Powertrax Pro XR
Discussion in '3rd Gen Tundras (2022+)' started by ghunter321, Mar 26, 2023.
  1. Mar 26, 2023 at 8:04 AM
    ghunter321
    ghunter321 [OP] Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    Does anyone have this? Any pros? cons? I'm disappointed in the whole OEM trifold cover fiasco and its time for a change.
  2. Mar 26, 2023 at 2:53 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    I have the retrax pro xr. I didn't think it was worth the price difference from the manual to the power. I use mine frequently and have come to the conclusion that the power one would have been a pain and I'm glad I decided against it. I can open and close it very quickly manually with little to no effort. The power one takes much longer to open and close comparatively speaking. There's also more to go wrong with the power. I would highly recommend saving your money on the difference of the manual vs the power. Use that money for something else you want in the truck.
    RickyBobbysTundra, SC4333 and SAGE63 like this.
  3. Mar 26, 2023 at 3:15 PM
    GoFast157
    GoFast157 New Member
    Agreed. Love my manual retrax. Quick and easy to open or close with 1 hand. I think the power version would just piss me off. It'd probably impress some folks at the grocery store though.
  4. Mar 26, 2023 at 3:59 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Check this post #969 in 2022 Tonneau covers thread.
  5. Mar 26, 2023 at 4:09 PM
    Watching that again just reconfirms I made the right decision for myself. I can open and close mine manually in less time than it takes that to open or close under power. I'd be curious to know how much power that truly draws when not in use.
  6. Mar 26, 2023 at 4:54 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I have the Retrax ProXR on my 2020. I will put the same model on the 2023 when the truck gets here. Fantastic lockable and usable cover. Didn't even consider the power model. No need for it. I have over 100K miles on my truck now definitely made the right decision for its use.
    Randy B
  7. Mar 27, 2023 at 10:41 AM
    ghunter321
    NC
    These are all excellent points. You’ve convinced me. My main reason for powertrax was that I am planning to get the overland bedrack slotted in. If I put mollie panels on will it make it difficult to still open all the way by hand from the side of the truck?
  8. Mar 27, 2023 at 11:20 AM
    GoFast157
    It is spring assisted, you can pretty much open the latch and let just it go, to open all the way. Or you can open a ways, close the latch and it stays at that point. If there's not room around your molle setup, maybe add a pull-strap? Find a spot at the rear of the bed and run something to the area of the latch on the cover maybe? Would be a short section of cord and easy to grab, while being mostly out of the way.
  9. Mar 28, 2023 at 12:18 AM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    Anyone with a retrax know the max height with it closed? Wanting to add a fridge and slide
  10. Sep 1, 2023 at 4:56 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Anyone using a manual Retrax with a bed rack? Any issues opening/closing with the bed rack being in the way?
  11. Sep 1, 2023 at 5:00 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I have a manual Retrax XR with a bed rack and have no issues with it.
  12. Sep 1, 2023 at 5:03 PM
    2TunGet1
    Thanks, do you have any pictures of it by any chance? I’m trying to get an idea of where the access to the handle to open and close would be around the rack. I guess it would depend on what stuff I have mounted on the rack.
  13. Sep 1, 2023 at 6:39 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Retrax pro and up top overland rack on the slide in tracks!
    Handle to open bed cover is on drivers side and you can just walk it up to the back of the cab while going in and out of the rack.
    2TunGet1 likes this.
  14. Sep 1, 2023 at 7:08 PM
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    That’s a slick setup!
  15. Sep 1, 2023 at 8:35 PM
    2TunGet1
    Sweet setup!
    I was looking at the Uptop Overland and the KB Voodoo VRS.
  16. Sep 1, 2023 at 10:17 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Mine was recent straight from the factory and it came with giant long tubes for draining :(
    Retrax support is cool though, I did a warranty claim on some parts I fucked up from install and they hooked it up with the quickness. Glad I paid the monies.
  17. Sep 1, 2023 at 10:42 PM
    SAGE63
    San Diego County
    My ICECO VL 45 with Iceco slide fits under my retrax
    Kona_boy[QUOTED] likes this.
  18. Sep 1, 2023 at 10:43 PM
    SAGE63
    San Diego County
    No issues... I have the KB Voodoo Max Moduler20220407_191856.jpg 20220106_103053.jpg
    Hope these pictures help
    ToyoMafia and 2TunGet1[QUOTED] like this.
  19. Sep 2, 2023 at 1:02 PM
    ARMYGREEN
    2014 CrewMax MGM
    One more with the bikes too!
    ToyoMafia and 2TunGet1 like this.
  20. Sep 2, 2023 at 6:41 PM
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    I have the PowerTrax and I’m very happy with it. I went for the electric because I wanted an easy way with a rack and RTT above. After almost one year, I have no regrets and would do it again.
  21. Sep 2, 2023 at 8:26 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Any tailgate seal suggestions? I try the ESI bulb seal. Maybe I installed wrong but the tailgate doesn’t close as well and water still gets in after going through high pressure car was test…
  22. Sep 2, 2023 at 8:32 PM
    GoTTi74
    GoTTi74 New Member
    I’m not expecting a bed cover to be water tight, especially not when pressure washing. Think about what you really need. If you want a fully watertight cabin, maybe you’d be better with the Sequia?
    Sixty9Four20 likes this.
  23. Sep 3, 2023 at 6:24 AM
    AustinTexas
    AustinTexas New Member
    When I go through a car wash (like hurricane force water spray) I will get a few drops of water in the corners
  24. Sep 6, 2023 at 8:18 AM
    2TunGet1
    Or a hard
    How does the Retrax Pro do when you go off-road? Any issues?
  25. Sep 6, 2023 at 8:56 AM
    SAGE63
    San Diego County
    @TuffTundy the retrax works great off road. dust does get in the bed. sometimes needs a bump when closing as it will move in the channel. Had one roller come out of the track but easy to knock it back in the track with a mallet and flat head screwdriver
    2TunGet1[QUOTED] likes this.
  26. Sep 6, 2023 at 8:59 AM
    2TunGet1
    Any rattling noise when you’re hitting those washboards?
  27. Sep 6, 2023 at 9:16 AM
    SAGE63
    San Diego County
    not that I notice, however I know it does rattle.
  28. Sep 6, 2023 at 10:22 AM
    Dtrancrx
    Dtrancrx New Member
    Not sure how they designed it..but I get no rattles at all..pretty cool..only down side is you loose about a foot of bed space
    GoTTi74 and 2TunGet1[QUOTED] like this.
  29. Sep 6, 2023 at 10:33 AM
    GoTTi74
    GoTTi74 New Member
    Luckily I got the 6.5 bed and the long equipment (e.g. skis) fit under the canister anyway.
    Dtrancrx[QUOTED] likes this.
  30. Sep 6, 2023 at 10:38 AM
    GoTTi74
    GoTTi74 New Member
    I can confirm, it works well but I had quite a bit of dust inside after driving ˜40mi on a dirt/forest road. Otherwise, no issues found yet.
