PowerBass OEM direct-fit speaker replacements for 1st gen trucks
Discussion in '1st Gen Tundras (2000-2006)' started by shifty`, Dec 13, 2024.
  1. Dec 13, 2024 at 12:56 PM
    shifty` [OP] Just like witches at black masses
    Just tossing this out there since Crutchfield's fitment info seems to think some of this stuff won't fit.
    PB is a company that makes quality, budget-friendly drivers, in both 4ohm and in 2ohm for the JBL OEM radio users out there, that are direct-bolt-ins and may offer a plug and play experience using factory connectors. I'd been eyeballing them before, and I like they offer a 7" driver that'll supposedly fit (although they don't list it) in our front/rear openings. I haven't tested that theory.
    Anyway, their fitment guide is here: https://powerbassusa.com/us/en/fitment-guide/
    And here's their chart for 1st Gen Tundras at the time of this post, in the event anyone wants to dabble, it's under $250 to get full speaker replacements for the 6-speaker setup in the AC trucks:
    dirtnsmores, abcinv and KNABORES like this.
  2. Dec 13, 2024 at 12:59 PM
    abcinv likes this.
  3. Dec 13, 2024 at 2:50 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I bought the woofers only for the front and they are great!
    shifty`[OP] likes this.
  4. Dec 13, 2024 at 2:53 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    dirtnsmores and shifty`[OP] like this.
  5. Dec 13, 2024 at 3:19 PM
    Did you go with the 7", the 6¾", or the 6½"? Do you happen to still have the part number you used?
    And was it in the Sequoia, DC, or AC?
  6. Dec 13, 2024 at 3:20 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Hey @shifty` you always say that using the factory amp with aftermarket head is sub-par... I never did understand if it is because the amp is low quality, or for some other hardware compatibility reason. Would the speakers you are talking about be a candidate to avoid a amp bypass while replacing the speakers and head unit for some reason?
    Anyways, I'm sure I've missed a post where you clearly laid out your reasons for not using the Amp!
  7. Dec 13, 2024 at 3:27 PM
    I don't recommend using the OEM amp/promote using the amp bypass harness because integrated amplifier technology has improved quite a bit in the last two decades. They can pack just as much, often more power into the tiny little head units on the market today than they could in the not-so-small OEM amps, with cleaner production.
    With these speakers in particular, I'd probably opt for amp bypass also, and put it up to my aftermarket head unit to drive them. Speaker tech, like integrated amplifier tech, has gotten markedly better in 20 years too, so this could be a great upgrade option for those who do want to stick with OEM but need to replace the drivers, either because their surrounds are shot, or the speakers are blown.
    That said, for those who wanted a more no-brainer plug-and-play experience, where your speakers already had the correct pigtail, you just swap them out, but are better suited to function with the OEM head unit and amp, these are reputable and actually pretty damn good quality.
    abcinv likes this.
  8. Dec 13, 2024 at 3:49 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    I would love to get a small sub somewhere. My tinny-azz Boss-driven sound is trash. Wish my OEM HU hadn’t taken a crap on me.
  9. Dec 13, 2024 at 4:39 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Perfect, thanks for the clarity.
    I've always bought pigtails to fit on whatever speakers, so it's never really seemed like a big deal to go aftermarket. Considering my goal is a SON AX6000 I may still target some other speakers, esp since my OEM head unit is already gone!
  10. Dec 13, 2024 at 7:09 PM
    I will say this, and I know it from firsthand experience helping others with their audio: If you’re not into car audio and havent really ever been more of a “listener/admirer”, this stuff can get intimidating.
    Take my install for example. I swapped out my front OEM door components for aftermarket, JBL Club components. In that process I had to do a hell of a lot more than unplug/replug speakers:
    • Find a suitable place to mount the crossover, then install it onto the door
    • Remove the factory Y-splitter that forks out to the tweeter and mid
    • Adapt the nub leftover and feed the line to the crossover
    • Do two new separate runs to the tweeter and mid, crimp on new connectors
    • Modify the OEM baffle to remove the factory connector, pry it out of the baffle wall.
    • Remove the OEM midrange speaker; then cut and modify JBL’s adapter to adapt the 6.6” speaker to their near-7” hole, which involved rotating about 10 different ways to find the best orientation, then trim all the unnecessary excess bits off, then wire in the JBL speaker back to the crossover and secure its wire
    • Unmount the tweeter and its bracket, then find a way to adapt the JBL tweeter to safely use the OEM bracket using one of the three different adapters JBL provided, only one of which worked. Then wire that up back to the crossover and secure it’s wire.
