Price of ignition coils?
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, Aug 7, 2021.
  1. Aug 7, 2021 at 10:24 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    I'm needing probably 3 or 4 ignition coils. I've found them on Toyota's parts online website. The generally have good pricing, but my complaint is their atrocious product descriptions and search engines.
    https://parts.maderatoyota.com/
    It appears my 2000 4.7L Tundra requires Part Number: 9091902230. About $100. That's reasonable for a set of 8. I would assume they are sold and replaced in sets, and around the internet it appears a set goes for about $100-150. Yet, these might be sold individually?
    But when I walk thru adding to my cart for the job it adds 8, for over $800. For coil packs. This cannot be accurate?!?!
    A set of spark plug wires is generally around $50. I cannot believe a single coil which is not complex is $100... ?! A set is crazy expensive.
  2. Aug 7, 2021 at 10:30 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    you can buy Denso coils for half the price, they are the original makers of the coils 50$
    side by side they are the same, just missing the Toyota stamp that looks shaves off.
    buy them from Rockauto.com (clickable link)
    Denso part number - 6731303 Ignition Coil
    2000 Toyota Tundra V8 4.7L
    Direct Ignition Coil (COP)
    Part/Stock #:
    673-1303
    Engine:
    V8 (4.7L)
  3. Aug 7, 2021 at 10:31 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  4. Aug 7, 2021 at 11:06 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    I personally use the Spectrum ones put about 5k miles on them no problem over 2 week period. First 2.5k was going 70 mph on the I-80 back to Cali 18 hours >4 hour break > 18 hours. The other 2.5k was going 55 mph towing back east same deal just took longer. If they were gonna crap out they would had by then. So far about 8k miles and just did my oil change. I'm running AD Delco Double platinum spark plugs got about 10k miles on them so far, still in good shape. Cheap unknown ebay ignition coils stay away from unless you plan on carrying extras in the truck. Before I got the Spectrums the previous owner had an eBay set that was on there started to crap out one by one. Which were change out with ebay spares that came with the truck. Which all got swap out with the Spectrums.
    Denso are $48 at Rockauto $20 for the Spectrums.
    Fiyad and ToyotaJim[OP] like this.
  5. Aug 8, 2021 at 4:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Mike59, shifty`, Darkness and 4 others like this.
  6. Aug 8, 2021 at 7:00 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks like Rock Auto has these for cheaper than Amazon too. $47.99.
  7. Aug 8, 2021 at 7:06 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Has anyone here used the trq coils?
    i still havent talked myself out of the msd’s yet either. Red means faster, right?
    Wes_heppy and ToyotaJim[OP] like this.
  8. Aug 8, 2021 at 7:09 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’ve been running 1A auto coils for a year and a half now. No issues so far. Set of 8 for $150.
    Darkness, ToyotaJim[OP] and CodyP like this.
  9. Aug 8, 2021 at 7:14 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Same here. Sounds like when they get the 'same' (some legit and some counterfit) parts in from different sellers they all go into a bin and mix together. Then Amazon just picks out the quantity that is ordered and sends them your way so you really have no idea what you're getting.
    ToyotaJim[OP] likes this.
  10. Aug 8, 2021 at 7:15 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    That's good to hear but not now for me since I forked over the skrilla for OE cause I didn't want any issues.
  11. Aug 8, 2021 at 9:41 AM
    ToyotaJim
    Thanks @jerryallday for the very helpful post with a link.
    $50 is more reasonable than $100 for sure. Looking at these, they are just a plastic and rubber boot with some very simple electronics. I'd have guessed they are $20 each. $50 is closer to reality. $100 is nutz.
    Darkness likes this.
  12. Aug 8, 2021 at 10:07 AM
    Jack McCarthy
    Bill
    North of Boston
    Simple electronics? lol
    That’s kind of like saying a cheap speaker coil is just as good as a more expensive better built one. The quality of the insulated coil and the ability to stand up to heat, vibration and voltage breakdown during its life makes a difference. So materials used and consistency in fabrication make a big difference.
    I will agree $100 is overpriced and going with the $50 Denso equivalent is your best bet.
  13. Aug 8, 2021 at 10:13 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Original factory toyota coil
    Denso without Toyota branding (looks shaved off)
  14. Aug 8, 2021 at 12:39 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Get the Denso, but only replace the failed ones.
    Maybe buy one extra for spare. Coils are typically not replaced preventively as they tend to last a long time.
    shifty` and ToyotaJim[OP] like this.
  15. Aug 8, 2021 at 10:25 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    so, just to avoid what i see come in at work a fair bit. Aftermarket coils will work usually. BUT the way Toyota uses ignition sense, the aftermarket coils can kill the whole ignition system depending on how they fail. once IGF is lost your usually fine, but with aftermarkets they seem to ground or or do something weird and it kills the whole circuit until the bad coil is removed. MANY tow ins over the years due to aftermarket coils (on any 4 wire ignition coil setup Toyota).
    spend the coin for denso off rockauto (Avoid ebay and Amazon) and replace the ones that need replacing. its not uncommon to see Toyota coils go well over 300k (hell my corolla was on its originals after 800k+
    KNABORES, bmf4069, Darkness and 5 others like this.
