Power for trailer winch
Discussion in 'Towing & Hauling' started by stump54, Sep 27, 2022.
  1. Sep 27, 2022 at 5:15 AM
    stump54
    stump54 [OP] New Member
    I'm looking to power the winch for loading vehicles on the car hauler, using either the trailer connector or the rear AC. In the past I ran a separate power line from the battery to the rear-mounted connector. I'm hoping to use one of the existing power sources on this new ('22) tundra.
    So, anyone know of a connector or converter I can use to power from the DC trailer receptacle or the bed-mounted AC?
    Thanks
  2. Sep 27, 2022 at 6:31 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    How many amps will the winch draw? Watts of the accessory (winch) divided by 12 (volts) = amps. You will want to be sure you do not connect the winch to any undersized wiring.
  3. Sep 27, 2022 at 7:00 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Best bet is a smaller deep cycle battery mounted on the trailer that gets topped off by the truck when driving. I don't think the trailer hitch wiring will support the draw of a winch.
  4. Sep 27, 2022 at 8:47 AM
    stump54
    Do you know any sources for an auxiliary battery "kit"?
  5. Sep 27, 2022 at 8:49 AM
    stump54
    I'm sure the math would show it exceeds the trailer light/brake wiring, but any idea if someone makes an AC converter I could plug in the the bed outlet?
  6. Sep 27, 2022 at 2:22 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    You're going to be pulling too much juice to tap that wiring. To pull 6k pounds up a ramp you're looking at ~250 amp draws
  7. Nov 18, 2022 at 6:11 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    I think you'll have to run that battery wire. At least a 1 or 2 gauge I would think.
    I have a hitch winch and run it off 30ft 1 gauge jumper cables. I do this because I use it for off roading. On multiple cars.
  8. Nov 18, 2022 at 6:35 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This is the way. Don’t draw directly from the truck battery to power a winch on a trailer.
    2mchfun and NewImprovedRon like this.
  9. Nov 18, 2022 at 6:38 PM
    I have an Aux Battery on the trailer, charged by the power from the plug, in addition I have a solar panel that is mounted to my gooseneck.
    2mchfun, snoope, Ericsopa and 2 others like this.
  10. Nov 20, 2022 at 12:36 PM
    baraynavab
    Atlanta
    Why not directly draw from the cars batter again?
  11. Nov 20, 2022 at 1:24 PM
    mountainpete
    1. Winches can draw huge amps - often over 500. To safely extend +20 feet you may need 0 ga (depending on the winch). That’s is big, heavy and Tundra payload is weak. Plus, if the gauge is too light, fire can happen. I’ve seen it.
    2. Always protect a starter battery. Winching can drain a battery faster than an alternator can recover. Would really stink if your truck can’t start while winching on the trailer.
    3. Your 7 pin wiring is already designed to low amp charge a trailer battery while driving. It’s how every travel trailer works.
    4. Adding a battery to a trailer is super easy and cheap. You can even use Jumper cables to the winch. It’s a different use case than a rear truck winch.
    bulldog93 likes this.
  12. Nov 20, 2022 at 2:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    And to add to what @mountainpete said, that is also the way electric over hydraulic dump trailers work. The deep cycle or dual purpose battery supplies the high current needed for the pump, and is recharged though the charge wire on the 7 pin connector while driving.
    Because of the high draw in use, the truck should be shut off or the trailer cord should be disconnected from the truck when winching or operating a dump trailer to prevent blowing the charge fuse.
    That, OR install a self-resetting circuit breaker on the charge wire in the trailer with a lower amperage rating than the truck’s fuse. Like a 20 amp.
    t300, 2mchfun and mountainpete like this.
  13. Nov 20, 2022 at 5:47 PM
    baraynavab
    Atlanta
    Yes Agreed on the winches drawing lots of amps.. so I do have a 30ft 1 gauge cable its big and heavy Copper wires... but I use the winch for off road recovery.. I wonder if I should put in an inline fuse kit with this setup or as @landphil said a self resetting circuit breaker.
  14. Nov 20, 2022 at 8:36 PM
    mountainpete
    Are you running a rear winch or on a trailer?
    If it’s a rear winch, it safest to connect in a high amp interrupter so the cable is dead unless you turn it on.
    There are less pricy and more manual ways of doing it, but this is an example of one: https://www.warn.com/power-interrupt-kit-62132
  15. Nov 21, 2022 at 8:47 AM
    baraynavab
    Atlanta
    So the setup I am going for is hitch mount winch for off roading which is removable and transferable from car to car. I have 2 the Tundra (not as serious) and the Land cruiser I go off roading with and dont want to mount hitches on both of them. So an easy way to have a hitch with it is using a Hitch mounted winch. As mentioned I am use the long 30ft jumper cables 1 gauge to get the power back to the winch.
    Is there any other NOT $129 way to have a fuse box on this setup? I am thinking a simple in line ANL fuse should do the job.. or if not get a 500 amp in line switch...
    Additionally I think the fuse has to closer to the battery or does it matter when in the link its hooked?
    vtl likes this.
  16. Nov 21, 2022 at 9:41 AM
    mountainpete
    Ah, makes sense... thanks.
    Just a personal opinion, but I would spend based on how much I use it and where. If I was running the winch once a year and primarily pulling other people out or in fairly predictable situations (like not soaked in mud), I would just use jumper cables like you plan. The alligator clamps won't be loving max pulls/loads but it's probably good enough for the occasional winching.
    If you want something more permanent and you decide to mount the wire (if it's good quality, you can even just mount the jumper cable), I wouldn't fuse it. I would just put in a cut off switch close to the battery and keep it off unless you are using it.
