, TRD Pro Headlights/Fog Lights
  18. Aug 3, 2024 at 9:38 AM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
  19. Aug 3, 2024 at 10:25 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    IMG_3026.jpg These came with the truck. I tell my wife they look like pontoons on a pontoon boat.:rolleyes: I don’t like them. I’ve been looking at other running boards and sliders. But can’t make my mind up. :notsure:
  20. Aug 3, 2024 at 10:30 AM
    dadtrucklife
    Lol your assessment is pretty spot on.
  21. Aug 3, 2024 at 3:54 PM
    dadtrucklife
    Now the next question is where can I get it for the best deal. So far my search lands me at BAM wholesale parts. Shipping seems reasonable too. Wonder if anyone offers free shipping?
  22. Aug 20, 2024 at 11:01 AM
    dadtrucklife
    Is it true there is no gap between the body and classic running board? I need something snug up to the body. I’d like to cover up the silver Talon cat shield bracket on my frame. Do you think these running boards have any door ding protection?
    I am dabbling at the thought of Go Rhino RB10 or RB20 but it sounds like those have some decent gap which I’m trying to avoid.
  23. Aug 20, 2024 at 4:21 PM
    Drootz
    Drootz Beer me!
    NorCal
    2021 Tundra MGM Platinum 4x4
    TRDPro Fox Suspension, TRD Black Chrome Exhaust, TRD Pro Wheels, TRD Skid Plate, TRD Rear Sway Bar, TRD Air Filter, TRD Flow accelerator, Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added, TRD Shift knob, Remote Tailgate Lock, TRD Parts Added: Fox Suspension, Black Chrome Exhaust, BBS Pro Wheels, Skid Plate, Rear Sway Bar, Air Filter, Flow accelerator, & Shift Knob Other additions: Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added. Wanted list: Color matched exterior handles
    I must say I am very happy with these OEM running boards.
    Cody1060 and dadtrucklife[OP] like this.
  24. Aug 20, 2024 at 9:47 PM
    dadtrucklife
    I don’t recognize these oem running boards? What model?
  25. Aug 21, 2024 at 4:28 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    They fill the gap very nicely. They have a piece of rubber that contacts the bottom of the rocker.
    I did not want a step that stuck out too far. There are probably better ones out there for door ding protection.
    My door ding protection is where I park :) Unfortunately that is not as effective as I would like. Notice the king of all door dings under my passenger door handle. I don't know how you can make one that big. It runs from the handle all the way down to the style line toward the bottom of the door.
  26. Aug 22, 2024 at 2:46 PM
    Drootz
    Drootz Beer me!
    NorCal
    I have a 21 Platinum and I just called Toyota to find out the part number for you and according to my VIN he said I had the following running boards Classic Black PT925-34183
    They are the exact same ones as pictured here https://www.tundras.com/threads/running-boards-factory-toyota.32145/#post-796171
    However, in this post they are mentioned as a KG option. The parts guy I talked to didn't say anything about a KG option, but thought I should mention it in case it was important.
    Did a little more digging see these posts https://www.tundras.com/threads/pics-of-your-running-boards.27387/page-8#post-2038396
    and also
    https://www.tundras.com/threads/que...g-boards-step-assist-parts.19872/#post-457612
  27. Aug 22, 2024 at 2:48 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    I’ve never been a fan of running boards or steps. I’m considering on taking mine off soon. But for now the kids enjoy using them.
  28. Sep 2, 2024 at 12:50 PM
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    These came new on my truck. I left them there because they fit in with the theme I was going with. Only truck I ever had with boards on it. My new tundra has electric boards. IMG_2407.jpg
    bucketlintels02 likes this.
  29. Sep 2, 2024 at 5:52 PM
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    I have had both OEM running boards on my 2021 1794 toyota tundra. I like the all black flat running because they tuck under and hide the support brackets. I do have the other OEM running boards ready for a new home
  30. Sep 2, 2024 at 9:23 PM
    scottgri
    scottgri New Member
    2019 tundra limited offroad
    None
    What is the part number for the all black running boards on your tundra.Do you have any pictures of how much they stick out from
    The rocker panel
