Problems with center console locking case?
Discussion in '2.5 Gen Tundras (2014-2021)' started by daylorb, Aug 5, 2020.
  1. Aug 5, 2020 at 6:05 AM
    daylorb
    daylorb [OP] New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I've got the center console insert with the three dials many of us have purchased. Locked 'er up before I went on the road... and now can't get it open. I am guessing somehow I messed up and reset the code? Unfortunately I don't have the keys with me. Has this happened to anyone else? Any suggestions?
  2. Aug 5, 2020 at 6:46 AM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    I have the same console. Never forgot the code but you may check out some videos on how to get that key unlocked using a bic pen lid. I've seen people push one in and get the gates open.
  3. Aug 5, 2020 at 12:08 PM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Thanks - I wonder how the code got changed? I've used it for almost two years with the same code...
  4. Aug 5, 2020 at 12:16 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Is it acting like it's locked or caught? I have a center console safe that when I rotated the dial the arm that rotates to lock the top down was catching on the opening it fit into. I had to tweak the arm down a bit so it would not catch in the slot. If this is true, it'll be tough to get to with it closed.
  5. Aug 5, 2020 at 12:56 PM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    It was locked. The code got changed. Not sure how - but I went through each dial keeping the other ones at the old code, and sure enough the first digit was off by 3. Going slowly trying each one it opened. I guess maybe I bumped the reset button while locked and spun the dial? Bizarre. Oh well - all is well that ends well.
    NewImprovedRon and rt_tundra_co like this.
  6. Aug 6, 2020 at 6:48 AM
    dgtulsaguy
    18' 1794
    Wasn't too impressed with the locking mechanism. I feel like it could have used tighter tolerances, another digit on the wheel and a more secure key. Especially with what I'm sure we all store in it. Mine also came with some crazy sharp edges on the inside that required deburring. I've had the latch fall below the edge and get caught/stuck open a time or two. Excellent construction on the body though and it feels solid bolted in.
  7. Aug 6, 2020 at 6:56 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    What brand and model do you have? There’s several, and fabrication (as well as price) are not equal.
  8. Aug 6, 2020 at 6:59 AM
    dgtulsaguy
    18' 1794
    So true! I'd be interested to know which one OP had.
    Here's mine:
    https://www.setf.com/tundra-center-console-safe
    happyjack87 likes this.
  9. Aug 20, 2020 at 11:29 PM
    happyjack87
    happyjack87 New Member
    This story is the reason I didn’t buy one with the coded dials.
  10. Aug 21, 2020 at 2:54 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Get a FAS1 Safe (http://www.fas1safe.com) compact box. Full steel construction, simplex lock, and made in San Antonio, TX!
    Black Wolf likes this.
