PSI for 35x12.5r18
Discussion in '3rd Gen Tundras (2022+)' started by Joemh711, Jun 14, 2023.
  1. Jun 14, 2023 at 7:54 AM
    Joemh711
    Joemh711 [OP] New Member
    Joe
    2013 Crewmax Texas Edition-Sold, 2015 Red TSS Crewmax-Sold, 2020 TRD Sport Crewmax-Sold, 2023 Tundra TRD Pro
    Looked everywhere and on different forums can’t get a straight answer . Running 35x12.5r18 Load F Falken Wildpeaks AT3W on a 23 TRD Pro. What is the recommended psi for the tires for best ride ?
  2. Jun 14, 2023 at 8:00 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I run my BFG KO 33” at around 45 also. More air creates a rougher ride. Look over on the previous gen or the wheel forum. There is wealth of info.
  3. Jun 14, 2023 at 8:08 AM
    Joemh711
    Joe
    Got it that’s what I figured . Discount Tire inflated them to 32 psi . I was thinking that was way too low .
    Eurodriver likes this.
  4. Jun 14, 2023 at 8:10 AM
    Tom
    Tom New Member
    You still got oem tires?
  5. Jun 14, 2023 at 8:16 AM
    Joemh711
    Joe
    No got after market 35s
  6. Jun 14, 2023 at 8:17 AM
    mass-hole
    mass-hole New Member
    Probably. Depends on some tires.
    I have 3 load range C's in my garage and all of them show the max load rating at different pressures. The Goodyear Territoty MT's I just got for my truck are 2535 lbs at 35 psi. The KO2's that are currently on my truck are 2535 at 45 psi. Then KO2's on my Lexus GX are 2755 at 50 psi.
  7. Jun 14, 2023 at 8:18 AM
    Tom
    Tom New Member
    Should have said. Do you still have take off tires. Would you like to sale them ?
  8. Jun 14, 2023 at 8:19 AM
    Joemh711
    Joe
    Sorry I literally just sold them yesterday with 100 miles on for $200 for the set
    Tom[QUOTED] likes this.
  9. Jun 14, 2023 at 8:25 AM
    Tundra Owner2Be
    Tundra Owner2Be Tundra Owner2
    Per Falken website, the max pressure (PSI cold) is 80.
  10. Jun 14, 2023 at 8:30 AM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    2016 sr5 Crewmax TRD Off Road
    de-badged, hood decal, Pro Headlights, Paint Match Pro grill and hood. DVD monitors. neoprene seat covers, weathertech floorliners
    1. Let the chalk tell you
      You can also “calculate” your tire pressure with the chalk method. This involves coloring a section of your tire with chalk to see how much tread is making contact with the ground. Start by finding a flat road surface. Concrete is actually the best choice, but you can also do this on asphalt. Make a mark with soft chalk that goes all the way across your tread. Then, gradually drive your truck forward about 50 feet and then backwards 50 feet.
      Analyze the chalk on the tire. If the chalk is only worn off on the center of the tire, reduce the tire pressure slightly and go through the process again. With the adjustment, you should see the chalk wear off more broadly. Keep making tiny adjustments in the tire pressure until the chalk wears off evenly and all the way across the tread.
      You will have to complete this process for each of your four tires. Once you’ve found the right street pressure, add 10% to all four tires. Then, measure the tires and add pressure to balance them. As explained above, you need to measure from the wheel to the ground. Start by balancing the profiles of the front tires with each other. Then, balance the front tires again with the rear tires. Always adjust the tires with the smaller profiles by adding air.
      The advantages and disadvantages of this method are the same as those involved in the second method above. If you go through the process correctly, you end up with the ideal tire pressure. But, this method is tedious and there’s a reasonable chance that you will make a mistake.
    DFS and Ponderosa_Pine like this.
  11. Jun 14, 2023 at 10:08 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    This will almost always say to use 35psi for most larger tires. The chalk test (as mentioned above) will also indicate about 35-38psi is correct for a 6000lb truck. If you had a static load like a camper this would be different. PSIs like 50-60 (exact same tire) are meant for situations like a one ton truck weighing 7500lbs hauling up to 3000lbs of cargo. Over inflation will result in the middle part of the tire wearing out and a harsh ride.
  12. Jun 14, 2023 at 10:54 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Go do a chalk test and tell us what you find. Will be a good data point!
  13. Jun 14, 2023 at 10:58 AM
    mass-hole
    I dont love that site because they dont always have the right numbers. They insist a LT315/70R17 C range should only be inflated to 35 psi even though my sidewalls clearly state 2535 @ 45 psi.
    I ran mine at 37 PSI because that was what was on the F150 Raptor door sticker and is what these tires are from. They wore like absolute garbage in the rear.
  14. Jun 14, 2023 at 11:02 AM
    mass-hole
    What is the max inflation pressure and load rating on your sidewall? 65 psi or 80 psi?
    I had load range D 37x12.5R17 Geolandars and they were rated for 3525 lbs load at only 50 psi. I had to run them below 30 for the tread to even be close to flat on the ground.
  15. Jun 14, 2023 at 11:26 PM
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
    Def do not run them at 80psi cold that is max press with max hauling load on truck or towing max weight. Run them at 40psi and you will be fine. Talked to tire manufacturer and did the chalk test. 40 psi for E/F load rated tires is perfect and gives a good ride. It’s def not to low of a pressure. I have the wear on the tire to prove it. It was perfect! Good luck!
    Black widow TRD likes this.
  16. Jun 15, 2023 at 8:17 AM
    Joemh711
    Joe
    Thanks ! Had more issues with balancing was about to start washing the truck and noticed the balancing weights had slid off over the rim . Dropped it off at discount hopefully they can get it fixed now .
  17. Jun 15, 2023 at 9:45 AM
    Jinkx
    Jinkx New Member
    Keith
    Yea they will get it right for you
    Good thing you saw it!
  18. Jun 15, 2023 at 9:49 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Told you it was the balance !! Ask the for one of the senior techs to perform the balance. Mine initially was down by one of the young bucks, and they did not leave it right.
    For testing purposes I got my truck up to triple digits and it rode buttery smooth.
    I’ve had Discount tire drop the ball. As a matter of fact this time they installed the tire on my SR5, they damaged my wheels. They are going to call me to schedule an appointment to get my wheels fixed.
    Be sure to check your wheels for any scratches or marks.
