Predator Step Bar Help Needed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Davidlspearman, Jul 2, 2018.
  1. Jul 2, 2018 at 9:57 AM
    Davidlspearman
    Davidlspearman [OP] New Member
    David
    2016 Toyota Tundra Dbl Cab MGM
    Hi, I purchased a set of bars off of a 2018 tundra double cab, and it did not come with any hardware just the predator step bars. I have a 2016 double cab, and I noticed that where the bars go there are currently some bolts except for one in the front on both sides. After doing research on installing them I find myself confused. I need to know where to get the bolts needed and if anyone knows what size or part number that they are or if someone has a set that I can buy from them, thank you for your help.
    parallax likes this.
  2. Jul 2, 2018 at 10:00 AM
  3. Jul 2, 2018 at 10:02 AM
    Rica25
    Ricardo
    Tulare
    Your truck should have the bolts already there just remove them and install the boards using same bolts
    joonbug, Pudge and Davidlspearman[OP] like this.
  4. Jul 2, 2018 at 10:05 AM
    Davidlspearman
    David
    Roman was who I asked first and he was unable to help. Said to try Southeast Toyota.
    When I look at the install on the 2016 bars it says to remove the factory bolts and discard and that the bars come w new bolts and washers.
    Plus I will still be missing the from inside one on both sides.
  5. Jul 2, 2018 at 10:06 AM
    Take a bolt with one to a local Ace hardware to match it
    Henry1jg, Mootball, Pudge and 2 others like this.
  6. Jul 2, 2018 at 10:07 AM
    Rica25
    Ricardo
    Tulare
    Take a bolt and take to nearest hardware store and match it up with a longer one
  7. Jul 2, 2018 at 10:20 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yep, those are a SET or GST accessory. I'm not in either of those regions.
    Davidlspearman[OP] likes this.
  8. Jul 2, 2018 at 10:29 AM
    tundraty
    tundraty New Member
    Fort Worth, TX
    2022 Celestial Silver SR5 CM 4x4 TSS Off-Road
    This is what I did
  9. Jul 2, 2018 at 11:00 AM
    Davidlspearman
    David
    I’m about to go to the local dealership and see what they say. The only downside is the guy who works parts doesn’t give you parts numbers and really doesn’t want to ever help. Overall he is a jerk. The only thing about going to a hardware store is knowing how long it needs to be. Also don’t the bolts have some sort of thread lock on them?
    4x4_Angel likes this.
  10. Jul 2, 2018 at 11:05 AM
    Get underneath and take one off if they're on ther
  11. Jul 2, 2018 at 1:46 PM
    Davidlspearman
    David
    Update:
    First I want to thank everyone for all your help. I went to to local Toyota dealership and the parts guy did help somewhat. He found the part number to something but said it was discountunied but when I looked it up, I was lead to some install directions on mounting the 3 step predator bars and in its list of parts included w the bars it said that I needed : (16) 8mmx25mm that’s for the 2012-up and the 2017-up (bars I have) say basically the same just 8mmx30mm. So I found a place that has them but I have to buy 50, but I guess that’s ok. I now wonder if I should get 30mm so it would be more secure??? Either way here’s a screenshot of the info I found and while I wish I could get the correct ones w the loctite sprayed on them I guess they will stay put. Let hope!7201394B-6F61-4F98-847B-7CC4AB7F9592.jpg
    BabyBlackYota and 4x4_Angel like this.
  12. Jul 2, 2018 at 1:49 PM
    Davidlspearman
    David
    BC65696D-F17E-4FF4-8DEF-0A877A6FA293.jpg Oh, and I took a bolt out and this is what I have BC65696D-F17E-4FF4-8DEF-0A877A6FA293.jpg
  13. Jul 2, 2018 at 3:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Check Fastenal or Ace Hardware they usually have individual pieces for sale.
  14. Jul 2, 2018 at 5:15 PM
    Davidlspearman
    David
    Called Fastenal today and the guy said he had some and I would have to buy 50 of them. So that’s my plan.
    Does anyone think I should use Loctite on the bolts or are they good w the lock washers?
  15. Jul 2, 2018 at 6:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  16. Jul 3, 2018 at 6:58 AM
    Davidlspearman
    David
    @Festerw Thanks. I’ve never heard of them but looks like they have lots of good stuff!
  17. Jul 3, 2018 at 8:29 AM
    parallax
    parallax Professional Zamboni stunt driver
    Oregon
    2018 White Tundra Crewmax SR5 5.7 TRD 4x4
    Dash camera
    I think you can buy nuts with a nylon insert that is a lock. pretty much at any home depot, lowes, or ace hardware, or farm supply store. Alot easier to remove nut, than lock tighting them.
    just need to figure out what the metric bolt size is to get the correct nyloc nuts.Screen Shot 2018-07-03 at 8.32.03 AM.jpg
  18. Jul 3, 2018 at 8:31 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This^^^^^
  19. Jul 3, 2018 at 8:41 AM
    How much are you paying for 50? when you don't need 50, no Ace Hardware close by to match? And you need flat washers n lock washers if you want loctite you can use blue or red which is the strongest
  20. Jul 3, 2018 at 9:01 AM
    csuviper
    Broomfield, CO
    I needed hardware for my steps as well and just went to Ace and got stainless steel bolts with washers. They don't have to be the exact bolts, just same size.
  21. Jul 3, 2018 at 12:49 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    M8 x 1.25 is the stock bolt size. 25mm is the overall length.
  22. Jul 3, 2018 at 7:16 PM
    Davidlspearman
    David
    I went today and purchased packs of 25 (smallest they had) of Stainless M8 25mm , Flat washers, and Lock washers. Pending weather I hope to have them installed tomorrow. Thanks for the help!
  23. Jul 5, 2018 at 6:36 AM
    Davidlspearman
    David
    Final Update:
    The bars are on and look good. I had to kinda wing it on some things but I used a combo of the 2007-2012 / 2017-up install instructions to put on and torque settings. I will say that I believe the bars I have for the 2018 are slightly different than the 2016 truck. Everything lined up except the front bracket sat about 1/2 inch off the body. As I slowly tightened the bolts in the correct order I was able to get it flush though. Maybe they are all that way. Either way thanks to everyone who helped me and here are the final pics installed. Sorry for the dirty truck. It won’t stop raining in Alabama. 9A4502BE-197E-4B64-9D40-3F81A5925840.jpg8FE16C78-9968-42E2-8123-CFF90801C70B.jpg
    ldale likes this.
  24. Jul 5, 2018 at 7:42 AM
    Glad you got them on they look good!
  25. Feb 21, 2024 at 11:06 AM
    Oz_zy
    Oz_zy New Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights Morimoto xb led fog light Db custom tundra grill with led Spyder smoked led taillight
    Do you have a link to these?
