PowerTank CO2 Tank Write Up - Bed Mounted
Discussion in 'General Tundra Discussion' started by agentcox000, Jan 25, 2018.
  1. Jan 25, 2018 at 6:27 PM
    agentcox000
    agentcox000 [OP] "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I previously owned a Jeep Wrangler and one of the pieces of equipment that has been incredibly useful long after selling the Jeep was my 10lb CO2 PowerTank. The ability to run air tools, reseat tires, and just general inflation needs, without any wiring necessary is very convenient and fast. This tank has saved me and others on more occasions than I can keep track of.
    When I got my Tundra, I knew one of my first projects needed to be a proper mounting solution for the PowerTank. After weighing all the options, I decided on bed mounting it. PowerTank makes an angled bracket for this but I felt it was a little expensive and more complex than what I needed, so I had a talented friend fabricate me a mount out of steel for much cheaper. The inspiration for this custom bracket came from an article written by TRUCK TREND back in 2011.
    Below are photos of the custom bracket, hole locations, and the final mounting solution. A small spacer was used to create a sort of 'leg' under the front left area of the mount to stabilize the unit (exactly where it's located in photos). It's comprised simply of washers stacked to the correct height I needed and wrapped in electrical tape. The hole size drilled in both the mount and the bed was 3/8" and all stainless steel hardware was used. The mount is thru bolted and fender washers were used underneath.
    I am very happy with the way it turned out and will report back any long term issues and my experiences with this air setup. Feel free to ask any questions you have and I’ll do my best to answer. Enjoy!
    http://www.trucktrend.com/how-to/parts-accessories/1103-8l-power-tank-air-system-mounting/
    Final Product:
    Mount progression: Raw, self-etching primer, Rustoleum bed liner, complete
    Hole locations and spacer:
    Close-up:
    Final before tank:
    Top view:
    Top view w/ tank:
    Tonneau cover clears easily!
    Wide view of the project:
  2. Jan 25, 2018 at 6:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice. How do you refill a CO2 tank? Welding supply?
    agentcox000[OP] likes this.
  3. Jan 25, 2018 at 6:32 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Very nice setup!! Met the power tank folks! Great people! Their 1st gen runner is one of the sickest build I’ve seen.
    agentcox000[OP] and 831Tun like this.
  4. Jan 25, 2018 at 6:34 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Welding supply or some offroad shops offer fills. I get mine filled at Sierra Expeditions in Tempe AZ
    831Tun[QUOTED] likes this.
  5. Jan 25, 2018 at 6:47 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
  6. Jan 25, 2018 at 7:14 PM
    Marty McFly
    Morty McBoonJug
    This is a great write up. I've been contemplating going this route for airing up. Damn powertanks are mucho expensive :(
    @dcsleeper408 any chance for a group buy :pray:
  7. Jan 25, 2018 at 7:35 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Thanks! It was a fun project and one I hadn't really seen posted yet. Also check Craigslist for used PowerTanks, I see them posted from time to time. That's how I got mine, think I paid around $200
  8. Jan 25, 2018 at 7:37 PM
    Marty McFly
    Morty McBoonJug
    I've been checking craigslist too but not much available. Ill keep checking :typing:
  9. Jan 25, 2018 at 7:41 PM
    Nice write up.
    I prefer a CO2 tank as well.
    I purchased my CO2 tank almost new, with regulator and hose for 225.00. Hell, there was just one posted for sale on another Offroad forum I visit.
  10. Jan 25, 2018 at 8:40 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    These are bad ass tanks.. paired with their monster valves I seen em fill a tire from 8-30 really fast. I want to say under 10seconds each tire. I really like the fittings and regulators they use as well.
    I’ll give them a call tomorrow and see what I can do for us..
  11. Jan 25, 2018 at 9:04 PM
    Marty McFly
    Morty McBoonJug
    Mark you rock :headbang:
  12. Jan 25, 2018 at 9:41 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    For anyone wanting to replicate the mounting bracket in the future here are the dimensions:
    dcsleeper408 and Marty McFly like this.
  13. Jan 25, 2018 at 10:01 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Nice work! How many times can you air up on one tank?
    dcsleeper408 likes this.
  14. Jan 25, 2018 at 10:09 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Heres the chart from PowerTank. PT10 is the tank size then just cross reference your tire size and amount of increase in PSI to show how many tires it will fill up, then divide by 4, giving you the number of complete four tire air-ups. Hope that helps.
  15. Feb 3, 2018 at 5:51 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Pretty cool. I bet it would make a good fire extinguisher in a pinch.
