Preventive maintenance
Discussion in 'General Tundra Discussion' started by mds, Nov 20, 2024 at 2:35 PM.
  1. Nov 20, 2024 at 2:35 PM
    mds
    mds [OP] New Member
    Today
    David
    2008 Tundra double cab
    side running step and bed cover
    I bought a new Toyota Tundra, double cab, with long bed in December 2008. The only things I have ever added to it are running boards and a fiberglass bed cover. It has been an absolutely amazing truck. I have changed the oil and filter every 5000 miles, changed the air filters when needed, replaced tires and brake pads, and I had to replace the battery once. The truck only has 104,000 miles. It has been a perfect machine. Now that I have passed 100,000 miles, I know I should get some preventive maintenance done but when I check online for what's recommended, I get woozy. Dang! I could never afford to do all of that. What steps should I absolutely take now that I have reached this first big milestone to keep everything running well? Thank you for your help!
    David
  2. Nov 20, 2024 at 3:11 PM
    Raven67
    Raven67 Just a retired guy
    Central Ky.
    24 Tundra Limited
    Instead of checking "online", check the owners manual, and do a little at a time. Because of your good maintenance practices, you've had excellent service from your truck, keep it going!
  3. Nov 20, 2024 at 3:41 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Clean maf and throttle body cheap and easy
    All fluids ps, brake, coolant, diffs, and a drain and fill on the tranny. A little spendy but all are overdue
    spark plugs probably least important unless your having ignition problems
    mtucker likes this.
