Program a transponder key?
Discussion in '2nd Gen Tundras (2007-2013)' started by diavel, Aug 25, 2020.
  1. Aug 25, 2020 at 4:09 AM
    diavel
    diavel [OP] New Member
    Simon
    Tundra Platinum Flex Fuel 4x4
    Hi.Has anyone successfully programmed a transponder key ,from the existing master, without special tools or technology? I have watched multiple videos on youtube and other forums but still cannot get it right.The new key I have is correct and matches the master (G code) but paring/matching it with the system is a nightmare.Outside of North America the Dealer wants $88 to do the work which seems a lot? Any advice would be appreciated.Thanks. (2010 Tundra Platinum)
  2. Aug 25, 2020 at 4:34 AM
    timsp8
    NY
    $88 isn’t too bad. I’ve read where the dealer wanted over $300 for a new key and programming.
    diavel[OP] likes this.
  3. Aug 25, 2020 at 5:11 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    What is worth more to you, your time and aggravation, or the 88 dollars? If I was not successful in one try I would just pay the 88 dollars, and save myself some aggravation. You will live longer that way.
  4. Aug 25, 2020 at 5:47 AM
    diavel
    Simon
    After reading and watching the various youtube videos it seems like a pretty straightforward job (doesn't it always) .Turn the ignition x times, open the door y times and bingo. Right now a quick fix and $88 looks a reasonable option.
  5. Aug 25, 2020 at 6:33 PM
    Dr_Al
    Dr_Al New Member
    Al
    I've done it with techStream. I watched the videos on how to do it without the software and none of them worked.
  6. Aug 25, 2020 at 7:41 PM
    diavel
    Simon
    Thanks very much for that. I will order the VCI cable so that I can use Techstream in the future and stop wasting time on the videos!
  7. Aug 26, 2020 at 9:21 AM
    Dr_Al
    Dr_Al New Member
    Al
    I've had good luck with the cheap key blanks from Amazon and ebay but not the cheap Chinese FOBs. The two FOBs I had both had buttons that stopped working. I've since replaced them with used OEM FOBs. There's at least one person on ebay who sells them (has like 100 in stock so I'm guessing a junk yard).
  8. Aug 27, 2020 at 12:10 AM
    diavel
    Simon
    Fixed it now . Dealership did the programming for the key they supplied.I have ordered some OEM fobs and the hardware to use Techstream next time. Thanks for all the advice-much appreciated.
  9. Aug 27, 2020 at 10:49 AM
    Jon1979
    Jon1979 New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    I have not done it for the Tundra. But I got a new key from True Value and they cut and programmed it to my wife's CRV. $ 110 for both. I don't own a Techstream so I had been thinking of having them do one for my truck.
  10. Sep 1, 2020 at 7:02 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    question- Is there a limit to how many keys can be programmed to a vehicle at one time?
  11. Sep 1, 2020 at 7:15 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    I have not been successful with the bootleg copy of techstream and VCI cable. The instruction is terrible and i sifted through tons of BS online to try to figure out how to make it work. i got one key programmed, then it defaulted back to not working. I've also heard the software may or may not be loaded with malware.
  12. Sep 1, 2020 at 8:24 AM
    ckkone
    ckkone New Member
    SLC, UT
    No, I spent a weekend getting techstream to work. While in there changed a bunch of other options, like turning off all warning chimes and beeps (very annoying when out in the wilderness trying to enjoy peace and quite.)
