Pulls hard to the left when brakes are applied
Discussion in '1st Gen Tundras (2000-2006)' started by kimmi33, Sep 10, 2023.
  1. Sep 10, 2023 at 9:10 PM
    kimmi33
    kimmi33 [OP] New Member
    I have a 2005 double cab tundra sr5 4x4 and it pulls extremely hard to left (driver side) when driving but mostly when brakes are applied . Ive replaced rack and pinion because thats what I was told was wrong but it still does it . Any Ideas?
    it has new wheel cylinders shocks struts too .
    Ive spent so much and now I just need to have it fixed.....
  2. Sep 10, 2023 at 9:17 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Stop replacing parts before diagnosing the problem. you’re going to start a forest fire burning all that cash.
    pulling under braking could be something as simple as a frozen caliper on the opposite side.
    When was the last time you had an alignment?
    can you post a pic of your tires so we can look for abnormal tire wear?
    Any knocking or banging when turning or going over bumps?
    does the steering feel “loose” at all?
    What’s your mileage?
    “wheel cylinders” I’m assuming is wheel bearings?
    do you have copies of the invoices so you can tell us exactly what work was done?
    does it pull at certain speeds or all speeds?
    does it pull in 2wd as well as 4wd?
    also, welcome aboard.
    kimmi33[OP], Aerindel and DJenerated like this.
  3. Sep 10, 2023 at 9:21 PM
    How about the front brakes?
    I doubt the rear brake cylinders are your problem.
  4. Sep 10, 2023 at 9:42 PM
    kimmi33
    I just purchased the truck and got a great deal for it and was told it needed a rack and pinion . the truck has sat up for a good bit . i ordered the part and mechanic put it in . the other parts were put in before i got it . before the rack and pinion the wheel felt like it took a min for it to actually turn when turning the wheel . and when driving it would pull quick and hard to left . now steering feels right but still pulls but now when braking .
    when the front is jacked up is the strut supposed to rub or touch the coil over shock?
  5. Sep 10, 2023 at 9:48 PM
    kimmi33
    when you look at the tire or wheel it looks like its laying out some
  6. Sep 10, 2023 at 10:00 PM
    Was the truck in an accident?
  7. Sep 10, 2023 at 10:01 PM
    kimmi33
    no accident . i left out it has a 3 inch lift with 20 in tires and wheels
  8. Sep 10, 2023 at 10:01 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    No. But you mentioned things that are more or less the same thing for our sake. Shock and strut are both acceptable terms for the front shocks. Coilovers is also an acceptable term for the front coil and strut assembly (though technically not accurate).
    I think it needs an alignment after the new rack n pinion.
    But I'm also concerned as to wtf is causing your coil and strut to hit eachother. That is if I'm understanding this right.
  9. Sep 10, 2023 at 10:02 PM
    DJenerated
    Dija
    The Lone Star State
    Ok. Now it's making more sense.
    Do you know what kind of lift?
    I bet the upper control arms are stock. That's affecting your alignment geometry, if so.
    ZappBrannigan and FrenchToasty like this.
  10. Sep 10, 2023 at 10:04 PM
    kimmi33
    so you think the truck should be right after alligned? and sorry I dont know very much about vehicles but im trying and learning as im going,
    DJenerated likes this.
  11. Sep 10, 2023 at 10:05 PM
    kimmi33
    dont know what kind just know 3 inch lift
  12. Sep 10, 2023 at 10:13 PM
    DJenerated
    Dija
    The Lone Star State
    We're going to need pics.
    ZappBrannigan likes this.
  13. Sep 10, 2023 at 10:15 PM
    DJenerated
    Dija
    The Lone Star State
    Maybe, but not if you have the original upper control arms and a 3 inch lift. You need off-road upper control arms for anything above 2 inches of lift.
    ... Unless it's a 3 inch body lift.
    We need pics, bad. Other wise we're just pissin in the wind here. Turn your wheels all the way to one side and get a couple good pics of the problem area you mentioned
    ZappBrannigan and Tripleconpanna like this.
  14. Sep 10, 2023 at 10:16 PM
    kimmi33
    going to take pics now
    Tripleconpanna and ColoradoTJ like this.
  15. Sep 10, 2023 at 10:47 PM
    kimmi33
  16. Sep 10, 2023 at 10:48 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Your description makes it sound like it wasn’t aligned properly after the rack and pinion install.
  17. Sep 10, 2023 at 10:49 PM
    kimmi33
  18. Sep 10, 2023 at 10:52 PM
    DJenerated
    Dija
    The Lone Star State
    Exactly what I suspected. You got a cheap 3 inch hockey puck (plastic spacer) for a lift and stock upper control arms. You need to remove that lift and looks like the person lied to you about new shocks
    Oh shit... Is that also a ball joint extention I see? Or perhaps a Trail Master (Disaster)?