  16. Apr 7, 2022 at 10:43 PM
    Fiyad
    Fiyad New Member
    Hi how are your ignition coils standing up. I am considering that brand as well
  17. Apr 11, 2022 at 11:18 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Denso. Replace all then you’re good for another 15 years. I’ve played the chase the misfire game.
    Mine have been puffed, cracked and burnt for over 100k but all still work. Last plug swap I put new NGK boots and seals on them. That was 2 years ago.
    When one goes, they are all getting swapped with Denso from Rock Auto.
  18. Apr 13, 2022 at 2:24 PM
    thxcolm
    thxcolm New Member
    central valley, CA
    2001 Toyota Tundra SR5 V8
    I'm fairly sure my 253k mile 01's have the original coils. When I changed the spark plugs out last year for the Denso's I noticed that a few of the coils had cracks in them. I really wanted to replace but also was hesitant that $800+ was the price of entry for OEM's. The $400 Denso sounds much more palatable.
    Question though, is it really better to do them all at once, or could I just replace the ones that are cracked?
  19. Apr 13, 2022 at 2:54 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I second going to rockauto and buying Denso coils. OEM is Denso.
  20. Apr 19, 2022 at 5:59 AM
    Motopilot
    Motopilot New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    I 2nd the denso…I cheaped out and bought cheap ones…last about a year and 5000 easy miles.
  21. Apr 19, 2022 at 7:17 AM
    There's a boot and seal replacement kit for OEM coils? Do tell more. I wasn't aware of it. A couple of mine are showing signs of heat/browning.
    That said, I can't reiterate this point from above enough: DO NOT buy auto parts on scAmazon or fleaBay, and now even Wallyworld is a venue for bogus/counterfeit/shady parts from 3rd party sellers. Stick to trustworthy sources, local auto parts store (LAPS), RockAuto, Summit, whatever.
    I understand the drive to save money, if you want to save money, just don't replace ALL of your coils. If you're throwing codes on a specific coil, swap it with the one next to it, clear the code, and see if the code follows the coil pack to its new home. If not, it's probably not the coil pack. If it is, just replace the one coil pack w/Denso branded. $350-700 saved instantly.
  22. Apr 19, 2022 at 10:48 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Denso:
    https://www.rockauto.com/en/moreinfo.php?pk=4718148&cc=1426935&pt=10150
    Aftermarket:
    https://www.rockauto.com/en/moreinf...ixIQQ4P4bIawKkQfRT4R5rE+w34RQMkvcB9vCbsFPb0wZ
  23. Apr 19, 2022 at 10:37 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
  24. Apr 20, 2022 at 5:20 AM
    The NGK look nice, but with the perpetual 5% off coupon Tundras.com members get at RA I'd rather just pay the extra $10 for OEM/Denso.
  25. Apr 21, 2022 at 8:29 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I thought denso doesn’t make them. I know you can’t buy the boots from the dealer.
  26. Apr 22, 2022 at 8:26 AM
    Denso direct: https://densoautoparts.com/find-my-part.aspx#ProductDetail
    True, can't get it at the dealer, but apparently they make it.
    I think Toyota sells as a single boot. The part number is possibly 9091911009, but that may be the Prius version. Not sure what the Tundra version is. Will edit this to update if I see it.
    Diablo169[QUOTED] likes this.
  27. Apr 22, 2022 at 10:01 AM
    FrenchToasty
    Mo
    Bone stock
    So is it basically worn electrodes cause high heat, which then gets absorbed thru the coils and makes the plastic then cracks?
    Mogo Gogo[QUOTED] likes this.
  28. Apr 22, 2022 at 7:08 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Do the cracks actually cause arcing issues or does the appearance just scare people? I've got two new denso coils I'm keeping in the truck and I'll just wait till I have an issue to put them in. I don't recall if mine were cracked when I changed my plugs a while back. Didn't give it any thought back then.
  29. Apr 23, 2022 at 11:01 AM
    Jack McCarthy
    Bill
    North of Boston
    Yep, moisture can get inside and cause a resistive path to ground leading to poorer sparking conditions. You want as much isolation as possible for a strong spark.
    https://itstillruns.com/problems-caused-cracked-ignition-coil-6884004.html
    txagg and Mogo Gogo like this.
  30. Apr 23, 2022 at 5:31 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    ive also read that, and maybe its too dry where im at to matter, but all 8 coils were cracked on the sequoia, and it never gave any troubles. Was gonna steal a good one to replace my cracked one in the tundra, but couldnt find one.
