Project Double Gnar : P0441 and some missing hoses
Discussion in '1st Gen Tundras (2000-2006)' started by ThatYeti, Jul 20, 2021.
  1. Jul 20, 2021 at 1:10 PM
    ThatYeti
    ThatYeti [OP] New Member
    2000 Tundra SR5
    Back again....made a few successful short trips in the truck...was getting too confident it seems...was even thinking I could have it tested for emissions again.....nope.
    Took a 30 ride to pick up something last night and just as I started back home it popped a CEL. Was running fine out and back, but checked it this morning and it was showing P0441. Looked up all the old threads here covering that and figured the gas cap, likely from 2000 had given up, or at least the seal on it. So I'd planned to just go get a new one but wanted to check under the hood as some of the posts mentioned hoses that may get loose or leak that could cause the code as well......hoses....I've got no hoses!
    Can't recall if they were ever there, but I'm gathering based on photos others have posted that I'm missing a few hoses at the very least. Anybody know what they're called (evap hoses?) and exactly how many I'm missing? Seems the purge valve with the green tag may not need one, but not really sure what's missing.
    Thanks in advance as always.
  2. Jul 20, 2021 at 1:13 PM
    ThatYeti
    2000 Tundra SR5
    Issues highlighted in this one
    Darkness likes this.
  3. Jul 20, 2021 at 1:17 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  4. Jul 20, 2021 at 1:18 PM
    My truck is at the airport, otherwise I would share a photo of my engine bay for reference
  5. Jul 20, 2021 at 1:20 PM
    ThatYeti
    2000 Tundra SR5
    Really appreciate this, but does the top hose coming from right to left terminate into that black box?
  6. Jul 20, 2021 at 1:23 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Grey w/ green port into black box goes to the solonoid mounted to the IM, then into the throttle body. Brown(ish) hose goes across the intake manifold to the intake tube baffle.?
    your hose with the green port is on the wrong side of evap, if that matters?
  7. Jul 20, 2021 at 1:25 PM
    ThatYeti
    2000 Tundra SR5
    So they basically cross at the little black box? Also any idea what these are called so I can go find replacements, given mine are apparently somewhere on the road?
  8. Jul 20, 2021 at 1:27 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Gotta keep your hose in the same area code.
    sorry, no clue what they’re called. Hopefully someone chimes in that does, cause mine are looking cooked.
    bmf4069 likes this.
  9. Jul 20, 2021 at 1:28 PM
    ThatYeti
    2000 Tundra SR5
    Haha indeed, didn't drive that far so they're probably still in the same area code.....just no idea where. Thanks.
  10. Jul 20, 2021 at 1:29 PM
    Just pull one off and take it to the parts store and get a good length of vacuum hose the same size. Might as well do them all in the engine bay.
  11. Jul 20, 2021 at 1:39 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I would definitely check the other side of engine regarding vacuum lines while you're in there.
    Circled green thing just for reference. Which items do you feel you need to find ?
    D4x4TRD and bmf4069 like this.
  12. Jul 20, 2021 at 2:10 PM
    ThatYeti
    2000 Tundra SR5
    Thanks and basically all of them at this point as whichever ones aren't missing could probably stand to be replaced. Just tried the parts store but didn't have time to grab a piece without getting there after they closed and they apparently couldn't look up the hoses or even the size, so I've got to go back tomorrow with a section and just buy a length of it.
  13. Jul 20, 2021 at 2:16 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Suggest taking green thing or black box for fitting purposes since you’re buying new hoses.
    You sure you don't have enough length to see if it will clear codes ?
  14. Jul 20, 2021 at 2:22 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    If the thing doohicky behind the battery is the evap the port to the hose with the green thing is 8mm and the other port is 10mm.
  15. Jul 20, 2021 at 2:25 PM
    ThatYeti
    2000 Tundra SR5
    So the hoses aren't all the same diameter?
  16. Jul 20, 2021 at 2:30 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Id bet a 5/16 could stretch over both, but 3/8 would be loose?
  17. Jul 20, 2021 at 4:11 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  18. Jul 20, 2021 at 4:14 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Darkness and bmf4069 like this.
  19. Jul 22, 2021 at 5:07 PM
    ThatYeti
    2000 Tundra SR5
    Ok, so I think they may have just fallen off and also may have a replacement hose that doesnt fit well. So I reconnected to match the photos above and will say it definitely smells a but more of gas fumes than I recall. Have I crossed something wrong?
  20. Jul 22, 2021 at 5:41 PM
    ThatYeti
    2000 Tundra SR5
    Those hoses at the bottom seem to fit the opposite tubes much better but I was trying to match the photo @Sirfive shared above. Also all the wiggling seem to have cracked the end of the larger one so I grabbed a zip tie to keep it on at least for now.
  21. Jul 22, 2021 at 5:54 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Has anyone here ever tried cleaning an evap canister? A quick search on google says something about blowing through the hose that comes from the tank with low pressure air. My squaw stinks like gas sometimes, i think if i only run it for a minute, shut it off, then start it again…ill see what happens after it quits raining.
  22. Jul 22, 2021 at 6:43 PM
    ThatYeti
    2000 Tundra SR5
    Any reason why plugging those all in would have it smelling like gas fumes so strongly?
  23. Jul 23, 2021 at 5:07 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Here's some pics PHM helped me with when I first joined. Maybe it'll help.
    BubbaW likes this.
  24. Jul 23, 2021 at 5:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think your lines off the little box thing are backerds, which come off the TB, which smells like gas.
  25. Jul 23, 2021 at 5:10 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Sequoias are not so easy to get to. Oof.
    on the tundras, which hose comes from the tank?
    the hose that goes to this smaller front box?
  26. Jul 23, 2021 at 5:18 AM
    ThatYeti
    2000 Tundra SR5
    Appreciate that but does the tube closest to the front of the truck not get a hose?
  27. Jul 23, 2021 at 10:21 AM
    ThatYeti
    2000 Tundra SR5
    It definitely still smells like gas around the truck even though it's not been run for 12 hours. So I need to just swap back the hoses to where they seem to fit better anyway? Had them that way at first but then the cab smelled of gas pretty strongly.
  28. Jul 23, 2021 at 10:27 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    A stuck canister can smell like gas, but mine doesnt, so im not willing to experiment before someone who knows affirms, or corrects me. Cause these rebreather things, should be bypassed and vented.
  29. Jul 23, 2021 at 11:02 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I would check the above Feed/Return lines and the connection below.
    We had a triple Gnar fuel line link the other day. Hoping the initial poster is alright and nothing blew up
    Underhood fuel leak | Toyota Tundra Forum (tundras.com)
    Sirfive[QUOTED] likes this.
  30. Jul 23, 2021 at 11:11 AM
    ThatYeti
    2000 Tundra SR5
    Sorry but all these angles are killing me, do the two tubes on the right side not both get hoses? The pic here seems to show the hose coming off the green thing goes somewhere else entirely, no?