    Not sure. Never seen either on these trucks.
    That hockey puck is 3 inches and it's likely giving you more like a 6 inch lift. And it looks like you have two spacers stacked on top of each other. That's very bad.
    I imagine you also have a drop bracket in front for your lower control arms. Now we needs pics of the truck from the front, but down low.
  19. Sep 10, 2023 at 10:55 PM
    kimmi33
    thank you
  20. Sep 10, 2023 at 10:57 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did you grab a photo of your rack while you were out there???
    We should make sure that looks right too...
    Edit: x2 on pulling out the spacer lift!!
  21. Sep 10, 2023 at 10:59 PM
    DJenerated
    Dija
    The Lone Star State
    The previous owner fucked this poor trucks suspension to hell. Take it back and get your money back. Kick the previous owners ass for me too.
    ZappBrannigan and SAGE63 like this.
  22. Sep 10, 2023 at 11:15 PM
    DJenerated
    Dija
    The Lone Star State
    If it has a drop bracket, the good news is you might be able to just remove the top smaller metal spacer on both sides of the truck and keep the larger plastic spacer for now. The bad news is you're going to need an alignment and those tires may not fit anymore in front
  23. Sep 10, 2023 at 11:16 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Yeah, that upper control arm is stock and stretched way past where it should be sitting. You’ll need need to address that before anything else. I’ll echo what these fine gentleman have already said and remove that upper spacer as step one.
    Tripleconpanna likes this.
  24. Sep 10, 2023 at 11:18 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    This.
  25. Sep 10, 2023 at 11:25 PM
    DJenerated
    Dija
    The Lone Star State
    I'm not sure about if drop bracket lifts need off road UCAs or not. But it couldn't hurt the situation, just hurt her bank account a little more. haha
    At least now days you can buy those cheap ass scamazon/ebay freedom off road UCAs. I wouldn't... But a lot of people do.
    I chuckle when I see a truck with King, Fox or Icon coilovers and freedom UCAs.
    ZappBrannigan[QUOTED] likes this.
  26. Sep 10, 2023 at 11:28 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I think I worded that badly. I meant that it was clearly a bad angle and to address that angle. The easiest way is to remove the lift. But if she’s got a 3” spacer lift already with another spacer on top of it she’s going to need control arms anyway I would imagine, even if she pulls the top spacer out.
    and yeah suspension is one of those places I wouldn’t want to cheap out… suspension and brakes…
  27. Sep 11, 2023 at 5:43 AM
    Looks like the Tuff Country 4.5" lift. Others on here have it installed and have zero problems (Edit: zero problems like OP describes). Although it looks like some dumbass threw a 2" strut spacer (that silver puck, OP) in above it, which ... if it were me, I'd get rid of.
    For pics of what that setup looks like in the wild: https://www.tundras.com/threads/hi06silvers-unf-ck-my-tuff-country-lift-thread.90187/
    You'll also see the same on this truck with a 3" body lift: https://www.tundras.com/threads/new-lifted-1gt-owner-need-advice.129014/
    It's a bracket lift, as you'll see in both of those threads, one having a video walkaround. There's a lot of beef folks have with the knuckle spacer it uses, so much they only recommend Tuff Country's 5" lift which I believe comes with replacement knuckles.
    That said, if this is legit, I don't think the lift is the cause here. I also don't necessarily think steering is the cause either, although knowing what that spacer could be doing to amplify things, something may very well be bent, and Cap'n B may be correct, rack install wasn't handled properly.
    First thing I'd do is take it into a qualified offroad shop that can handle custom alignments. Verify the alignment is fine. You may want them to pull that puck, then replicate pulling 2" out of the rear, I'm assuming the previous owner probably used blocks in the back.
    Next thing I'd be doing is evaluating the brakes. The fact this issue happens when you step on the brakes could indicate you've got a stuck brake caliper piston, or a soft brake line is collapsing.
    Jack McCarthy and KNABORES like this.
  28. Sep 11, 2023 at 5:48 AM
    Dammit, I just realized @s25hanh pulled the video. Ah well. Others on the forum have the same lift.
    I don't think that's his truck though. I know he was trying to sell it, and he got it for pretty cheap.
  29. Sep 11, 2023 at 5:50 AM
    My drivers front brake caliper has failed twice on me. Same both times, starts pulling to the left when braking. It’s probably not the steering, but picks of the rack still may be helpful.
  30. Sep 11, 2023 at 6:25 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Does the bottom spacer look crooked to anyone else? Or just an illusion?
    DJenerated and Mr Badwrench like this.