    That’s a lot. I know and have personally helped several people do stuff like this over the internet and a lot find it intimidating, some have never crimped more than a few wires in their lives, if any. Many couldn’t tell you how a crossover works.
    If you give some folks an option of “Remove 3 screws. Unplug old midrange speaker. Screw in new one, reattach plug, repeat with tweeter, only it’s 2 screws”, versus all the shit I just typed, a LOT of people want what’s in this paragraph, not what’s in the bulleted list above. Hell, **I** want what’s in this paragraph more myself, if the driver quality is good! Plug and plug upgrades, are GREAT!
    My backdoors were easier, JBL Club coaxials. Still had to trim adapter rings and modify (remove) the OEM plug off the OEM housing/baffle to route my wires into the new speaker and secure the wire, but no crossovers, aftermarket speaker wire, etc to piss around with.
    We need more quality plug and play but I don’t see it happening with our trucks. Too old at this point. But we are seeing a lot of vendors offering bolt-in OEM++ upgrades which is nice.
    JasonC. likes this.
  11. Dec 13, 2024 at 7:48 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Haha ok ya. The JBL system in these trucks might be more complex than I am used to. Just reading your bullets made me tired. Not that I couldn't do that stuff I just don't think I want to any time soon. Guess I'll figure out what's rattling in my driver's door and make a plan.
  12. Dec 16, 2024 at 3:40 PM
    rock climber
    I think it was the 7, but I can't find my order anymore. This was on the sequoia, but they are also a perfect fit for the DC. On the DC, I removed the factory amp and speakers and installed memphis 6.5 components.
    Oddly enough on the AC, it's the non JBL system and I haven't touched the speakers, just a head unit and sub.
  13. Dec 16, 2024 at 3:58 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Interesting. Should I be the guinea pig in these speakers for the double cab JBL system? I still have the factory head unit and amp. I already did the repair on the front speakers and it sounds amazing. But the rear speakers are crackling a bit so I just need to replace the rears.
  14. Dec 16, 2024 at 4:21 PM
    If I read PB's site correctly, they have 2ohm drivers for the 1st gen w/JBL.
    I want to say the 7" mentioned above may be one of them and while it looks like a woofer/isn't coaxial, it's supposedly a full range speaker.
    dirtnsmores[QUOTED] likes this.
  15. Dec 16, 2024 at 4:41 PM
    dirtnsmores
    Southern CA
    I think what the chart is saying, this is what I need...
    OE652-TY
  16. Dec 16, 2024 at 4:50 PM
    Crutchfield says the following three will fit the 2006 DC with JBL system (I plugged your truck specs in and filtered on PB's brand). They're all 2ohm speakers engineered to be direct swaps for the JBL 2ohm drivers.
    If it were me, what would I do? I'm not fully sure. Those OE-700s would probably sound awesome in the front doors, but I don't remember The DC layout... For some reason I thought you had a tweeter in the sail panel (interior triangle where mirror is), and two speakers in the door at knee level? If it's a coaxial in the rear door, and 3 components in each door, I'd probably drop the OE-652s in the rear, and the 7's in front, maybe the OE-6C components to fill in the rest? Not sure. Would need to see inside the door and make some choices, plus look into the wiring of y'alls doors with the DC + JBL setup, since it's so different than the AC/RC trucks..
  17. Dec 16, 2024 at 5:29 PM
    dirtnsmores
    Southern CA
    Yeah it definitely makes sense to open everything up and take a look first. But since my front sounds really good, yep, even the tweeters up there, I'm just going to be replacing the rear speakers that are giving me crackling noises. OE-652s might be the ones.
    Edit: actually those ones are 4 ohms.
  18. Dec 16, 2024 at 7:01 PM
    Is it single speaker in the rear? Or components?
  19. Dec 16, 2024 at 7:06 PM
    dirtnsmores
    Southern CA
    yep just one back there.
  20. Dec 16, 2024 at 7:19 PM
    I’d probably run with the OE-652, middle speaker in my image above. Coaxial for mids and high, and 2ohm driver. Would give reasonable high/mid fill in back. If it were me I’d pop the door panel off and pop out the speaker to confirm it’s stamped with the 2ohm symbol on the rear, or ohm out the speaker lead to confirm w/o popping the door panel (at the amp, after checking wire colors to test in the EWD) but …
