Power steering rack leaking
Discussion in '1st Gen Tundras (2000-2006)' started by jerry91, Jan 24, 2021.
  1. Jan 24, 2021 at 11:08 AM
    jerry91
    jerry91 [OP] New Member
    2005 Toyota Tundra SR5 RWD
    Help my power steering rack leaking at the pinion input shaft. I did some off-roading I think I put too much pressure on power steering. Wondering if I can replace just seal without replacing the whole rack. I saw it leaking right on the top where it connects. Any help is appreciated
  2. Jan 24, 2021 at 4:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i mean.. you can buy just the seals.. but to replace it is pretty involved. its just easier to throw a reman in. rack rebuilds are not for the faint of heart from what im told.
  3. Jan 24, 2021 at 6:14 PM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    My steering rack is leaking also. Just probably gonna throw a rack in it here soon.
    jerry91[OP] likes this.
  4. Jan 25, 2021 at 5:54 AM
    Richid
    Richid New Member
    Ya - they are like transmissions. By the time you get all the specialty tools needed to rebuild it, you're at the same price as a reman.
    Racks are pretty easy in these, plenty of room - well, except for the center mount bolt.
  5. Jan 25, 2021 at 6:01 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Agreed with replacing the rack. If one seal has failed... more will follow. I looked into rebuilding mine last summer “just for the experience” but after reading the manual, I came to the conclusion that replacing was much wiser and easier.
    Might as well do the lines also. You’ll probably damage the B nuts removing them from the rack unit during removal. Corrosion and all that...
  6. Jan 25, 2021 at 10:28 AM
    jerry91
    Which reman rack you guys recommend? Is the rack same from 2000 to 2006. I think what i saw was v6 1st gen uses different rack maybe Iam wrong
  7. Jan 25, 2021 at 11:44 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I went with a remain off Amazon from a seller with good reviews. I've had no problems with mine. I wouldn't go with the cheapest one available but I don't think a new Toyota unit in necessarily needed either.
    I would assume the rack would be the same for a V6 or the V8, maybe different for 4wd vs. 2wd.
  8. Jan 25, 2021 at 12:14 PM
    jerry91
  9. Jan 25, 2021 at 12:20 PM
    Richid
    Richid New Member
    I've never had a problem with any remans - even the cheapest ones.
    Any of those namebrands are probably getting them from the same source, so you should be fine with that one.
