Proper floor jack and jack stand placement
Discussion in '3rd Gen Tundras (2022+)' started by 19604X4, Apr 14, 2023.
  1. Apr 14, 2023 at 8:24 AM
    19604X4
    19604X4 [OP] New Member
    2024 Toyota Tundra TRD Pro
    Good morning all Tundra owners.
    looking for guidance/recommendation for proper floor jack and jackstand placement to lift truck.
    Not referring to the jack that comes with the truck.
    Preparing to install a Westcott Industries Design lift kit.
    Feedback appreciative.
  2. Apr 14, 2023 at 9:39 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  3. Apr 14, 2023 at 12:03 PM
    nodak67
    nodak67 New Member
    JR
    The owners manual
  4. Apr 14, 2023 at 12:09 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    It’s just a truck man, nothings changed. Buy a 3 ton floor jack.
  5. Apr 14, 2023 at 12:30 PM
    eddiefromcali
    Eddie
    100% Stock
    If youre asking this, Id assume you also need a reminder that lefty loosy, righty tighty
  6. Apr 15, 2023 at 5:16 AM
    raylo
    raylo not so new member
    Frederick, MD
    Past trucks I have used a floor jack on the rear pumpkin or front cross member to get both wheels up to place jack stands on those frame points. Not had to jack the Tundra up yet... and I also have a QuickJack these days that I will use instead of the floor jack/jack stands to rotate tires and eventually do brakes.
  7. Apr 15, 2023 at 7:22 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You can use the TRD skid plate to lift the front too.
    usmc raid likes this.
  8. Apr 15, 2023 at 9:08 AM
    eddiefromcali
    Eddie
    100% Stock
    Have you tried lifting the truck with the QJ? Using the truck adapters?
  9. Apr 15, 2023 at 9:36 AM
    raylo
    Frederick, MD
    Not yet, but it worked fine with my Tacoma. I have the original BL-7000SLX, although they make a longer version now that would probably be better for this longer vehicle. I may get the accessory rail extension kit if it seems unstable.
  10. Apr 15, 2023 at 10:05 AM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    I am bummed... I have the QJ 5000TLX with the truck adapters for my Tacoma, too bad they aren't strong enough for the Tundra. Looks like I'll need to sell them and get the 7000 series around Black Friday. QJ 5000 worked great with the Taco, but no way in hell I would risk it with the weight of the Tundra.
    Ugh. I didn't look ahead into the future I guess... back to conventional jack stands for me for the time being!
    raylo[QUOTED] likes this.
  11. Apr 15, 2023 at 10:35 AM
    eddiefromcali
    Eddie
    100% Stock
    I have the same ones, bought them years ago during a scratch n dent sale. I don't think they lift high enough for the Tundra but I haven't tried yet. They're barely long enough to reach our Teslas jacking points but have plenty of power to lift the heavy thing
  12. Apr 15, 2023 at 10:49 AM
    raylo
    Frederick, MD
    You need this:
    QuickJack 5150561 Quickjack SUV and Light Truck Adapters | Summit Racing
  13. Apr 15, 2023 at 12:35 PM
    MrKABC
    Art
    Corona, CA
  14. Apr 17, 2023 at 10:08 AM
    raylo
    Frederick, MD
    I like that guy. He gives you a lot of info in a short video with no extra fluff or nonsense.
    Mattedfred[QUOTED] likes this.
  15. Nov 2, 2024 at 6:22 AM
    mskertchly
    mskertchly New Member
    Mario
    DFW TX
    2024 Tundra SR5 4x4 TRD
    Working on painting the calipers and UCAS on my 2024 Tundra. Is it possible to lift both front wheels from the center frame using the cross bar by the trans? I have a yellow jacket floor jack
  16. Nov 2, 2024 at 8:05 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I've rotated my tires a few times using my 3-ton floor jack at the manual's recommended jacking locations. The front location seems too far back to me, as it tends to lift the entire side of the truck, instead of just the front corner. But it does work.
  17. Nov 2, 2024 at 8:10 AM
    demfer
    demfer New Member
    I made a mistake and jacked up the car by the front most cross member and can see a dent in on there now. Hope it’s ok, please use the second from front cross member which is part of the frame to raise the truck. Doh!
  18. Nov 2, 2024 at 9:29 AM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    This does NOT sound like a good idea at all.
    Spacecowboy863 likes this.
  19. Nov 2, 2024 at 10:41 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    It is rated for it and Toyota does say you can do it. Same on the 2.5 Gen.
  20. Nov 2, 2024 at 11:22 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Can confirm the 2.5gen TRD skid has a recommended jacking point that uses this block
    This isn't the official TRD skid plate but it's an exact copy from eBay
  21. Nov 2, 2024 at 3:35 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You can definitely lift from the TRD skid plate.
    TexasCabledawg likes this.
  22. Nov 4, 2024 at 5:01 AM
    mskertchly
    Mario
    DFW TX
    It worked. I used two jack stands on the sides for safety. I'll try and take a picture under the truck of the cross bar I used. Thanks everyone. BTW, the 2x4s are just there in my garage, no connection with this...lol
  23. Nov 4, 2024 at 5:21 AM
    mskertchly
    Mario
    DFW TX
    Here's before the original suspension.
    Here's after the ceramic paint job.
  24. Nov 4, 2024 at 5:30 AM
    mskertchly
    Mario
    DFW TX
    Here's the point where I jacked the truck in the red square. Interestingly enough, the Catalytic Converter plate has an indent at that point. No dent to the frame/
    Yaboy likes this.
  25. Nov 15, 2024 at 8:25 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I used my skid plate to jack up the front to change my wheels.
