Power Tailgate Lock for 2020 Tundra Platinum Crewmax PK3B6-34JS0
Discussion in '2.5 Gen Tundras (2014-2021)' started by Smarks, Nov 21, 2019.
  1. Nov 21, 2019 at 9:37 AM
    Smarks
    Smarks [OP] Gravity Sucks!
    2020 Tundra Crewmax Platinum
    TRD Dual Exhaust, TRD Front and Rear Sway Bars
    Does anyone have experience installing one of these? I have the part but have yet to install it. Seems a little different then the pop and lock and I can't find any good instructions on the web.
  2. Nov 21, 2019 at 10:00 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Haven't done it (yet) but here are the instructions. Keep me (us) posted on how it all goes!
  3. Nov 21, 2019 at 10:52 AM
    Smarks
    You are the man! This is exactly what I needed. I'll keep you posted.
  4. Nov 21, 2019 at 10:55 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Can you post pictures of the parts please.
    619Tundra likes this.
  5. Nov 21, 2019 at 10:56 AM
    bmann7
    WA
    See signature line
    I am but a messenger.
  6. Nov 21, 2019 at 11:03 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    :popcorn:
  7. Nov 21, 2019 at 11:05 AM
    bmann7
    WA
    See signature line
    If you take a look at the document I shared, it shows most of the parts along the way.
  8. Nov 21, 2019 at 11:17 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yea but a quick picture of what’s in the box wouldn’t hurt
  9. Nov 21, 2019 at 11:50 AM
    Smarks
    I’ll post pics when I get home, no problem
  10. Nov 21, 2019 at 11:55 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Can’t believe that’s not standard equipment already! I got lucky and it was on the truck I bought, just crazy how loud it is.
    AggiePhil and BravoDeltaRomeo like this.
  11. Nov 21, 2019 at 9:33 PM
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    Rider0120 and bensky like this.
  12. Nov 24, 2019 at 12:41 PM
    MGMTundra251
    Got it installed. Totally plug and play and well made. Didn’t have to slice/tap/hack anything. It works great. There was one discrepancy in the instructions but overall a great kit and I’m totally happy.
    JJcksn12 and 2chains like this.
  13. Nov 24, 2019 at 1:49 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    Sweet! How loud is it?
  14. Nov 24, 2019 at 1:51 PM
    MGMTundra251
    Slightly louder than the door lock. Doesn’t bother me.
  15. Nov 24, 2019 at 3:14 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    And what was the discrepancy?
    Flyinryank likes this.
  16. Nov 24, 2019 at 3:22 PM
    Burdturger
    Burdturger New Member
    Is this the "pop lock" kit? I didn't realize it was oem.
  17. Nov 24, 2019 at 4:10 PM
    MGMTundra251
    Step 6e- route the wire harness from the passenger side floorboard to the tailgate. The instructions says to remove the grommet from the floorboard and discard it so that tailgate lock wire harness with new grommet can be used. My platinum has an existing wire going through that grommet so I can not simply discard it. Not sure if other trim have this wire going through the grommet or not. I ended up just pulling the existing grommet out of the way and pushing the new grommet into the hole with the existing wire in place.
    Joe333x and Durania[QUOTED] like this.
  18. Nov 24, 2019 at 5:09 PM
    2chains
    2chains New Member
    Southern Ablerta
    How long for the install? Always takes me twice as long as most people post;(
  19. Nov 24, 2019 at 5:50 PM
    MGMTundra251
    It should take about an hour.
    Recommend glancing through the instructions before starting the job. Be careful not to lose the push nut retainer that secure the actuator arm to the clevis. It fell out of the bag when I remove the actuator. Took me a couple of minutes to find it.
  20. Nov 24, 2019 at 7:21 PM
    Smarks
    Got mine installed today as well. Plug and play. Very happy with it. The instructions were spot on with one exception. I did not need to remove the heat shield for the exhaust. Maybe because I have the TRD dual exhaust system. My grommet in the passenger foot well did not have any wires running through it so I discarded mine. The hardest parts for me were getting the passenger kick panel back on. Trying to get the panel to slide over the upper clip was a PITA. So I popped it out of the sidewall and clipped it into the kick panel and was able to get it back in. Also I don’t have a lift so getting under the truck was a bit harder and took longer than expected. I’m not a small guy. Also watch out for the heat shields under the truck they are extremely sharp. Cut my hand a couple times on the edges so I put on gloves, but too little too late :(. I also put in some dynamat in the tailgate to deaden the noise of the actuator. But honestly it’s not that loud even without it. I think it’s much quieter than the pop and lock version. Total install time for me was about 2 1/2 hours. Happy to answer any questions anyone might have.
  21. Nov 24, 2019 at 7:23 PM
    Smarks
    It is not. It’s OEM.
    AggiePhil likes this.
  22. Nov 24, 2019 at 7:43 PM
    MGMTundra251
    Mine is a 20 Platinum as well. Really weird that I have the wire and you don’t. The wire on mine goes out and towards the tailgate area. Do you have the factory bed lights installed?
  23. Nov 24, 2019 at 8:10 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    @Roman , do you guys have these available?
  24. Nov 24, 2019 at 8:27 PM
    Smarks
    I bet that’s it, because I don’t have the bed lights.
  25. Nov 24, 2019 at 9:58 PM
    Voyagermike
    Voyagermike New Member
    California
  26. Nov 25, 2019 at 11:29 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    anyone know if tis kit will work on previous years? 2016 perhaps?
  27. Nov 25, 2019 at 12:05 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Order it and try it out lol I wanted to order for my 17 but Roman wasn’t sure if it fits or not.
  28. Nov 26, 2019 at 11:29 AM
    bmann7
    WA
    See signature line
    Factory bed lights? 2019 Platinum and no bed lights here? Please tell me more!
  29. Nov 26, 2019 at 1:09 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    *dealer installed bed lights, not factory...
  30. Nov 26, 2019 at 1:20 PM
    bmann7
    WA
    See signature line
    Ah ha - tell me more? Cost, photos, part numbers, etc? Thanks!!
